[Επίσημο] MacBook Pro M2 & Mac Mini M2 @2023
evanfotis
26 March 2008
5,486
Apple today announced the next-generation 14-inch and 16-inch MacBook Pro models with faster M2 Pro and M2 Max chips, up to 96GB of RAM, an upgraded HDMI 2.1 port with support for an 8K external display, faster Wi-Fi 6E, and other new features.
The new M2 Pro chip features a 10-core or 12-core CPU and offers up to 20% faster performance than the M1 Pro chip, according to Apple. The chip also has up to a 19-core GPU that delivers up to 30% more graphics performance, while the Neural Engine is 40% faster.
The higher-end M2 Max chip has an improved 12-core CPU with up to eight high-performance and four high-efficiency cores and delivers up to 20% faster performance than the M1 Max chip, and it has up to a 38-core GPU, according to Apple. With the M2 Max chip, the new MacBook Pro is now up to 6x faster than the fastest Intel-based MacBook Pro.
Both new MacBook Pro models are now available with up to 96GB of unified memory when configured with the highest-end M2 Max chip. By comparison, the previous models were available with up to 64GB of memory with the M1 Max chip. Memory bandwidth is unchanged at up to 200GB/s for the M2 Pro chip and up to 400GB/s for the M2 Max chip.
The notebooks can be configured with up to 8TB of SSD storage, which is unchanged from the previous generation.
The new MacBook Pro models support Wi-Fi 6E, which allows for faster wireless connectivity and lower latency over the 6GHz band. The previous 14-inch and 16-inch MacBook Pro models were limited to Wi-Fi 6, which operates over the 2.4GHz and 5GHz bands.
An upgraded HDMI 2.1 port on both new MacBook Pro models supports one external display with up to 8K resolution at 60Hz, or 4K resolution at 240Hz.
spcav
18 August 2006
16,643
Τα απολυτως αναμενομενα.
Καλό το HDMI 2.1.
To WiFi 6E καλό αλλά με ελαχιστη υποστηριξη σε router κλπ και ηρθε πολύ καθυστερημένα καθώς πλέον υπάρχει το 7.
Το 500αρι+ (χοντρικά) που θα εχει διαφορά από το υφιστάμενο (αφού αυτό βρίσκεται πλέον σε χαμηλότερες τιμές της επίσημης) δικαιολογείται μάλλον μόνο για αυτους που δουλευουν συστηματικά απαιτητικές εφορμογες video, όπου (κρίνοντας από τις διαφορες στα M1 vs M2 iPads) το M2 κανει ουσιαστική διαφορά.
ilias
9,150
Bratislava
Στα επισημα apple stores εχει αποσυρθει το Μ1 και το Μ2 εχει παρει 150 ευρω πανω για το βασικο 14ρι, στα 2.400 ευρω.
Σε μερικα "εξουσιοδοτημενα" apple stores (τυπου istorm) εχουν προσφορα το βασικο μοντελο 14" σε τιμες αμαζον, δηλαδη στα 1920 ευρω...
Μπαινεις σε σκεψεις...
Reactions: dimitris777
Looter
20 July 2008
1,629
Αστεία αναβάθμιση.
Αγγλία η βασική έκδοση πήρε 300 λίρες πάνω για το ίδιο προϊόν με πρόσχημα την ισοτιμία. Τα ίδια και χειρότερα θα συμβούν και Ελλάδα. Κοινώς τρέξτε να αγοράστε τα υπάρχοντα μοντέλα.
spcav
18 August 2006
16,643
Τοσα χρονια με macbook pro και πλεον σκεφτομαι ''αν ειναι να τα σκασω, δεν παω να παρω κανα Asus με τουμπανο oled οθονη, gpu που παιζει games κλπ;''
Προφανως γνωριζω (για να μην αρχισουμε τη γνωστη κουβεντα) τι δινει ενα macbook.
Για τη δικη μου ομως χρηση (αν και κατοχος όλων των συσκευων apple) το παραπανω περιορίζεται βασικά στην ποιότητα κατασκευής (και σε αυτή βάζω την κορυφαία αίσθηση του trackpad) και στην οθόνη.
Τωρα που ο ανταγωνισμός δίνει oled, ισως αναθεωρήσω.
Αστεία αναβάθμιση.
Αστεία δεν τη λες, απλό refresh είναι. Οι ανατιμήσεις (κλασικά) αφορούν την ευρωπαϊκή αγορά, εδώ στο Αμέρικα αν δεν κάνω λάθος παραμένουν ίδιες οι τιμές με πέρσι.
Μα το θέμα είναι τι κάνεις με το laptop. Προσωπικά θεωρώ το concept gaming laptop fail ως ιδέα και μόνο (αν θες παιχνίδια, πάρε ένα ωραίο ευάερο state-of-the-art πύργο, να τρέχεις απροβλημάτιστα, αθόρυβα, κυριλέ, και με μεγάλη οθόνη).
Το λαπτοπ χρειάζεται για μένα όλα αυτά στα οποία η Apple υπερτερεί. Φορητότητα, αυτονομία, εργονομία, και καλή συνεργασία με τα υπόλοιπα εργαλεία σου. Πιο εύκολα θα άλλαζα στρατόπεδο σε κινητό παρά σε laptop.
Reactions: takisot
22 June 2006
34,855
NEO HRAKLEIO
μια τυπικη αναβαθμιση εκανε, γι αυτο αλλωστε δεν υπηρχε και καποια παρουσιαση κλπ
Ιδιες τιμεςαμερικη, ευρωπη τα γνωστα καπελα!
ΥΓ... asus oled ειχα, μια χαρα ηταν, απλα η μπαταρια αστεια, αρκετος θορυβος οταν ζοριζοταν, η οθονη πολυ καλη (ο λογος που το τηπρα).
Δυστυχως για μενα που ηθελα και καλη οθονη, αλλα και αυτονομια χωρις θορυβο και ειδικα επιδοσεις και με μπαταρια μονο το macbook ειναι απαταιτητο.
Επειδη δεν το θελω για βασικο μηχανημα ομως, πηγα στο απλοι macbook air M2 που το βρηκα demo σε πολυ καλη τιμη.
Εχει ολα οσα θελω , σε πολυ ελαφρυ σωμα, καιμε τεραστια αυτονομια χωρις συμβιβασμους οταν το εχω με μπαταρια (σχεδον παντα δηλ.)
Looter
20 July 2008
1,629
Ξαναζεσταμένο φαγητό φίλε.
Το έχω το 16αρι εδώ και ένα χρόνο.
Παλιά δεν τα ανακοίνωναν ΚΑΝ όταν έκαναν μόνο αναβάθμιση στον επεξεργαστή λόγω παλαιότητας. Τώρα όχι μόνο το παρουσιάζουν ως νέον προϊόν (εδώ γελάμε) αλλά βρίσκουν και ευκαιρία να βάλουν το καπελο στην τιμή.
Μην επικροτείς τακτικές ληστρικών αυξήσεων στις τιμές για να τα παίρνουν φθηνά τα αμερικανακια.
Ειδικά στο θέμα λαπτοπ πλέον υπάρχουν ΠΟΛΛΕΣ ενστάσεις καθώς ο ανταγωνισμός παίζει με 13η γενιά Intel με efficiency cores , OLED οθόνες αφής , πλήρη συμβατότητα εφαρμογών που 2 χρόνια μετα την κυκλοφορία του Μ1 ακόμα περιμένουμε έχοντας πληρώσει ΗΔΗ το premium.
vadergr
17 August 2007
27,536
Μεταμορφωση
Για να συγκρίνεις με MacBook pro λογικα είχες κανένα studio art, ZenBook pro η zephyrus.
Όλα θεωρούνται εκπληκτικά μηχανήματα που ανταγωνίζονται και τα XPS.
Δεν γίνεται να είχες αστεία μπαταρία με δαυτα, και υποτίθεται ότι φοράνε και καλά ανεμιστηρακια.
Οκ, λογικό να μην έχουν το efficiency των νέων MacBook. Ειδικότερα αν δεν είχες πχ κανένα εντελώς πρόσφατο μοντέλο. :unsure:
takisot
Μέλος Δ.Σ.
27,911
Παλλήνη
Για παιχνίδια δεν είναι το MBP, προφανώς λόγω έλλειψης τίτλων όχι horsepower.
Μόνο και μόνο όμως για την καταπληκτική miniled οθόνη αξίζει πάντως. Δίνει σχεδόν εφάμιλλα μαύρα με oled σε θέαση video content, με πολύ υψηλότερη φωτεινότητα και μάλιστα sustained στα 1000 nits με peak στα 1600 σε HDR. Σε αυτά πρόσθεσε την αθόρυβη λειτουργία, το ότι δεν ζεματάει και την απίθανη αυτονομία.
Η έξυπνη αγορά είναι όντως να πάρεις το περσινό μοντέλο. Έτσι κι αλλιώς είναι τούμπανο.
22 June 2006
34,855
NEO HRAKLEIO
ειναι αρκετοι λογοι που το εδωσα... τα εχω ξαναπει.
Δεν εχουν ακομα λυσει τα θεματα αυτονομιας , θορυβου και επιδοσεων με μπαταρια τα pc laptop, ακομα κια με τα τελευταια chipchet.
ειναι φυσικα που ηθελα για επαγγελματικους λογους και καποια προγραμματα οπως το fcpx , mοtion κλπ
22 June 2006
34,855
NEO HRAKLEIO
πιο ενδιαφερο παντως για οποιον θελει σταθερο υπολογιστη αθορυβο, μικρο και οικονομικο σχετικα, το νεο mac mini στα 600$ , Ελλαδα φανταζομαι γυρω στα 700.
Ειδικα το mac mini pro Μ2 θα ειναι θηριο.
vadergr
17 August 2007
27,536
Μεταμορφωση
Το απλό το M1 με τα 8gb ram λες?
22 June 2006
34,855
NEO HRAKLEIO
αν εννοεις πιο mac mini, οχι το νεο λεω... 599% mac mini M2, εριξε τη τιμη κατα 100$ !
Aν θελεις βεβαια καλυτερες επιδοσεις , μνημη , δισκο κλπ πας στο M2 pro mac mini sta 1299$.
karamela
6 November 2013
10,731
Τα macbook αδιάφορα για εμένα. Αλλα χάρηκα πολύ με το Mac mini!!! Ειδικά το απλό είναι απίστευτο VFM, και με τον νέο M2 Και 100$ κάτω στην τιμή!!! Δεν το πιστευω αυτό που έκανε η Apple!!!
Βέβαια το Mini με τον M2pro όλα τα λεφτά!!
Επειδή έχω το απλό Mac mini με τον M1, ξέρει κανείς έτσι χοντρικά να μας πει πόσο στην πράξη αναβάθμιση είναι ο Μ1 Vs M2 Και κυρίως πόση διαφορά έχει με τον M2 pro? Σκέφτομαι να δώσω το M1 Mac mini και να πάρω ή το Mac mini Μ2 ή το Mac mini m2pro ανάλογα φυσικά και αν έχει αισθητή διαφορά σε επιδόσεις γιατί έχει και σημαντική διαφορά στην τιμή.
Υ.Γ. Να το ξαναπώ το απλό Mac mini με τον M2 ειδικά στην Αμερική που το δίνει 599$ είναι ο καλύτερος VFM υπολογιστής στην αγορά!!
22 June 2006
34,855
NEO HRAKLEIO
αν εχεις το M1 δεν εχει τοσο νοημα η αναβαθμιση.
Τα νεα προιοντα με M2 ειναι πιο πολυ γι αυτους που εχουν ακομα intel μηχανηματα.
Αυτο που ειδα εγω ειναι ενα 20% περιπου βελτιωση, οχι κατι σημαντικο στο macbook air m2.
αν ειναι ν αλλαξεις , μονο στο mac mini M2 pro.... αλλα ξεφευγει λιγο η τιμη φυσικα.
ΥΓ... στην Αμερικη αν βαλεις και το student discount παει στα 499$, τρομερο VFM.
karamela
6 November 2013
10,731
Ευχαριστώ Γιάννη, είναι τόσο μικρή η χρηματική διαφορά αν δώσω το Mac Mini M1 για να πάρω M2 που έστω και αυτό το 20% νομίζω ότι αξίζει, το M2 Pro σίγουρα είναι καλύτερο απλά δεν ξέρω αν αξίζει τα 1.400+ ευρώ που θα έρθει εδώ στην Ελλάδα.
Υ.Γ. Ισώς πάρω το mac mini M2 και απλά κρατήσω και το mini M1 για τα παιδιά, είναι τόσο φτηνό πλέον που δεν ξέρω αν έχει νόημα να το πουλήσω!!
