Απάντηση: Re: Nikon Χρώματα
καλο πραγμα ε.....?
Ωραίες λήψεις (στο καδράρισμα αναφέρομαι, εφόσον δέν έχει υποστεί μικροδιορθώσεις, άν και τις πέρασες όπως είδα απ' το
Capture NX 2.1.1 W).
Ψάξου όμως λίγο έξω απ' τ' αυτόματα προγράμματα.
Τα στοιχεία λήψης σου στην πρώτη φωτογραφία με τις τρείς κοπέλλες:
http://i237.photobucket.com/albums/ff99/gomar_4/delfinario/DSC_0044_1.jpg
* Camera Make = NIKON CORPORATION
* Camera Model = NIKON D90
* Picture Orientation = normal (1)
* Interoperability Index = (0)
* Y-Resolution = 72/1 ===> 72
* X/Y-Resolution Unit = inch (2)
* Software / Firmware Version = Capture NX 2.1.1 W
* Last Modified Date/Time = 2009:08:16 11:28:31
* Y/Cb/Cr Positioning (Subsampling) = centered / center of pixel array (1)
* Reference Value of Black/White Point = 0/1,255/1,0/1,255/1,0/1,255/1
Exif Sub IFD
* Exposure Time (1 / Shutter Speed) = 1/100 second ===> 0.01 second
* Lens F-Number / F-Stop = 56/10 ===> ƒ/5.6
* Exposure Program = aperture priority (3)
* ISO Speed Ratings = 1000
* Exif Version = 0220
* Original Date/Time = 2009:08:15 22:39:40
* Digitization Date/Time = 2009:08:15 22:39:40
* Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr
* Exposure Bias (EV) = 0/6 ===> 0
* Max Aperture Value (APEX) = 5/1 ===> 5
Max Aperture = ƒ/5.66
* Metering Mode = pattern / multi-segment (5)
* Light Source / White Balance = unknown (0)
* Flash = Flash did not fire
* Focal Length = 185/1 mm ===> 185 mm
User Comment Character Code = ASCII
User Comment =
* Last Modified Subsecond Time = 00
* Original Subsecond Time = 00
* Digitized Subsecond Time = 00
* FlashPix Version = 0100
* Colour Space = sRGB (1)
* Image Width = 1024 pixels
* Image Height = 689 pixels
* Image Sensing Method = one-chip color area sensor (2)
* Image Source = digital still camera (DSC)
* Scene Type = directly photographed image
* Colour Filter Array (CFA) Geometric Pattern = 0x00,0x02,0x00,0x02,0x01,0x02,0x00,0x01
* Custom Rendered = normal process (0)
* Exposure Mode = auto exposure (0)
* White Balance = auto (0)
* Digital Zoom Ratio = 1/1 ===> 1
* Focal Length in 35mm Film = 277
* Scene Capture Type = standard (0)
* Gain Control = high gain up (2)
* Contrast = normal (0)
* Saturation = normal (0)
* Sharpness = normal (0)
* Subject Distance Range = unknown (0)
Το αυτόματο βελτιώνει τη Nikon που, σίγουρα κάνει καλή δουλειά.
Τώρα, το γιατί νομίζω οτι παίρνοντας τη D90 δέν έψαχνες μόνο τα αυτόματα αλλά κάτι παραπάνω... αυτό είναι μιά άλλη ιστορία.
Σε αντίθετη περίπτωση, μάλλον θά' χες αγοράσει μιά πανάκριβη κόμπακτ που, όλα τα κάνει μόνη της, εκτός απ' το καδράρισμα.
Φιλικά και πάντα με καλή διάθεση,
Γρηγόρης.
ΥΓ: Σπάνια έχω γράψει απόψεις μου για παρουσιάσεις συνφορουμιτών.
Τώρα, τί με τσίγκλησε με σένα... μάλλον φταίει τ' οτι είμαστε γείτονες.
Αυτά.
