Νομιζω ειναι καλυτερα εδω.
Με φθηνότερη την Panasonic BGH1.
APPROVED CAMERAS
CAPTURE REQUIREMENTS
- Resolution Requirements
- Camera must have a true 4K UHD sensor (equal to or greater than 3840 photosites wide)
- Capture Formats:
- RAW (e.g. X-OCN, REDCODE, Arriraw etc.) or COMPRESSED (e.g. XAVC, AVC-Intra, ProRes, or other I-Frame capable formats)
- Minimum of 16-bit Linear or ≥ 10-bit Log processing
- Minimum data-rate of 240 Mbps at 10-bit UHD 23.98 fps
- Capture Transfer Function
- S-Log3, Log-C, V-Log, Log3G10, etc.
- Capture Color Space
- S-Gamut3.cine, RED Wide Gamut RGB, Alexa Wide Gamut, etc.
- No looks or color corrections should be baked into the original camera files.
- Files must maintain all metadata (i.e. Tape Name, Timecode, Frame Rate, ISO, WB, etc.).
