-LG TV Line-up 2021-
xavito
29 October 2008
9,009
65"...[rtings.com]...LG 65QNED90UPA review...https://www.rtings.com/tv/reviews/lg/qned90
η αντίστοιχη ευρωπαϊκή είναι η 65QNED916PA
65QNED90UPA : panel τύπου ADS, το οποίο είναι παρόμοιο με ένα IPS,RGB-vertical stripe
F.A.L.D. (περίπου 1000 ζώνες) mini LED LCD
120Hz με MCFI + αναβόσβησμα του οπίσθιου φωτισμού
Wide Color Gamut DCI-P3 coverage : ναι
xavito
29 October 2008
9,009
LG launches its first LED TVs, starting at $70,000...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1631624397
-LG Electronics has launched its first-ever LED TVs, called DVLED, designed for residential installations. The LED TVs are available in 81- to 325-inch sizes with HD, 4K or 8K resolution, starting at $70,000.
πηγή:[flatpanelshd.com]
-LG DVLED: Modular MicroLED screens for home cinema with resolution up to 8K...https://www.hdblog.it/tv/articoli/n543991/lg-dvled-display-microled-modulari/
DVLED FULL HD
DVLED ULTRA HD
DVLED 8K
Prices, as it was rather predictable, are absolutely elitist: it starts from around 70,000 dollars up to 1.7 million dollars .
Sold only through CE pros, LG DVLED Extreme Home Cinema offers 16:9 displays from 81 to 325 inches, and UltraStretch videowall units in 32:9.
994999
πηγή: hdblog.it
πηγή : prohardver.hu
xavito
29 October 2008
9,009
55"...[prohardver.hu]...LG 55NANO813PA review...https://prohardver.hu/teszt/lg_nano81_nanocell_technologia_4k_hdr_teve/lg_nano81.html
The LG NANO81 television was provided by LG's Hungarian office
55NANO813PA : IPS panel
60Hz
Edge LED LCD
Then we tried to shoot the target values (120 cd / m² brightness, 6500 K color temperature, 2.2 gamma) and to achieve the highest color accuracy, which was more or less successful.
The average value of the delta E was 0.46, which is a great value, but the largest delta E was 2.84, and we have already achieved significantly better results with the manufacturer's other televisions.
The brightness became 120.7 cd / m² at a black level of 0.2245 cd / m², which represents a real contrast of 537.4: 1
Οι ρυθμίσεις είναι μόνο για αναφορά.
Δεν υπάρχει καμία εγγύηση ότι θα σας δώσουν την καλύτερη εικόνα που είναι σύμφωνη με τα πρότυπα της βιομηχανίας και κατάλληλη για το περιβάλλον προβολής σας (ειδικά ισορροπία λευκού, ρυθμίσεις συστήματος γάμμα και χρώματος που διαφέρουν από μονάδα σε μονάδα).
Εάν θέλετε μια εγγυημένη βαθμονομημένη εικόνα, καλέστε έναν επαγγελματία βαθμονομητή τηλεόρασης.
AI image : off
AI brightness settings : off
Energy saving step : off
Picture mode : Original
Panel brightness : 64
Contrast : 95
Screen brightness : 22
Automatic dynamic contrast : off
Gamma: 2.2
Black level: Automatic
Local dimming : off
Eye-saving function : off
Color depth: 55
Shade : 0
Color scale: Native
Sharpness : 25
Super resolution : off
Noise abatement : off
MPEG noise reduction : off
Smooth gradation : off
TruMotion : off
xavito
29 October 2008
9,009
65"...[rtings.com]...LG 65NANO75UPA review...https://www.rtings.com/tv/reviews/lg/nano75-2021
Direct LED LCD
60Hz
ADS panel, which is similar to IPS,RGB subpixel layout
webOS 6.0
Η αμερικάνικη 65NANO75UPA αντιστοιχεί με την ευρωπαϊκή 65NANO756PA
Recommended settings 65NANO75UPA...https://www.rtings.com/tv/reviews/lg/nano75-2021/settings
xavito
29 October 2008
9,009
Michalis3
25 February 2011
8,020
Πιθανώς, αφορά όλα τα (OLED) μοντέλα από την LG για το 2021 (και όχι μόνο)
πηγή : hdtvtest.co.uk
You can now turn off the "No Signal" message on the LG C1 OLED, which is a feature added by the latest firmware update of 03.20.12 (the last two digits may vary by region). According to our sources, this function will also be included in a forthcoming software update for last year's LG CX OLED to add 4K 120Hz Dolby Vision gaming support. Other features added by this firmware include a new "OLED Care" submenu, as well as a "Memory Optimiser" feature to improve the responsiveness of WebOS 6.0 by clearing unused apps, thus freeing up memory & storage.
xavito
29 October 2008
9,009
50"...[geex.x-kom.pl]...LG 50NANO863PA review...https://geex.x-kom.pl/recenzje/test-i-recenzja-telewizora-lg-50nano863pa/
50NANO863PA ίδια με την 50NANO886PB
Panel type : VA , subpixel panel structure RGB,4-domain,vertical stripe
Panel technology : LCD
Backlight type : Edge (bottom) LED,vertical local dimming zones (on,off)
120Hz panel με MCFI
ANSI Contrast Ratio : 3576:1
Unfortunately, as in the 55NANO863P, the 50-inch model also repeated the strange phenomenon of distortion of the red color: instead of 75 percent red, the TV displayed a shade of color ... Orange.
This phenomenon occurred during playback of files from USB and DVB-T transmission. When playing the signal from HDMI, it occurred less frequently.
Unfortunately, this is the second model of the LG NanoCell TV that manifests this drawback.
Noticed by me for the first time during the test of the 55NANO863P model in June this year, it is repeated in the 50-inch model and this despite a different software version: 03.15.90 in 50NANO863P instead of 03.11.35 in 55NANO863P.
In other words, despite the passage of three months, this error still haunts the 863P series.
Perhaps the manufacturer is not aware of the problem, which is why I am raising this issue again.
Despite almost four times the contrast ratio, just like in the 55-inch model, the TV uses and factory activates "local dimming" (LPLED) – in my opinion, completely unnecessary.
LPLED in combination with edge lighting can only dim/dim entire vertical parts of the screen, which falsifies the image and destroys the original vision of the filmmakers (the frames come from HDR material, during which the backlight works at full power).
Fortunately, the manufacturer allows the user to turn off local dimming and then on the screen we will see dark and uniform blacks.
(the picture come from HDR material, during which the backlight works at full power).
HDR
In filmmaker (HDR) mode on the board, the maximum luminance during three minutes of measurement was stable and amounted to 415 cd/m²(nits).
xavito
29 October 2008
9,009
65"...[flatpanelshd.com]...LG 65G16LA (65G1) review...https://www.flatpanelshd.com/review.php?subaction=showfull&id=1634180944
SDR_Pre_Cinema
HDR Pre Cinema Home
calibration settings 65G1:
Setting
Picture mode :ISF
Energy Saving : Off
Format Aspect ratio: Original
Just scan : On
Global OLED Light : 65
Contrast : 85
Brightness: 50
Dynamic Contrast: Off
Gamma: 2.2
Black level: Auto
Color
Color: 50
Tint: 50
Color gamut: Auto
Picture options
MPEG Noise reduction: Off
Sharpness: 0
Super resolution: Off
Smooth Gradation: Low / Off
Motion Eye Care :Off
TruMotion: Off / Cinema screen
OLED Motion Pro : Off
xavito
29 October 2008
9,009
LG Display has revealed that it will introduce a 97-inch OLED panel next year, and so we expect LG Electronics to launch a 97in OLED TV in 2022.
Although the screen resolution is not specified, it's likely to be 8K rather than 4K to justify the significant price premium.
We also explain why LG stopped short of 100 inches, and had to settle with *only* a 97-inch OLED panel.
Source: http://koreabizwire.com/samsung-lg-vie-for-the-upper-hand-in-100-inch-tv-market/202019
LG Display interview at Blue Light Summit 2021:
πηγή:hdtvtest.co.uk
furious99
20 December 2008
866
edited by xavito:
LG to offer free 3-month Apple TV+ trial to 2016-2021 TV owners...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1635826566
πηγή : flatpanelshd.com
furious99
20 December 2008
866
Είναι πολύ πιθανο ότι αρχές 2022, θα είναι διαθέσιμη έκδοση του KODI από ανεξάρτητο προγραμματιστή στο Content store της LG στις smart TV. Το εγχείρημα είναι δύσκολο γιατί οι LG smart TVs δεν τρέχουν android. Προς το παρόν είναι σε alpha stage και τρέχει σε developer mode σε pc. Όταν είναι έτοιμη θα υποβληθεί στην LG για να μπει στο Content store, από όπου και θα μπορούμε να την κατεβάσουμε. Λεπτομέρειες για το project εδώ:
xavito
29 October 2008
9,009
Some of the recent LG C1 & G1 OLED TVs with a build date of September 2021 or later have been affected by an HDCP 2.2 bug which prevents the TV from playing 4K HDR sources (including from PS5, Xbox Series X, Sky Q & 4K Blu-ray players).
LG has promised a software fix via firmware update which is estimated to arrive before the end of November 2021.
πηγή: hdtvtest.co.uk
xavito
29 October 2008
9,009
We crowned the best TV of 2021 in our annual TV shootout where the LG G1, the Panasonic JZ2000, the Philips OLED+936, the Samsung QN95A & the Sony A90J were compared vs a Sony BVM-X300 reference mastering monitor.
Timestamps:
0:00 World’s Best TVs!
1:13 Black Level & Shadow Detail
2:05 Colour Accuracy
3:27 HDR Performance
4:25 Motion
5:08 Video Processing
6:00 Screen Uniformity
6:43 Bright Room
7:32 Best Gaming TV
8:17 Best Home Cinema TV
8:51 Best Living Room TV
9:24 Best TV of 2021
10:34 Q&A
All competing TVs were 55 inches in screen size, and were calibrated in SDR and HDR modes to the common standards used within the film and broadcast industry, perceptually matched to the Sony X300.
Thanks to Mr Maciej Koper who flew in from Poland to help with the calibrations.
All the TVs were masked, and their positions switched on shootout day, so the three calibrator judges (including Mr James Willmott who is a THX-certified video calibrator) didn't know which TV was which when scoring different picture attributes.
Here are the results:
Best Home Cinema TV: Panasonic JZ2000
Best Living Room TV: Sony A90J
Best Gaming TV: LG G1
Best TV of 2021: Sony A90J
Michalis3
25 February 2011
8,020
Φαίνεται πως επιλύθηκε το πρόβλημα...
LG has started rolling out firmware update 03.20.80 which fixes the HDCP 2.2 bug on affected C1 & G1 OLED TVs. The OTA rollout is staggered, but you can also download the software from your regional LG support site to be installed manually via USB. We also measured the SDR & HDR peak brightness of firmware 03.20.45, 03.20.65 & 03.20.80, and found no significant differences according to our meters.
Θα είναι χρήσιμο να επιβεβαιωθεί αυτό και στα σχετικά threads (καινούργιων) κατόχων στο forum. Τα τρία (ή τέσσερα) πρώτα νούμερα στον κωδικό υποδεικνύουν το έτος και τον μήνα κατασκευής, αν δε λανθάνομαι ([0/2]1xx).
