Sony KDL-32D3000 : Reviews - Εντυπώσεις - Σχόλια
Panini
1 December 2006
54
Re: sony 32 D3000 στις 10/06
εδω ειναι καποιες photo της 32D3000 απο το avforums μαζι με μια 42Χ2000 συνδεδεμενες κ οι δυο με PS3
-bye-
nilo
5 March 2007
1,482
Athens
Παντως οι πρωτες εντυπωσεις για την 32D3000 (απο το μελος του avforums που ποσταρε τις φωτο) ειναι αρκετα ενθαρυντικες.
Διαβαστε...
My first quick impressions were its silky smooth, whilst watching casino royale at 1080p the frame rate was lovely, out classing my 40 x every step of the way, although overall picture quality seemed better on the X, the D was very impressive to say the least. It has a load of options to mess about with,its got the same menu layout as the W series plus alot of added features . you can even crank the motion enhancer up , or even turn it off. Hdmi now has auto switching, and you can also search for hdmi devices to pair up with the sony theatre system. Theres lots of tweaking to be had which is allways a good thing.
The sound is good , but not amazing , my 26lxd70 in the bedroom has a deeper bassier sound, but the clarity seems ok. I've only listened to it on factory preset, ( by the way these are all quick impressions, its hard when you've got a nagging mrs) .
A major big point that most people will be interested in is There is NO clouding at all . Hopefully this Mira defect plague is now a thing of the past.
All in all a cracking set IMHO , this is the best 32" sony have produced so far. its on par if not better than Panasonics 32lxd700(picture that is). It certainly has alot more options than panasonics offering.
although a prefer the menu style of the panasonic. If you own a Ps3 and your in the market for a 32", this is where its at. say no more.
GeoGeoGeo
28 March 2007
3,498
Άντε άντε να ρθει και κατά δω....(από καταστήματα)
aime
14 April 2007
595
Paris
Αυτή η δωρικότητα της Sony πάντα μου άρεζε. Πάντα απλή στην εμφάνιση σε όλα τα είδη της. Στις φωτογραφίες δε δείχνει και τίποτα ιδιαίτερο , ιδίως το τηλεκοντρόλ είναι για παπούδες να βρίσκουν τα πλήκτρα!!! Μέσα όμως πρέπει να βρίσκονται τα διαμάντια...
Αντιθέτως η Philips είναι φοβερή στο σχέδιο, στα τηλεκοντρόλ, στις ευκολίες, αλλά άμα πάρεις φθηνή θα σου βγεί πολύ ακριβή με τις επισκέψεις....(με βάση το παρελθόν στις crt). Aκριβότερη και από την ακριβότερή της!!! ¨Ετσι νομίζω, μπορεί να άλλαξαν τα πράγματα μια και πλέον και οι δύο εταιρείες συναρμολόγιση πλέον κάνουν και software φτιάχνουν για να δουλεύουν οι οθόνες...
Γιώργος.Χ
23 June 2006
5,867
Αττική
Σχετικό είναι... Μην ξεχνάς οτι η Sony έχει ρίξει ολο το βάρος της στις τηλεοράσεις και στο Bluray και γιαυτήν είναι αγώνας επιβίωσης αφού αποτυχια θα ισοδυναμούσε με πολύ σοβαρά προβλήματα.....
Τώρα για ποιότητα κατασκευής ειναι λίγο λαχείο... και η Sony έχει αρκετές σαβούρες δυστυχώς και το κακο ειναι οτι το after sales support της στην Ελλάδα είναι εξισου κακό (ισως και χειρότερο από την Philips)
Γιώργος.Χ
23 June 2006
5,867
Αττική
Και τι διαμάντια 100Hz!!!!
Φιλε τα 100 Hz είναι τεχνολογία δεκαετίας και κακώς ενθουσιαζόμαστε τόσο πολύ λες και ξαφνικά θα μας δώσουν το Αγιο Δισκοπότηρο του HD.
Προσοχή στις αγορές και υπομονή.. Δεν χρειάζεται να επαληθεύουμε ολα τα μοντέλα καταναλωτικής συμπεριφοράς των απανταχού marketeers
GeoGeoGeo
28 March 2007
3,498
Γνωρίζω πως η τεχνολογία των 100Hz είναι δεκατίας.Όμως βοηθάει πολύ προς το καλύτερο την εικόνα στο σήματος της τηλεόρασης!
Γιώργος.Χ
23 June 2006
5,867
Αττική
To ϊδιο και τα 24fps αλλά δεν πήγαμε κατευθείαν εκεί... Γιατί άραγε ??
(Τυπική ερώτηση φαντάζομαι οτι την απάντηση την υποψιαζόμαστε όλοι)
Yperion
21 June 2006
43,515
BVR (Beyond Visual Range)
Tα τηλεκοντρολ η Philips τα εχει χαλασει πολυ. Αν δεις το τηλεκοντρολ στις νεες 42PFL76ΧΧ θα δεις τι εννοω.
Επισης τα 100 Ηz των LCD σαν τεχνολογια ειναι πολυ διαφορετικα απο τα 100 Ηz των CRT. Δεν ειναι τυχαιο οτι οι LCD 100 Ηz εμφανιζονται τωρα. Η τεχνολογια δεν ειχε ωριμασει νωριτερα.
Βασίλης 07
896
Απάντηση: Re: sony 32 D3000 στις 10/06
:blush:
Είμαι ανάμεσα σε Sony (D3000,V2500) και Samsung (Bordeaux LE32R86B) .Σε γνωστή αλυσίδα Π***ο λίγο πολύ μου παρουσίασαν ώς μεγάλο μειονέκτημα το θέμα εγγύησης για την Sony και με προέτρεψαν να επιλέξω Samsung που έχει 2 χρόνια εγγύηση έναντι 1 της Sony.Τελικά υπάρχει πρόβλημα με την υποστήριξη της Sony ?
GeoGeoGeo
28 March 2007
3,498
Η υποστήριξη των samsung είναι λογική γιατί δίνει προμήθειες!Βέβαια δεν παύει να είναι και ένα μειονέκτημα!Τώρα στην επιλογή σου η D3000 ξεχωρίζει από τις άλλες δύο σε θέμα αναλογικής θέασης(ιδιαίτερα κινούμενες εικόνες όπως π.χ. αγώνες ποδοσφαίρου).
Βασίλης 07
896
Δέν θέλω να βγούμε off θέματος εδώ (έχω ανοίξει σχετικό) αλλά το αναλογικό σήμα είναι κάτι που δέν με ενδιαφέρει και τόσο στην επιλογή νέας TV μιάς και τα κανάλια σύντομα ...? θα γίνουν ψηφιακά.
