Και ξαφνικα η τηλεοεαση δεν ανοιγει!!! Μετα απο ενα χρονο αψογης λειτουργειας η 65αρ 9096 δεν ενεργοποιηται με τιποτα!Εβγαλα/εβαλα την πριζα μπας και γινει κατι..ματαια! Και δεν εχει κανενα κουμπι επανω της παρα μονο το τηλεχειρηστηριο! Χθες , δηλ πριν απο 10 ωρες που την εκλεισα με το τηλεχειρηστηριο επαιζε μια χαρα! Τι λετε να συμβαινει και τι κανουμε εν συνεχεια!
Like the Sony XH9505, the TV's control is now just a single button, located beneath the Sony branding at the center of the bottom bezel.
This button lets you turn the TV On/Off, change the input source, change the channel, adjust the volume, and restart the TV.
Perform a forced factory reset on your Android TV (if the TV has one or three buttons)
https://www.sony.com/electronics/su...jectors-lcd-tvs/kdl-32r300c/articles/00159906
Follow the instructions according to the number of buttons on your TV.
Type A: Your TV model has only one button
- Unplug the TV AC power cord from the electrical socket.
2.Press and hold the
Power button on the TV (not on the remote), and then (while holding the button down) plug the AC power cord back in.
Continue to hold the button down until the white LED light appears.
It will take approximately 10-30 seconds for the LED light to turn white.
3.Release the button after the white LED light appears. If the LED light doesn't turn white within 30 seconds, start from Step 1 again.
4.Wait a few minutes for the forced Factory reset process to take place. The TV will reboot (turn on and off) twice. If the TV doesn't turn back ON automatically, press the
Power button to turn the TV back ON.
5.When the
Welcome setup screen appears, perform the setup. If the
Welcome setup screen doesn't appear, unplug the AC power cord and then plug it back in.
If the forced Factory data reset didn't resolve the issue, repeat the procedure again starting from Step 1.
