Δοκιμή του PS3 σαν Blueray player !
Μιχάλης Κορ.
21,476
Πειραιάς
Το PS3 είναι εκτός από μια πολύ καλή παιχνιδομηχανή κ ένα πολά καλό blueray player. Αυτό τουλάχιστον επιβεβαιώνει το UltimateAV στην δοκιμή που έκανε...!!!
Το πλήρες κείμενο είναι εδώ :
http://www.guidetohometheater.com/hddiscplayers/1206ps3blu/index.html
Αποσπάσματα από την δοκιμή :
"Also of interest to home theater buffs is that Sony has included full 7.1-channel support for Dolby's lossless TrueHD codec, in addition to Dolby Digital and DTS. The PS3's platform is fully upgradeable and it's possible that support for DTS' lossless audio coding, DTS-HD Master Audio, could be added later.
The PS3 will output 720p, 1080i, or 1080p when it is native on a Blu-ray Disc or a video game. It can also downconvert from 1080p to 1080i if your display cannot accept 1080p. But it cannot downconvert 1080p to 720p, and it does not have the ability to upconvert lower resolution discs to 720p, 1080i or 1080p. Even when I manually selected 720p or 1080p as the output format, the PS3 would output only 480p with standard definition DVDs.
The PS3 also rocks with startup speed, disc load speed and disc access during playback. In other words, it's ergonomically very Sony. Inserting discs with the PS3 powered down, it took less than ten seconds, at most, to boot to the menu of either a DVD or a 50GB BD, either of which the PS3 does automatically.This ergonomic performance is a far cry from the more expensive Samsung BD-P1000 standalone BD player, which still takes around 30 seconds to load a BD menu, or the Toshiba first-gen HD DVD players, which can take closer to a minute to load a disc.
The PS3 unequivocally earns its keep as a BD player for a home theater environment.
Compared to Samsung's BD-P1000 and (briefly) Sony's BDP-S1 as BD players, the PS3 is superior in absolute picture quality to the former, and more than holds its own with the latter. And it kills both in terms of startup and disc access speed and overall ergonomic prowess and stability. It's just bullet proof, and aside from being the coolest looking piece of gear ever, it's the only next-gen player so far that behaves like one in every respect.
techie
1,131
Ναι αλλα προς το παρον blueray discs μονο σε 1080p,1080i δεν μπορει να κανει downconvert σε 720p
και στα sd dvd δεν κανει upscale
=silent=
2 August 2006
11,100
Homeless
Εγω παντος που ειχα 1 PS2 και εβλεπα dvd οταν πειρα 1 κανονικο dvd ειδα τεραστια διαφορα στην εικονα. Εχω την εντυπωση οτι το Playstation 3 δεν μπορει να συγκριθει με 1 απλο blu-ray player. Προσφερουνε πολλα με αυτη την κονσολα αλλα δεν νομιζω οτι μπορει να συναγωνιστει τους υπολοιπους
Μιχάλης Κορ.
21,476
Πειραιάς
Δεν ξέρω αν μπορεί να συγκριθεί με κάποιο καλό blueray μηχάνημα αλλά τώρα που μιλάμε, το έκανα δοκιμή όπως γράφουν κ παίζει πάρα μα πάρα πολύ καλά ! Επίσης μπορεί να μην κάνει downconvert -> 720p αλλά προσωπικά δεν με πειράζει καθόλου. Τέλος το upconverting των απλών dvd δεν το κάνει αλλά γιατί να το κάνει άλλωστε ? Δεν είναι αυτή η δουλειά του. Η δουλειά του είναι να είναι παιχνιδομηχανή. Έχει όμως κ το πλεονέκτημα να είναι blueray μηχάνημα που μάλιστα είναι κ πολύ καλό. Μέχρι εκεί λοιπόν κ δείχνεί ότι με 600 περίπου ευρώ συνδυάζεις κ τους 2 κόσμους πάρα πολύ καλά.
@silent: φίλε μου μην συγκρίνεις το ps2 με το dvd γιατί πολύ απλά έβλεπες από πολύ κακό σήμα που ήταν το s-video που έβγαζε το ps2. Συν ότι είναι πολύ παλιό μηχάνημα το ps2...
takisot
Μέλος Δ.Σ.
27,870
Παλλήνη
Παντως τα παραπανω νομιζω οτι μπορουμε να τα επιβεβαιωσουμε οσοι ειμασταν στο σπιτι του Νανοπουλου και μεταφεραμε τις πρωτες μας εντυπωσεις εδω: http://www.avclub.gr/forum/showthread.php?t=5623
Πραγματικα το μηχανακι ως BR πηγαινε "σφαιρα" απο πλευρας ταχυτητας και η εικονα του ηταν πολυ καλη και σαφως καλυτερη τουλαχιστον απο το samsung BR που ειχα δει.Λιγο η κινησουλα του ειχε περιθωρια βελτιωσης αλλα αυτο μπορει να ηταν και το 3:2 pulldown λογω 24 fps της ταινιας σε 60hz display.
GeonX
2,755
…πάντως δυο στα δυο test να λένε το ίδιο πράγμα μάλλον έχουμε θέμα…και στο παλιότερο thread http://www.avclub.gr/forum/showthread.php?t=5458 που είχα ανοίξει για τη σύγκριση PS3 με Blu-Ray players ο reviewer έγραφε…
by Al Griffin SOUND&VISION on line....
QUOTE Getting back to our trio of Blu-ray Disc players, my personal favorite was the PlayStation 3. This machine's picture and sound quality were nothing short of stunning, and its HDMI 1.3 connection and built-in Dolby TrueHD decoding give it a layer of future-proofing that the other players currently lack. I also appreciated its multichannel Super Audio CD playback and 60-GB hard disk for storing compressed music files. And even though I don't have much use for the PS3's gaming capabilities, I definitely got a kick out of Resistance: Fall of Man. The PS3's $600 price — several hundred less than the others — also goes a long way toward making it the Blu-ray Disc player of choice. UNQUOTE
…τώρα να τα παίρνουν από τη Sony για να θάβουν το δικό της stand alone BD player μάλλον απίθανο οπότε…
