Βραχίονες: 9", 10" ή 12"?
Kostas P.
742
Οι uni pivot εχουν ρυθμιση azimuth.
Γι αυτον δεν ξερω.
Από το manual:
Lean, commonly called ‘azimuth’, is the extent
to which the cartridge leans towards the centre
of the record or away from it. Zero lean is
important for accurate playback and stylus/
record longevity. Lean can be adjusted by
shortening or loosing the left and right hoists
using the hoist spools.
Once the correct height is set, lean can be
adjusted by shortening and lengthening the two
hoists in equal and opposite measure so that the
pivot contact remains on the line between the
suspension points.
με τις ενδοτικότητες τι κάνει..
είδα μέχρι και κεφαλή με πάνω από 32cu να του φοράει.....
The magnetic counterweight attaches under the
thrust box and can be slid forwards and
backwards to adjust the downforce at the stylus
end. Take care to restrict movement of the arm
while adjusting the counterweight. Use the
supplied scale to set the required downforce.
An inertia ('effective
mass') adjuster is also included, so be sure to set
downforce after placing the inertia adjuster on
the arm in the desired position.
Adjusting the inertia to suit the cartridge
suspension is important. Compliant cartridges
need a less inert arm, and stiffer cartridges, a
more inert. Good results can be achieved by trial
and error, or by calculation. A nine-inch
Blackbird has an effective mass of around 10g
without the inertia adjuster.
Reactions: AUDIOLYTIC
vlad66
29 October 2017
15,230
Αγιοι Αναργυροι
🤔 .......... σου ειπα τι εγινε προχθες με τον rb250 ..............
Φανταζομαι θα εχει τροπο , με διαφορετικα armtubes ?
δεν νομίζω να το φτάνει μέχρι εκεί..
ή το πάει αλλιώς;;;;
θα διαβάσω το quote του Κώστα αργότερα.. δεν είμαι σε θέση τώρα... :LOL:
AUDIOLYTIC
13 August 2010
9,809
Νομιζω κατι παρομοιο σε σχεδιαση παρουσιασε ενα μελος του audiokarma forum.
Να το ψαξω και μολις το βρω θα δωσω το λινκ. Ειναι ενδιαφερον.
Reactions: vlad66
vlad66
29 October 2017
15,230
Αγιοι Αναργυροι
βάλε εδώ μια καλή φωτό του δικού σου με τον νέο πλίνθο.. εδώ θα είναι μεγάλη η φωτογραφία και θα το δω καλύτερα..
όλοι θα το δούμε δλδ.... :)
Kostas P.
742
Αυτόν εννοείς?
Ο μαύρος είναι ο Audiocraft, ο άλλος?
AUDIOLYTIC
13 August 2010
9,809
Ναι Κωστα αυτος ειναι. Προσφατα αναρτησε φωτογραφιες για την τελευταια του προσπαθεια, και λεει οτι ειναι ο καλυτερος που εφτιαξε ως τωρα.
Ο αλλος βραχιονας ειναι ο Denon DA-50 δεκάιντζος. Τον πηρα απο Ιαπωνια σε πολυ καλη τιμη .
Αψογος σαν δευτερος βραχιονας και τον πετυχα και σε αψογη κατασταση. Σαν καινουργιος ειναι.
Kostas P.
742
Απ' όσα καταλαβαίνω (όχι όλα) για την κατασκευή αυτού του είδους βραχίονα τα πιστεύω αυτά τα σχόλια. Ο Supatrac με ιντριγκάρει και η εμφάνιση του δε με χαλάει αλλά θα πάει με το τελωνείο κοντά στα 2000€ και υπάρχουν καλές και δοκιμασμένες επιλογές σε αυτό το ποσό.
Όντως σα καινούριος δείχνει, είσαι ευχαριστημένος? Έχω στο μάτι τους DA-401 & DA-402, έχεις εμπειρία με αυτούς?
AUDIOLYTIC
13 August 2010
9,809
Ναι ειμαι ευχαριστημενος με τον DA-50 , ιδιαιτερα για το λογο που τον πηρα. Ειναι μετριας μαζας ,οπου μπορω να χρησιμοποιω ορισμενες απο τις κεφαλες μου, αφηνοντας τις αλλες για τον audio craft.
O DA-402 ειναι πολυ καλος. Τον 401 δεν ετυχε να τον δοκιμασω, εχε υπ'οψιν οτι ναι μεν εχει αποσπωμενο headshell, αλλα ειδικου τυπου που ισως δυσκολα θα βρισκεις.
Ο DA-402 απο την αλλη, χρησιμοποιει το συνηθισμενο headshell οποτε θα εχεις απειρες επιλογες . O DA-402 ειναι 12 ιντζος.
Αυτο που σημερα θεωρειται top engineering, τοτε ηταν η απλη καθημερινοτητα των πλειστων Ιαπωνων.
Αυτο που τοτε θεωρειτo top engineering, σημερα , ή απλα δεν υπαρχει , ή αν υπαρχει σε ελαχιστους βραχιονες, κοστιζει και φτανει μεχρι πενταψηφια νουμερα.
Kostas P.
742
Έχεις δίκιο σε όλα. Δεν είχα προσέξει τη λεπτομέρεια στον 401 παρότι έχω δει πολλές φωτογραφίες. Για τον 402 έχω διαβάσει πολύ θετικά σχόλια και εκτός headshell έχει και την επιλογή armtube.
Kostas P.
742
Έχει κανείς εμπειρία με τους βραχίονες της Dynavector? Tα μοντέλα είναι οι 501, 505, 507 και 507 ΜΚ ΙΙ απ' όσο γνωρίζω.
Kostas P.
742
RIGID FLOAT tonearm​
Άλλος ένας εξεζητημένος βραχίονας Γιαπωνέζικης κατασκευής που παράγεται (με δικό του headshell) σε τρεις εκδόσεις: 7", 9" και 13 ιντσών. Απ' ότι διάβασα ο κατασκευαστής θεωρεί ότι ο ίσιος βραχίονας δε χρειάζεται antiskate setup. Κουνάει πολύ όμως...
Κοστολόγηση high end φυσικά
Για όσους έχουν όρεξη για διάβασμα
Kostas P.
742
Τον έχω υπόψην, αν κατάλαβα καλά έχουν ιστορία, είναι η εταιρεία που κατασκευάζει για την Dynavector τους Dynavector βραχίονες. Καινούριος είναι εκτός budget μου, μεταχειρισμένος στην Ευρώπη δύσκολα βρίσκεται. Αντίθετα οι Dynavector είναι πιο διαδεδομένοι δεύτερο χέρι και οι πρώτες εκδόσεις είναι πιο προσιτές οικονομικά. Τα λίγα σχόλια που έχω διαβάσει για τους Sorane είναι καλά αλλά όχι τα συνήθη ενθουσιώδη σχόλια. Πάντως οι Sorane - Dynavector λόγω των ρυθμίσεων τους φαίνονται σαν βραχίονες που μπορούν να υποστηρίξουν σχεδόν όλων των τύπων τις κεφαλές
