Εχω 5 ηχεια απο ενα παλιο στερεοφωνικο της Sony και θελω να αγορασω εναν ενισχυτη, συγκεκριμενα τον Cav avr-8 http://www.alifragis...?prod_id=AVR-8.
Τα ηχεια και ο ενισχυτης εχουν τα παρακατω χαρακτηριστικα,θα αντεχουν στον ενισχυτη αυτον η παιζει να τα καψω?
Ενισχυτης:
Ηχεια2 ηχεια front+ 3 ηχεια rear)
Front Speaker (SS-NX1)
Speaker system 2-way, bass-reflex type,
magnetically shielded
type
Speaker units
Woofer: 17 cm (63/4 in.), cone type
Tweeter: 2.5 cm (1 in.), dome type
Nominal impedance 6 ohms
Dimensions (w/h/d) Approx. 210 x 402 x 285
mm (83/8 x 157/8 x 111/8
in.)
Mass Approx. 7.0 kg
(15 lb 7 oz) net per
speaker
Centre/Rear Speaker (SS-RC100)
Speaker system 1-way, 2-unit,
bass-reflex type
Speaker units
Full-range: 8 cm (31/4 in.), cone type
Nominal impedance 8 ohms
Dimensions (w/h/d) Approx. 225 x 95 x 95 mm
(91/8 x 33/4 x 33/4 in.)
Mass Approx. 1.5 kg
(3 lb 5 oz) net per speaker
Ο παλιος ενισχυτης της sony που ηταν πανω τα ηχεια ειχε τα εξης χαρακτηριστικα(δεν ξερω αν βοηθανε)
Front Speaker:
DIN power output (rated) 90 + 90 watts
(6 ohms at 1 kHz, DIN)
Continuous RMS power output (reference)
110 + 110 watts
(6 ohms at 1 kHz,
10% THD)
Music power output (reference)
180 + 180 watts
(6 ohms at 1 kHz,
10% THD)
Center Speaker:
DIN power output (rated) 25 watts
(8 ohms at 1 kHz, DIN)
35 watts
(8 ohms at 1 kHz,
10% THD)
70 watts
(8 ohms at 1 kHz,
10% THD)
Rear Speaker:
DIN power output (rated) 25 + 25 watts
35 + 35 watts
(8 ohms at 1 kHz,
10% THD)
70 + 70 watts
(8 ohms at 1 kHz,
10% THD)
Ενισχυτης:
- Dolby Digital 5.1, Pro-logic II, DTS 5.1 & PCM decoding
- AM/FM tuner with RDS display
- Multiple Audio & Vidio Input / Output
- Karaoke system
- Stereo: 78 W x 2 ( 8 Ohms)
- 5.1 Ch: 72 W x 5 ( 8 Ohms) / 110W x 5 ( 4 Ohms)
- Audio Input / Output: Optical(4/1) , Coaxial(4/1) , RCA Input (4/1), 5.1CH (1/1)
- Video Input / Output: S - Video(4/1), Component Video (4/1), Analog Video(4/1)
- Frequency Response: 20 Hz-20 KHz ( + 1dB , - 3dB )
- S/N Ratio: ≥80 dB
- T.H.D.: ≤0.2%
- Net Weight: 11.5 kg
type
Speaker units
in.)
Mass Approx. 7.0 kg
speaker
bass-reflex type
Speaker units
Mass Approx. 1.5 kg
Front Speaker:
110 + 110 watts
(6 ohms at 1 kHz,
10% THD)
180 + 180 watts
(6 ohms at 1 kHz,
10% THD)
Center Speaker:
35 watts
(8 ohms at 1 kHz,
10% THD)
70 watts
(8 ohms at 1 kHz,
10% THD)
Rear Speaker:
35 + 35 watts
(8 ohms at 1 kHz,
10% THD)
70 + 70 watts
(8 ohms at 1 kHz,
10% THD)
