[Beta Firmware] NMP-1000P v1.2.0 Build0818
Postby QNAPTony » Fri Aug 19, 2011 5:21 pm
Hi all,
Below link please find the latest beta firmware for NMP-1000P.
[Download Links]
http://forum.qnap.com/viewtopic.php?f=176&t=48445
[Checksum]
3122646390 86543279 NMP-1000P_20110818-1.2.0_ALL_PAL.fw
1911410532 86543371 NMP-1000P_20110818-1.2.0_ALL_NTSC.fw
[Version & Build]
v1.2.0 Build0818
[New]
- Support audio only live stream
- Playback UI for TuneIn Radio
- Update safe mode
- Support .flv
- Upgrade SDK
- Play-count function
- Upgrade transmission daemon for BT Download Station
[Bug fix]
- Change NAND Flash access clock
- Music Title value empty
- Picture changes Play mode setting
- Fix detection failure on wireless dongle
- Disable wireless driver messages on the console
- Disable HWJPEG
- Initial mute variable
- Enable Youtube video url translation function in codec library
- HTTP buffer controller for FLV
- Fix power on detecting issues (on Ralink2870 wireless dongle)
- Restrict max 8192 files visible in a folder because of long user wait
- Enable Youtube option, fix typo
- Press key [play] to playback DVD/BD folder
- Fisable slide-in effect of active-menu in photo playback
- Translate remote file name to local filename for Media DB initialization and web playback
- USB folder remove problem
- delay to avoid power-off failure
- Modify get album art rule
- Solve Youtube query fail
- Login YouTube, no options Add to favorites
- Enhance volume adjustment performance
- Youtube change web page
- DCM support to delete the current playback track
- Enhance the setting volume performance for DVD, CD and BD mode
- Mute and playback and unmute, there are noise on HDMI
- Disable option "Eject/Disconnect" for Internal disk
