Τελικά πήρα την Σόνυ από mediamarkt.
Υπάρχουν κάποιες υποτυπώδες ρυθμίσεις να δω εδώ μεσα ,η να ψάξω youtube;
Ευχαριστώ παιδιά.
Cognitive Processor XR 2nd gen
Συμβατότητα HDR formats: HDR10,HLG,TV-led Dolby Vision :yes
(HDR10+ : no)
Dolby Atmos,DTS,DTS:X via DTS-HD MA via eARC
SoC
Model: BRAVIA 4K VH21
MediaTek MT5895
Core Architecture:4x ARM Cortex-A73 @ 1800MHz
64-bit ARMv8-A (32-bit mode)
CPU Cores: 4
CPU Clock Range: 1200 - 1800MHz
Installed RAM : 3 GB
Available Memory: 935 MB
GPU Renderer : ARM Mali-G52 (Vulkan)
OpenGL ES version: 3.2
Total storage-On-board Storage : 16GB - expandable via USB
Internal Storage Total Space: 4185 MB
Internal Storage Free Space: 2112 MB
Dismantling Information for Use by Professional Recyclers...https://www.sony.com/electronics/su...3e8e33a4428c29c0a2367f316c1260a/98889044M.pdf
Αρχικές ενδεικτικές τιμές...https://avclub.gr/index.php?threads/sony-tv-line-up-2022.176330/post-1058770184
XR-85X95K - 6.700 €
XR-75X95K - 4.650 €
XR-65X95K - 3.600 €
Professional displays:
FWD-85X95K
FWD-75X95K
FWD-65X95K
Reviews - test :
75"...[hdtvtest.co.uk]...Sony XR-75X95K review
We review the Sony X95K Mini LED tv.
We also explain why Sony LED LCDs exhibit more blooming than competing Mini LED tvs from rival brands.
Our BRAVIA X95K review sample is the 75-inch version (model number Sony XR-75X95K) with 600 local dimming zones.
Spectral Power Distribution 75X95K,quantum dot enhancement film QDEF
Native ANSI blacks was 0.05 cd/m²(nits) if peak white was set at 119 cd/m²(nits) with local dimming disabled.
Native ANSI blacks was 0.026 cd/m²(nits) if peak white was set at 120 cd/m²(nits) with local dimming enabled (medium).
DCI-P3uv colour gamut coverage : 96%
Rec.2020 colour gamut coverage : 75.7%
HDR: Peak Brightness on a 10% window: 1992 cd/m²,nits , after calibration to D65 white point,
Full-field: 701 cd/m²,nits
Sony XR-65X95K από Digital Trends...https://www.digitaltrends.com/tv-reviews/sony-bravia-x95k-mini-led-tv-review/
65"...[lesnumeriques.com]...Sony XR-65X95K review...https://www.lesnumeriques.com/tv-televiseur/sony-xr-65x95k-p66983/test.html
VA panel (RGB,vertical stripe,8 domain) + viewing angle compensation film + antireflection filter
Οι ρυθμίσεις είναι μόνο για αναφορά.
Δεν υπάρχει καμία εγγύηση ότι θα σας δώσουν την καλύτερη εικόνα που είναι σύμφωνη με τα πρότυπα της βιομηχανίας και κατάλληλη για το περιβάλλον προβολής σας (ειδικά ισορροπία λευκού, ρυθμίσεις συστήματος γάμμα και χρώματος που διαφέρουν από μονάδα σε μονάδα).
Εάν θέλετε μια εγγυημένη βαθμονομημένη εικόνα, καλέστε έναν επαγγελματία βαθμονομητή τηλεόρασης.
Our settings and measures:
We set the Sony Bravia XR-55A95K television to User mode ,
then lowered the brightness to 11 in order to obtain a white close to 150 cd/m² in SDR.
For HDR content, it is advisable to keep the brightness at maximum to enjoy the content.
Regarding the MotionFlow motion compensation engine, Expert mode limits motion blur while maintaining the 24 fps cinema rate.
Finally, don't forget to unclamp the HDMI ports (Channels and inputs > External inputs > HDMI signal format > Enhanced format).
65"...[flatpanelshd.com]...Sony XR-65X95K review...https://www.flatpanelshd.com/review.php?subaction=showfull&id=1655879889
mini-LED FALD Direct LCD
we counted 36 dimming zones horizontally and 12 vertically for a total of 432.
Calibration settings:
Note: We include calibration settings only for SDR, not HDR. For our calibration we have deactivated the ambient light sensor that automatically adjusts the backlight setting according to your environment. You may prefer to have it enabled.
65"...[rtings.com]...Sony XR-65X95K review...https://www.rtings.com/tv/reviews/sony/x95k
65X95K calibration settings...https://www.rtings.com/tv/reviews/sony/x95k/settings
65"...[hdtvpolska.com]...Sony XR-65X95K review...https://hdtvpolska.com/test-recenzja-telewizor-sony-x95k-mini-led-opinie-cena/?showfull=1
65"...[xataka.com]...Sony XR-65X95K review...https://www.xataka.com/analisis/sony-x95k-analisis-caracteristicas-precio-especificaciones
65"...[fwd.nl]...Sony XR-65X95K review...https://fwd.nl/beeld/review-sony-xr-65x95k-x95k-serie-lcd-led-tv/
65"...[dday.it]...Sony XR-65X95K review...https://www.dday.it/redazione/43776/recensione-tv-mini-led-sony-bravia-xr-x95k-review-prova
65"...[hifi.de]...Sony XR-65X95K review...https://hifi.de/test/sony-x95k-test-112695
65"...[geex.x-kom.pl]...Sony XR-65X95K review..https://geex.x-kom.pl/recenzje/test-i-recenzja-sony-65x95k/
The tv was produced in May 2022, and a test copy was provided by the manufacturer himself.
VA panel + viewing angle compensation film
Direct backlighting
FALD mini LED LCD
100/120Hz με MCFI
Wide colour gamut DCI-P3 (CIExy) space coverage : 94%
During the test, I identified 36 zones horizontally and 12 vertically, for a total of 432 independent zones.
Another advantage of Sony 65X95K is the brightness in full-screen mode, which amounted to 728 cd/m² (nits).
Therefore, the light conversion takes place not on the diode, but outside it (in the so-called QDEF foil).
In short, in the 2022 TV range, Sony has... "QLED TV". And, of course, he keeps this fact a secret.
It is important to keep in mind that any multi-zone backlight is a compromise and will never show 100% of the image intended by the creator.
Designers must choose whether they prefer deep blacks or maintaining the original brightness.
Sony chose the latter option.
I respect this choice and I am aware of the advantages of this solution.
On the other hand, I also saw rivals who in their algorithms put on deep blacks at the expense of reducing the original brightness.
As I have already mentioned, no solution is perfect and will have its supporters and opponents.
Of course, OLED tvs are a way out, but they also get short of breath in bright scenes, not to mention losing details in the shadows.
Who knows, perhaps the solution would be for Sony (as well as competitors) to add an additional option in the menu, which would indicate to algorithms what the viewer prefers.
I mean:
65"...[clubic.com]...Sony Bravia XR-65X95K test...https://www.clubic.com/pro/entreprises/sony/test-produit-440724-test-sony-xr-65x95k.html
65"...[audiovision.de]...Sony XR-65X95K test...https://audiovision.de/sony-xr-65x95k-test/
Ευχαριστώ παιδιά.
(HDR10+ : no)
SoC
MediaTek MT5895
CPU Cores: 4
XR-85X95K - 6.700 €
XR-75X95K - 4.650 €
XR-65X95K - 3.600 €
FWD-85X95K
FWD-75X95K
FWD-65X95K
Reviews - test :
Group | Setting | Value |
Profile | Custom | |
Auto Picture mode | Off | |
Ambient Light sensor | On/Off | |
Brightness | Brightness | 6 (for 120 nits) Higher for bright rooms |
Contrast | 90 | |
Gamma | -2 | |
Black level | 50 | |
Black adjust | Off | |
Adv contrast enhancer | Off | |
Auto local dimming | Medium | |
Peak luminance | Off | |
Color | Color | 50 |
Hue | 0 | |
Color temperature | Expert1 | |
Live Color | Off | |
Adv color temp | R-gain | Max |
G-gain | -5 | |
B-gain | -4 | |
R-bias | 3 | |
G-bias | -2 | |
B-bias | -1 | |
Clarity | Sharpness | 50 |
Reality creation | Off | |
Random noise reduction | Low / Off | |
Digital noise reduction | Off | |
Smooth gradation | Low / Off | |
Motion | MotionFlow | Off / Custom |
Smoothness | 1 / Min | |
Clearness | Min | |
Video signal | HDR Mode | Auto |
HDMI video range | Auto | |
Color space | Auto |
Direct backlighting
FALD mini LED LCD
100/120Hz με MCFI
- in its history, Sony has offered tvs with a higher number of zones – for example, the excellent 65ZD9 model from 2016 had as many as 646.
I mean:
- Preserving the original brightness (luminance preference);
- Black Preference.
