-Sony TV Line-up 2019-
xavito
29 October 2008
8,989
65"...[lcdtvthailand.com]...Sony KD65A8G review...https://www.lcdtvthailand.com/revie...ายิ่งกว่าเดิม-ด้วยราคาเปิดตัวต่ำกว่า-A8F.html
μετάφραση google th to en
Sony_65A8G_SDR (Standard Dynamic Range)_Table
Sony_65A8G_HDR10_pre calibration data
source photo:[lcdtvthailand.com]
xavito
29 October 2008
8,989
We saw the 110-inch Sony Crystal LED (formerly known as CLEDIS) at the company's Basingstoke office, and learnt a bit about their take on MicroLED self-emissive technology which is capable of delivering 1000 nits of peak brightness full-screen.
Various turnkey packages of the Sony Crystal LED Display can be ordered through AWE Europe, a UK distributor:
http://www.awe-europe.com/
Due to the nature of many Crystal LED purchases, the pricing can vary in relation to other project factors and requirements, but here are some guide prices:
146-inch: 350,000 Euros
182-inch: 500,000 Euros
219-inch: 700,000 Euros
https://www.youtube.com/watch?v=YaChI1WNG2M
source video:[youtube.com - hdtvtest.co.uk]
Micro-LED: Sony...https://www.lesnumeriques.com/tv-te...nt-du-samsung-the-wall-en-europe-n138981.html
μετάφραση google fr to en
34094127-micro-led-sony-vend-son-crystal-led-concurrent-du-samsung-the-wall-en-europe__w800.jpeg
21d0e2f2-micro-led-sony-vend-son-crystal-led-concurrent-du-samsung-the-wall-en-europe__w800.jpeg
source:[lesnumeriques.com]
STELIOS
27 August 2006
2,072
απλησιαστες τιμες !!
papasouzakias
13 May 2009
4,523
Από το 2027 θα αρχίσουμε να βλέπουμε μια κάποια αύξηση των πωλήσεων microled για οικιακή χρήση αφού τότε προβλέπεται να πέσουν σε πιο προσιτά επίπεδα οι τιμές τους.
xavito
29 October 2008
8,989
85"...[lesnumeriques.com]...Labo - Sony KD85ZG9 ...https://www.lesnumeriques.com/tv-te...ny-kd-85zg9-pic-luminosite-record-n87503.html
...The player uses four HDMI outputs and Sony uses a converter that can convey the 8K stream 60 fps through a single HDMI cable.
Finally, this TV is the first to our knowledge to accept an 8K signal using a single HDMI cable unlike Sharp 8K LV-70X500E. As usual at Sony, you must first unblock the HDMI port in question, in this case the HDMI 4 port, in the Settings> Watch TV> External Inputs> HDMI Signal Format> Enhanced Format.
Sony used for the occasion an 8K player with four HDMI 2.0 outputs and a converter box that allows just to couple the flow of the four outputs and send back to the TV with a single HDMI cable supporting a high bandwidth. Sony is not yet talking HDMI 2.1 input, because the standard is not yet fully finalized, but Sony - with this demonstration - ensures that its TV will be compatible with 8K streams.
JL_?
19 September 2008
15,415
Terra
Why is Dual Panel LCD vs OLED a Hot Topic?...https://www.displaydaily.com/article/display-daily/why-is-dual-panel-lcd-vs-oled-a-hot-topic
source:[displaydaily.com]
We review Sony's new BVM-HX310 professional mastering monitor, which is the replacement for the Japanese brand's now-discontinued X300 reference OLED monitor.
We found the Sony HX310 to be the first LCD display we've tested that can compete with OLED on picture quality, thanks to dual-layer LCD or light-modulating cell layer (LMCL) technology. List price is at least £30,000.
We understand that the Hisense U9 and the upcoming Apple Pro Display XDR 6K monitor will also be using dual-layer LCD technology, although not the exact same one found on the BVM-HX310.
Footages at 2:15 and 2:52 are blurry due to wide lens aperture used to capture dark detail.
https://youtu.be/7Ee74qdPcmY
source video:[hdtvtest.co.uk]
Κάτι περίεργο συμβαίνει με τις μετρήσεις του πάντως...
25000:1 αντίθεση σε SDR και 125000:1 σε HDR; Γιατί αυτή η διαφορά και γιατί δεν του έκανε καμμιά εντύπωση;
xavito
29 October 2008
8,989
49"...[lesnumeriques.com]...Sony KD49XG9005 test...https://www.lesnumeriques.com/tv-televiseur/sony-kd-49xg9005-p51511/test.html
KD49XG9005: VA panel,true 4Κ UHD RGB -vertical stripe,F.A.L.D. LCD (with PFS LED backlight),100/120Hz με MCFI+αναβόσβησμα του οπίσθιου φωτισμού,WCG (aka Triluminos Display)
a03c846e-sony-kd-49xg9005-le-meilleur-televiseur-de-moins-de-50-pouces-du-marche__w800.jpeg
5007467c-sony-kd-49xg9005-le-meilleur-televiseur-de-moins-de-50-pouces-du-marche__w800.jpeg
e1c49af2-sony-kd-49xg9005-le-meilleur-televiseur-de-moins-de-50-pouces-du-marche__w800.jpeg
d1d69345-sony-kd-49xg9005-le-meilleur-televiseur-de-moins-de-50-pouces-du-marche__w800.jpeg
6440b12b-sony-kd-49xg9005-le-meilleur-televiseur-de-moins-de-50-pouces-du-marche__w800.jpeg
... In fact, it is identical to last year's Sony KD-49XF9005, with the exception of the design of the feet. The Sony 49XG9005 is also the only Sony TV with the reference XG90 in 2019, the other diagonals are stamped XG9505 and ship the X1 Ultimate processor...
xavito
29 October 2008
8,989
55"...[tvtest.pl]...Sony KD55AG8 test...http://www.tvtest.pl/sony-55ag8-test/
μετάφραση google pl to en
The matrix comes from LG Display and has the same sub-pixel structure as LG 55C9, LG 55E9, Sony 55AG9 or Panasonic 55GZ950.
https://www.youtube.com/watch?v=_bG1DKmXpVA
Short commentary on the chart:
starts at around 667 cd / m ^ 2,
after approx. 50-55s reaches 700 cd / m ^ 2,
then slowly drops to approx. 440 cd / m ^ 2 and stabilizes for 20 seconds,
then again it grows to about 700 cd / m ^ 2 ...
... to finally fall to about 300 cd / m ^ 2.
the whole measurement lasted 5 minutes.
As you can see, 55AG8 offers lower brightness in HDR mode than rivals, especially LG. What is the reason? It is hard to say, but it seems to me that since we are dealing with the same latest generation OLED panel, it may be Sony engineers' desire to protect the panel from burning out.
xavito
29 October 2008
8,989
Ενημέρωση υλικολογισμικού για τις τηλεοράσεις Android 2016 - 2019 της Sony - Από τις 27 Νοεμβρίου 2019...https://www.sony.gr/electronics/support/articles/00206881
Firmware update for Sony’s 2016 - 2019 Android TVs - Starting on 27th November 2019...https://www.sony.co.uk/electronics/support/articles/00206881
v6.6545
This update further builds on Android 8.0 Oreo, enhancing the TV’s performance and compatibility standards while improving on the existing functionalities:
Improves network connectivity with certain routers
Improves the stability and performance of the overall user interface
Improves compatibility with certain CAM modules and resolves issues with channel storage (Russia only)
[Applicable TV model series]
Sony’s 2016 Android TVs: XD70, XD75, XD80, SD80, XD83 and ZD9 Series
Sony’s 2017 Android TVs: XE80, XE83, XE85, XE90, XE93, XE94 and A1 Series
Sony’s 2018 Android TVs: XF75, XF80, XF83, XF85, XF87, XF90 and AF8 Series
Sony’s 2019 Android TVs: AG8, XG80, XG81, XG83 and XG90 Series
Προβλήματα ήχου σε συστήματα οικιακού κινηματογράφου με θύρα ARC σε τηλεοράσεις Android της Sony (μοντέλα 2016-2018) μετά την ενημέρωση Android 8.0 Oreo...https://www.sony.gr/electronics/support/articles/00223423
Γνωρίζουμε ότι μπορεί να έχετε προβλήματα με τον ήχο, μέσω της θύρας ARC που συνδέεται στην μπάρα ηχείων, το δέκτη A/V ή το σύστημα home cinema, όταν ενεργοποιείτε την τηλεόρασή σας από την αναμονή.
Εντωμεταξύ, δοκιμάστε τις παρακάτω λύσεις με αριθμητική σειρά. Αν τα συμπτώματα παραμένουν, συνιστούμε να χρησιμοποιήσετε την επόμενη λύση της λίστας.
ΣΗΜΕΙΩΣΗ: Ενεργοποιήστε την προτεραιότητα του ηχοσυστήματος, πριν να δοκιμάσετε τις παρακάτω λύσεις.
[HOME] > [Settings] (Ρυθμίσεις) > [Sound] (Ήχος) > [Audio system prioritisation] (Προτεραιότητα ηχοσυστήματος)
Λύση 1:
Απενεργοποιήστε τη συσκευή ήχου σας με το τηλεχειριστήριο ηχοσυστήματος
Απενεργοποιήστε την τηλεόρασή σας με το τηλεχειριστήριο τηλεόρασης
Ενεργοποιήστε την τηλεόρασή σας με το τηλεχειριστήριο τηλεόρασης
ΣΗΜΕΙΩΣΗ: Η συσκευή ήχου θα ενεργοποιηθεί αυτόματα μέσω της λειτουργίας BRAVIA Sync (HDMI CEC).
Λύση 2:
Αλλάξτε τις ρυθμίσεις των ηχείων με τις επιλογές [HOME] > [Settings] (Ρυθμίσεις) > [Sound] (Ήχος) > [Speakers] (Ηχεία) > [TV speakers] (Ηχεία τηλεόρασης)
Απενεργοποιήστε την τηλεόραση με το τηλεχειριστήριο τηλεόρασης
Ενεργοποιήστε την τηλεόραση με το τηλεχειριστήριο τηλεόρασης
ΣΗΜΕΙΩΣΗ: Οι ρυθμίσεις ηχείων θα αλλάξουν αυτόματα σε [Audio system] (Ηχοσύστημα) μέσω της λειτουργίας BRAVIA Sync (HDMI CEC).
Λύση 3:
Ενεργοποιήστε τον χειρισμό BRAVIA Sync από το μενού [HOME] > [Settings] (Ρυθμίσεις) > [External inputs] (Εξωτερικές είσοδοι) > [BRAVIA Sync settings] (Ρυθμίσεις BRAVIA Sync) > [BRAVIA Sync control] (Χειρισμός BRAVIA Sync)
Επιλέξτε [Yes] (Ναι) όταν εμφανίζεται η ένδειξη [Remove recognized devices from the list] (Κατάργηση αναγνωρισμένων συσκευών από τη λίστα)
ΣΗΜΕΙΩΣΗ: Ο χειρισμός BRAVIA Sync θα απενεργοποιηθεί.
Επιλέξτε ξανά το χειρισμό BRAVIA Sync για να τον ενεργοποιήσετε
ΣΗΜΕΙΩΣΗ: Οι ρυθμίσεις ηχείων θα αλλάξουν αυτόματα σε [Audio system] (Ηχοσύστημα).
Λύση 4:
Κάντε επαναφορά της τηλεόρασής σας
Απενεργοποιήστε την τηλεόραση.
Αποσυνδέστε το καλώδιο ρεύματος της τηλεόρασης (καλώδιο τροφοδοσίας) από την πρίζα.
Αφήστε την τηλεόραση χωρίς ρεύμα για 2 λεπτά.
Συνδέστε το καλώδιο ρεύματος (καλώδιο τροφοδοσίας) στην πρίζα.
xavito
29 October 2008
8,989
Sony rolls out AirPlay 2, HomeKit & Dolby Atmos as part of Android 9 update...https://flatpanelshd.com/news.php?subaction=showfull&id=1575352656
begin December 2019 ,
Applicable products:
2019:
XBR Z9G series
XBR A9G series
XBR X950G series
XBR X850G series (55/65/75/85 inches)
2018:
XBR Z9F series
XBR A9F series
New features and changes:
Adds Support for Apple AirPlay and Apple Homekit.
- With Apple AirPlay, you can stream movies, music, games, and photos to your TV right from your iPhone, iPad, or Mac computer.
Integrated Dolby Atmos support through the TV's built-in speakers.
- In addition, Sound mode compatible models will switch to Dolby Audio automatically so that you can enjoy Dolby Atmos content.
Pass through mode is added and allows the output of compressed audio to a home theater or soundbar.
Only 2018 models:
The Video, Album, and Music apps are combined with the Media Player app.
- Videos, photos, and music can now be viewed as a list in the Media Player app.
Adds support for High Efficiency Video Coding (HEVC) 100/120Hz format for USB video playback.
Only 2019 models:
Small screen for TV viewing on program guide
- While in the program guide, a small screen appears in the upper right corner to display the program you are watching
Illumination LED behavior when "Ok Google" is detected (except for XBR X850G/X855G/X857G models).
- The illumination LED blinks yellow if you say "Ok Google" when your TV is turned on or in standby mode.
source:[flatpanelshd.com - via sony.com]
