- 18 December 2010
- 9,067
SRA = the Stylus Rake Angle. This is the angle the stylus makes in relation to the cantilever and the body of the cartridge. The SRA should be identical to the Vertical Tracking Angle (VTA) when the top of the cartridge is mounted parallel to the record's surface. If the Stylus Rake Angle (SRA) is not identical to the VTA, the SRA has to be adjusted until it reaches the correct VTA and mimics the cutter diamond. One method to achieve this is by adjusting the height of the arm at the pivot. The headshell will no longer be parallel to record's surface. Another method is to put a wedge in between cartridge and headshell. Since the engraved signal in the record measures micrometers, it is obvious that if the SRA is incorrect, a higher level of distortion will be heard.
αυτα για το ΣΡΑ, αν και δεν βλεπω πως αφορα την συζητηση μας. μιλαμε για το αν και γιατι τα 180 γρ παιζουν καλυτερα. οι ρυθμισεις προφανος πρεπει να ειναι οκ.
