Τεχνολογικά νέα, ανακοινώσεις .....από τη Sigma
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Καλά ας βγάλει για εσάς. ;)
Εγώ να πω την μαύρη μου αλήθεια την Tamron περιμένω περισσότερο ειδικά με τα ζουμακια 35-150 f2-2.8
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Καλα ενταξει.....
Dear SIGMA customers,
First of all, thank you very much for your continued support and interest in our products.
SIGMA would like to share the development status of the three-layer image sensor as of February 2022 by the following.
The development of the three-layer image sensor is currently underway with the strong leadership of SIGMA’s headquarters in collaboration with research institutes in Japan. The stages of development can be roughly divided into the following:
  • Stage 1: Repeated design simulations of the new three-layer structure to confirm that it will function as intended.
  • Stage 2: Prototype evaluation using a small image sensor with the same pixel size as the product specifications but with a reduced total pixel count to verify the performance characteristics of the image sensor in practice.
  • Stage 3: Final prototype evaluation using a full-frame image sensor with the same specifications as the mass products including the AD converter etc…
    We believe that these three stages are necessary in the development, and we are currently in the process of creating the prototype sensor for Stage 2.
Based on the evaluation results of the prototype sensor, we will decide whether to proceed to Stage 3 or to review the design data and re-prototype “Stage 2”. When we proceed to Stage 3, we will verify the mass-producibility of the sensor with research institutes and manufacturing vendors based on the evaluation results, and then make a final decision on whether or not to mass-produce the image sensor.
Although we have not yet reached the stage where we can announce a specific schedule for the mass production of the image sensor, we are determined to do our best to realize a camera that will truly please our customers who are waiting for it, as soon as possible.
Once again, I would like to thank all of you for your continued support of SIGMA.
We will continue to strive for technological development to meet your expectations and trust.
Kazuto Yamaki
Chief Executive Officer, SIGMA Corporation
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Πρωτη φορα τον βλεπω τοσο σκασμενο τον Υamaki.
Δεν ειναι και λιγο βεβαια τοσο συνεχιζομενη αποτυχια.
Αναρωτιεμαι γιατι δεν συμβιβαστηκαν καπως και να αφησουν το FF για χαρη του s35 oπως ηταν η SD1
Πιθανολογω γιατι μαλλον βαθια μεσα τους ηθελαν να εισαγουν τον αισθητηρα στην κινηματογραφηση μαλλον.....
Τι ωραια που θαταν παντως να υπαρχει καμερα που να μπορεις να αλλαζεις αισθητηρα αναλογα την χρηση ( οπως καναμε στο film era)
Θες το καλυτερο pixel resolution και καλυτερη χρωματικη αναπαραγωγη ? Βαζεις εναν Foveon.
Θες εξαιρετικο high iso ? Βαζεις εναν Bayer.
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
1η Ιουνιου νεα προιοντα με πιθανοτερο τον 16-28 DG DN ως ευρυγωνιο ταιρι του νορμαλ ζουμ
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Mετα απο αρκετο καιρο και ενω στην γκαμα των superfast φακων για mirroless εχει εως τωρα 2 35αρηδες τον 85αρη και τον 105 μακρο η Sigma ετοιμαζει δυο ευρυγωνιους
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Reactions: evanfotis
evanfotis
26 March 2008
5,502
Άντε να δούμε μια fp, με Flippy screen, foveon sensor να γράφει βίντεο cdng...
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Γιαμακι μην τα παρατας συνεχισε στο τελος θα σου ανοιξουν την πορτα ( ή θα τελειωσουν τα χρονια πατεντας και θα ελευθερωθει και το RF ) :ROFLMAO:
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Reactions: kbouk
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
In an interview with Imaging Resource, Yamaki stated that the global chip shortage has largely been the only thing that was holding Sigma back from the X3 going into production.
Fortunately for SIGMA, the company had managed to have its own production system and as such, supply chain issues have been kept to a minimum.
“Our partner is now making the prototype. As you know, semiconductor makers are extremely busy right now. So there’s been a little bit of delay.
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Reactions: gpapjohn
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
Να και η Sigma για Ζ μοντουρα....να δουμε και αν θα βγαλουν ολους τους τους φακους οι δυο μεγαλοι sigma και tamron για την Νικον (γιατι για την fuji το πανε πολυ πολυ σιγα)
kbouk
8 January 2010
22,818
ΠΕΙΡΑΙΑΣ
Βρε λετε ο Γ. Σπύρου να είναι τυχερός και να ξεκινήσουν την εισοδο στους Ζ με κανενα τηλεφακό ? :)
ο 60-600 προσαρμοσμένος να αποδίδει ριπές, max ταχύτητα κλπ. απευθείας στην μοντουρα Ε και L θα δώσει μεγάλη ωθηση στα δυο συστήματα και θα καλύψει με σχετικά χαμηλή τιμή ένα σημαντικό κομμάτι αγοράς
Kosh
7 September 2006
92,014
Εκεί ψηλά.....
αντε παλι..... περσι τετοια εποχη παλι ευχες εκανε ;)
