Nikon Z 9
Chris75
18 May 2008
163
Παιδιά, η μηχανή πουλάει σαν ζεστό ψωμάκι στην κατηγορία της, έχει τα πρωτεία στις πωλήσεις, σε βαθμό που εντείνονται οι φωνές να υπάρξει απάντηση απ την... Sony !
Άργησε, αλλά τους έστειλε αδιάβαστους η Nikon.
NassosT
4,706
Νέο firnware 2.1: https://downloadcenter.nikonimglib.com/en/download/fw/454.html
• [High-frequency flicker reduction] has been added to the roles that can be assigned to camera controls using Custom Setting f2 [Custom controls (shooting)]. For more information, see the Supplementary Firmware Update Manual.
• Autofocus is now better at tracking small subjects.
• Autofocus now produces more accurate results with human portrait subjects detected via eye/face-detection AF with [Continuous AF] selected for [Focus mode].
• Fixed an issue that resulted in the camera focusing on the background when [Single-point AF], [Dynamic-area AF (S)], or [Dynamic-area AF (M)] was selected for [AF-area mode], or when [Wide-area AF (C1)] or [Wide-area AF (C2)] was selected with a custom focus-area size of [1×1].
• You can now expect better results from vibration reduction during panning shots taken with the camera pointing up or down and an option other than [Off] selected for [Vibration reduction].
• Fixed the following issues:
- With certain Z mount lenses, choosing [Focus] for Custom Setting a1 [AF-C priority selection] with [Continuous AF] selected for [Focus mode] would sometimes disable the shutter release even when the subject was in focus.
- [Aperture lock] could not be selected for Custom Setting f4 [Control lock] in modes M and A when an F mount lens was attached.
- Assigning [Recall shooting functions] to a control using Custom Setting f2 [Custom controls (shooting)] would render [Save current settings] unavailable when an F mount lens equipped with an aperture ring and power contacts was attached.
- Auto distortion control would sometimes not be applied to pictures taken with [ON] selected for [Auto distortion control] in the [PHOTO SHOOTING MENU].
- The camera would not recognize custom Picture Controls saved to a memory card using the Mac edition of Picture Control Utility 2.
- Recalling shooting functions would sometimes result in unexpected changes to exposure if:
▸ ISO sensitivity was set to a fixed value in mode M,
▸ an option other than [Exposure maintenance off] was selected for Custom Setting b7 [Keep exp. when f/ changes], and
▸ [Recall shooting functions] or [Recall shooting functions (hold)] was assigned to a control using Custom Setting f2 [Custom controls (shooting)] both with no option (or mode M only) selected for [Shooting mode] and with no check next to any of [Shutter speed], [Aperture], and [ISO sensitivity settings].
- When [Recall shooting functions] or [Recall shooting functions (hold)] was assigned to a control using Custom Setting f2 [Custom controls (shooting)], subject detection would not function as expected if the setting for [AF subject detection options] recalled by pressing the control differed from the option currently selected for [AF subject detection options] in the [PHOTO SHOOTING MENU].
Reactions: gpapjohn
kbouk
8 January 2010
22,422
ΠΕΙΡΑΙΑΣ
Νάσο με την πρώτη βελτίωση στο flicker πιστεύεις οτι λύθηκε το πρόβλημα με τις λεντοπινακίδες ?
evanfotis
26 March 2008
5,485
Ευπρόσδεκτες βελτιώσεις.
Δοκίμασες;
Το auto iso δε λειτουργούσε πριν σε manual mode?
NassosT
4,706
Δεν το έχω δοκιμάσει ακόμα.
Το auto iso λειτουργεί κανονικά σε M mode και με την 2.0.
Κώστα, φαίνεται ότι λύνεται. Από την άλλη δεν μου φαίνεται και πολύ πρακτική λύση σε fast paced συνθήκες να πρέπει να ασχοληθείς με τη ρύθμιση του shutter speed με τόση ακρίβεια.
Kosh
7 September 2006
91,466
Εκεί ψηλά.....
Εγω παλι σας λεω οτι με τοσες διαφορετικες συχνοτητες εκπομπης απο τα διαφορα φωτιστικα παντα πρεπει να ασχολεισαι τελικα με το shutter speed αν δεν θες τιποτα περιεργα.
Βεβαια φτιαχνουν και μετα καποια για να ειμαστε ακριβεις στο post production (το εβλεπα και δεν το πιστευα) αλλα οχι παντα.
NassosT
4,706
Αυτό ακριβώς. Δε γίνονται αυτά, δεν βολεύουν στην πράξη. Όπως δουλεύει το Auto flicker reduction, που καταλαβαίνει αν τα φώτα είναι 50 ή 60 Hz, έτσι θα πρέπει να φτιαχτεί να λειτουργεί και το "νέο" σύστημα.
Εδιτ: Βέβαια αν έχεις στο κάδρο πχ τρεις διαφημιστικές πινακίδες με διαφορετικές συχνότητες, δεν μπορούν να γίνουν και πολλά.
Reactions: kbouk
Kosh
7 September 2006
91,466
Εκεί ψηλά.....
Ε ναι εκει κανεις μια επιλογη
Τις σπας
Τις βγαζεις απο την πριζα και βαζεις δικες σου
Ζεις με αυτες.
Ολα τα αλλα τωρα ....
NassosT
4,706
Δούλεψα το ΣΚ με το νέο firmware σε δύο ποδηλατικούς αγώνες, το μόνο που έχω να παρατηρήσω είναι ότι πράγματι υπάρχει βελτίωση στο AF, σε ό,τι αφορά την ταχύτητα που βρίσκει και κλειδώνει το θέμα και το πόσο καλά το "κρατάει". Αισθητή βελτίωση, όχι συνταρακτική βέβαια, μια και ήδη ήταν εξαιρετικές οι επιδόσεις της μηχανής σε autofocus.
NassosT
4,706
Φοβερό και το επι κοντώ γυναικών σήμερα στο Βερολίνο στο Πανευρωπαϊκό Στίβου. Τρέλανε όλο τον κόσμο η Φινλανδή Μουρτο, με το 4.85 της (PB & NR).
Δείγμα της Ζ9
Reactions: racer
evanfotis
26 March 2008
5,485
Νάσο ωραία σύνθεση με τις διαγώνιες και timing!
Για βάλε και το exif data να δούμε.
Reactions: NassosT
