-Samsung TV Line-up 2021-
xavito
29 October 2008
8,989
55"...[geex.x-kom.pl] ... Samsung QE55Q77A review... https://geex.x-kom.pl/recenzje/test-i-recenzja-telewizora-samsung-55q77a/
QE55Q77A: VA panel,8 domain,RGB,vertical stripe
Edge (bottom) LED LCD
120Hz με MCFI
wide color gamut DCI P3 gamut :yes
HDR
In the HDR mode on the 10% board, the maximum luminance after three minutes of measurement was 549 nits, which is much above average and higher than in the 65Q77A (511 nits).
xavito
29 October 2008
8,989
-Η Samsung Display δημοσίευσε μια σελίδα προϊόντος για τα QD-OLED panel (που διατίθεται στην αγορά ως "QD Display"), η οποία μας δίνει μια ματιά στις πιθανές προδιαγραφές των νέων τηλεοράσεων OLED της Samsung το επόμενο έτος...https://avclub.gr/index.php?threads/oled.13629/post-1058684162
-What is QD-OLED? Samsung details its new TV display technology...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1628754223
65"...[hdtvtest.co.uk]...Samsung QE65LST7TC "The Terrace" hands-on test
QE65LST7TC: VA panel
We did a hands-on test of Samsung's The Terrace outdoor TV, and measured it to reach 1800 nits full-field at D65 white point, making it the brightest television full-screen we've come across thus far.
The Samsung Terrace is available in three screen sizes, namely 55-inch, 65-inch (tested) & 75-inch models, retailing at £4000, £5000 & £6500 respectively.
This video was graded & uploaded in HDR10, and so is best watched on a compatible HDR display.
xavito
29 October 2008
8,989
43"...[geex.x-kom.pl]...Samsung UE43AU7192 review...https://geex.x-kom.pl/recenzje/test-i-recenzja-telewizora-samsung-43au7192/
Panel type : VA , subpixel panel structure RGB,4-domain,vertical stripe
Panel technology : LCD
Backlight type : Direct LED
50/60Hz
ANSI Contrast Ratio : 4340 : 1
Despite the good contrast, Samsung engineers decided to turn on their favorite "improver" and used global dimming (so-called frame dimming ).
Unfortunately, it is much more aggressive than in the low-contrast UE43AU8002.
HDR
In HDR mode on the 10% board, the maximum luminance after three minutes of measurement was a meager 237 cd/m²(nits).
xavito
29 October 2008
8,989
55"...[fwd.nl]...Samsung QE55QN85A review...https://fwd.nl/beeld/review-samsung-qe55qn85a-qn85a-serie-neo-qled-televisie/
QE55QN85A : ADS panel (which is an IPS variant)
Filmmaker mode,measurements SDR
HDR Filmmaker Mode
Οι ρυθμίσεις είναι μόνο για αναφορά.
Δεν υπάρχει καμία εγγύηση ότι θα σας δώσουν την καλύτερη εικόνα που είναι σύμφωνη με τα πρότυπα της βιομηχανίας και κατάλληλη για το περιβάλλον προβολής σας (ειδικά ισορροπία λευκού, ρυθμίσεις συστήματος γάμμα και χρώματος που διαφέρουν από μονάδα σε μονάδα).
Εάν θέλετε μια εγγυημένη βαθμονομημένη εικόνα, καλέστε έναν επαγγελματία βαθμονομητή τηλεόρασης.
General:
Picture Mode: Filmmaker Mode
Picture Size Settings: 16:9 Standard
Fit to Screen: On
Expert Settings:
Brightness: 28
Contrast: 45
Sharpness: 5
Color: 25
Tint(G/R): 0
Local Dimming: Standard
Contrast Enhancement : Off
Film Mode: Auto Color
Tone: Warm 2
Gamma: BT.1886 / 0
Shadow Detail: 0
RGB Mode: Off
Color Space : Auto
Sharpness Settings:
Auto or Customized:
De-blur : 10
De-judder: 6-8
Led Clear Motion: Off
Noise Reduction: Auto or Off
xavito
29 October 2008
8,989
65"...[lesnumeriques.com]...Samsung QE65QN800A review...https://www.lesnumeriques.com/tv-televiseur/samsung-qe65qn800a-p65847/test.html
QE65QN800A type panel: VA (Vertical Alignment) + viewing angle compensation film+anti-glare filter,RGB,4-domain,vertical stripe
Display technology: LCD,transmissive
Backlight : mini-LED Direct,FALD.
Wide color gamut_DCI-P3 coverage : ναι
120Hz με MCFI+αναβόσβησμα του οπίσθιου φωτισμού
It is indeed a VA panel (there are not two red sub-pixels, it is simply the optical filter that gives this illusion.
bcd99405-samsung-qe65qn800a-le-televiseur-8k-100-hz-le-plus-abordable-de-samsung_wtmk.jpeg
332667aa-samsung-qe65qn800a-le-televiseur-8k-100-hz-le-plus-abordable-de-samsung__w1280_wtmk.jpeg
5e13c3cc-samsung-qe65qn800a-le-televiseur-8k-100-hz-le-plus-abordable-de-samsung__w1280_wtmk.jpeg
01ba1195-samsung-qe65qn800a-le-televiseur-8k-100-hz-le-plus-abordable-de-samsung__w1280_wtmk.jpeg
d66b904b-samsung-qe65qn800a-le-televiseur-8k-100-hz-le-plus-abordable-de-samsung__w1280_wtmk.jpeg
Our settings and measurements:
To get the best image quality, we chose Filmmaker mode.
We then lowered the Backlight to 17 to get a white close to 150 cd/m²,
then set the local attenuation to "standard" ("high" in HDR) and the contrast improvement to "Off".
Finally, on the motion compensation side, the Auto Motion Plus in Automatic mode works pretty well, but we prefer the custom setting with "Blur Reduction" on 8 and "Judder Reduction" on 3.
Remember that in Filmmaker mode, Auto Motion Plus is disabled.
In game mode, you have to go to the image settings and then to the expert settings to change the color shade on "Warm2" and choose the automatic color space to find a temperature closer to 6500 K and colors a little more accurate.
ΓΡΥΠΑΣ
6 December 2018
1,337
Sorry εάν είμαι εκτός τόπου...!
Σε Samsung TV, έχεις την δυνατότητα να περιηγηθείς στο διαδίκτυο; ( Όπως στις LG TV, μέσω της εφαρμογής " Πρόγραμμα περιήγησης στο web " )
ΓΡΥΠΑΣ
6 December 2018
1,337
Κατι ακομη.... τον κερσορα τον χειριζεσαι με τα πληκτρα, σαν ποντικι ( οπωϛ στιϛ LG, με το LG Magic Remote ), ή ειναι αναλογα με το ποιο τηλεχειριστηριο χρησιμοποιειϛ;
billpeppas
23 October 2013
6,851
Athens
Με τα κουμπιά.
Δεν θυμάμαι κάποιο φρέσκο μοντέλο που να είχε pointer.
Βεβαίως, μπορείς να χρησιμοποιήσεις το Smart Things στο κινητό και να χρησιμοποιήσεις το touch του κινητού σαν control.
Καμία από όλες αυτές τις λύσεις βεβαίως δεν κάνει... εύχρηστο τον web browser οποιασδήποτε TV (προσωπικά είτε σε LG με magic remote, είτε samsung, είτε panasonic δεν αντέχω λεπτό web browsing μέσω της TV)
xavito
29 October 2008
8,989
We crowned the best TV of 2021 in our annual TV shootout where the LG G1, the Panasonic JZ2000, the Philips OLED+936, the Samsung QN95A & the Sony A90J were compared vs a Sony BVM-X300 reference mastering monitor.
Timestamps:
0:00 World’s Best TVs!
1:13 Black Level & Shadow Detail
2:05 Colour Accuracy
3:27 HDR Performance
4:25 Motion
5:08 Video Processing
6:00 Screen Uniformity
6:43 Bright Room
7:32 Best Gaming TV
8:17 Best Home Cinema TV
8:51 Best Living Room TV
9:24 Best TV of 2021
10:34 Q&A
All competing TVs were 55 inches in screen size, and were calibrated in SDR and HDR modes to the common standards used within the film and broadcast industry, perceptually matched to the Sony X300.
Thanks to Mr Maciej Koper who flew in from Poland to help with the calibrations.
All the TVs were masked, and their positions switched on shootout day, so the three calibrator judges (including Mr James Willmott who is a THX-certified video calibrator) didn't know which TV was which when scoring different picture attributes.
Here are the results:
Best Home Cinema TV: Panasonic JZ2000
Best Living Room TV: Sony A90J
Best Gaming TV: LG G1
Best TV of 2021: Sony A90J
πηγή : hdtvtest.co.uk
xavito
29 October 2008
8,989
-Samsung to buy more LCD TV panels from LG Display next year; report...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1637920031
πηγή:flatpanelshd.com
-Samsung: in 2022 more LCD TV panels from LG Display, AUO and Sharp, QD-OLED and OLED from LG...https://www.hdblog.it/tv/articoli/n547742/samsung-2022-lcd-lg-auo-sharp-qd-oled-wrgb-oled-lg/
πηγή : hdblog.it
-Rumour: Samsung Electronics even closer to OLED TVs in 2022?...https://www.avforums.com/news/rumour-samsung-even-closer-to-oled-tvs-in-2022.19336
πηγή: avforums.com
50"...[avforums.com]...Samsung UE50AU9000 review...https://www.avforums.com/reviews/samsung-au9000-ue50au9000-led-lcd-tv-review.19322
LCD
edge-lit LED
VA
60Hz panel
HDR
image.php
Using our standard testing of measuring various screen window sizes, we found that the peak brightness of the AU9000 was around 275 nits across all window sizes.
This is to be expected from a set at this price point. With an ANSI measured black level of 0.071 nits we get an on/off contrast of 3878:1.
DCI-P3xy coverage: 87%
