PopCorn A-400/410 (Sigma 8911 + VXP)
antreas1980
11 November 2011
156
καλησπερα εχω ενα προβλημα με το control του μηχανηματος αφου εχει χαλασει το κουμπι power με αποτελεσμα πολλες φορες να δυσκολευομαι να κλεισει το μηχανημα.Ξερει κανενας που μπορω να βρω καινουργιο control για το μηχανημα?
AlexT_
10,452
Μάλλον έχει χαθεί το ενδιαφέρον για τα Α400 & Α410.
Πέρασα την τελευταία beta 2 (περιλαμβάνει και τις βελτιώσεις της beta 1), η οποία λύνει αρκετά ζητήματα..
http://www.networkedmediatank.com/showthread.php?tid=73492
Οι βελτιώσεις (αντιγραφή από το παραπάνω φόρουμ):
Beta 2 Release Notes:
- Fixed SSA/ASS has vertical top alignment overlapped timestamp causing crash issue
- Fixed position tag in SRT unable to show properly in full-scale OSD
- Fixed color tag in SRT unable to take effect issue
- Fixed SSA/ASS position is not relative to video frame aspect ratio issue
- Fixed SRT with SSA position tag (0,0) causing crash issue
- Fixed some video clips with no audio stream keep trigger rebuffering issue
- Fixed some vobsub rendering problem
- Fixed some TrueHD MKV file passthrough no sound issue
- Added audio sampling info
- Fixed PGS with fading effect unable to display properly issue
- Added LAME Padding handling for MP3 seamless playback
- Fixed now playing Lyrics panel rendering issues
- Added ID3 Year tag and sampling rate info into get_current_aod_info API
- Changed now playing artist, album, genre and audio resolution label to icon display
- Fixed SACD ISO with upper case extension (ISO) unable to start playback issue
- Fixed some FLAC causing static sound and skip during gapless playback transition issue
- Fixed some MPEG AVI playback has no video display issue
- Added FLAC and DSD MIME type for UPNP renderer
Beta 1 Release Notes: ( http://www.networkedmediatank.com/showth...?tid=73426 )
- Reduced playback starting time
- Added UTF16 support for SMI subtitle
- Added subtitle style support for SSA or ASS subtitle
- Improved all the text base subtitle rendering quality
- Fixed in SRT subs the bold tag sets all consecutive text to bold issue
- Fixed UTF16 text subtitle sometimes dropping issue
- Fixed big gap between subtitle italic style text characters
- Fixed sometimes text subtitle missing or crash after trick mode issue
- Hide color, fontsize and position setting sub-menu, except for SRT, SMI, SUB
- Fixed some MKV embedded text subtitle with zlib compression unable to show correctly issue
- Fixed MKV PGS subtitle random dropping or missing issue
- Fixed MKV PGS subtitle display with wrong color palette issue (Avatar)
- Fixed some external SUBIDX may cause random crash issue
- Fixed SUBIDX with two or more languages or index encounter random crashing issue
- Improved the performance of DSD and SACD playback
- Added support for gapless DSD playback.
- Improved DSF and DFF (DSD) files NMJ scanning speed
- Added Composer and Duration info in scanning for DSF and DFF
- Fixed DSF file larger than 2GB (stored in NTFS or EXT3 storage) unable to retrieve ID3 info issue
- Fixed some DFF files detection issue
- Fixed DSF channels mixed up issues
- Fixed SACD seeking wrong position issue
- Fixed SACD unable to repeat playback issue
- Fixed unable to play SACD when select play now on Add To Queue popup box issue
- Fixed certain APE file playback cause framework crash due to big tag size issue
- Fixed M4A and WMA randomly causing crash issue
- Added audio info display box in screen saver when changing song
- Fixed EUC-KR encoding in Now Playing issue
- Enhanced the Now Playing song listing UI
- Fixed Track Artist and Album Artist scanning issue
- Fixed BDLITE menu chapter section have no indicator issue
- Show audio title and language together on MKV menu
- Fixed UPNP audio playback unable to get metadata info
- Fixed certain AVI and MP4 playback encounter crash issue
- Fixed some MP4 playback no sound issue
- Added NMJ audio and subtitle bookmark handling
- Fixed play next song if select "Add song to Queue(current)" during playback issue
- Fixed unable to copy file to folder created from File Operation (inside NMT HDD, copy through Samba)
- Fixed unable to browse NFS servers without SAMBA Master Browser issue
- Fixed SDHC SD Card mounting issue
- Improved scrolling speed in File Browser
- Enhanced the buffering icon
cmoustos
25 August 2008
2,079
Θεσσαλονικη
Να ρωτήσω κάτι για το Α400 να κινηθεί λίγο το thread :)
Για ασύρματο dongle έχει δοκιμάσει κάποιος κάτι άλλο εκτός από το original? Δουλεύει? Αν ναι ποιο? Ευχαριστώ
achilleas8095
26 June 2006
430
Απάντηση: Re: PopCorn A-400/410 (Sigma 8911 + VXP)
τίποτα? ουδείς? :(
Είχα χρησιμοποιήσει ένα turbo X (δεν θυμάμαι όμως πιο chip φορούσε ) και δούλεψε μια χαρά!
8 June 2007
996
ΜΕΣΟΛΟΓΓΙ
Καλησπερα φιλοι μου...κατοχος του Α-410 και θελω μια βοηθεια γιατι πελάγωσα.....για να δω 3D ταινια, τους υπότιτλους τους εκανα μετατροπη απο 2D σε 3D με το προγραμμα 3D-Subtitler σε αρχεια idx και sub και δεν εμφανίζονται...τι γινεται? Υπαρχει καποια αλλη λυση? Ευχαριστω πολυ..!!!
8 June 2007
996
ΜΕΣΟΛΟΓΓΙ
Το μονο που βρηκα ψάχνοντας ειναι οτι βάζοντας στο τελος πριν το .mkv για την ταινια και πριν το .srt για τους υπότιτλους ,το 3DSBS...το 410 αναγνωρίζει 3d την ταινια και με λογοτυπο επανω δεξια ,τους υποτιτλους τους εχει στην μεση πλεων ,αλλα οχι 3D μονο 2d...πατωντας το setup στο τηλεχ/ιο στο 3d μου βγαζει μονο τις επιλογες: Right Eye First & Left Eye First....Υπαρχη καποια βοηθεια βρε παιδια για να παιζουν κανονικα 3d οι υπότιτλου?
67263704_374465943213229_4499300721589485568_n.jpg67168404_2489330877784496_2874467692469813248_n.jpg67168105_1088971921303066_5228807951971516416_n.jpg67136430_459887771509933_8878292769198571520_n.jpg
σε αυτο το video βλεπω πως εχει περισοτερες επιλογες...?? https://www.youtube.com/watch?v=-72...RNK_5S3vXGN0E6Wec4qr_bTdAfHge9pv8khZnYHaaqivU
τι δεν κανω σωστα..?
vadergr
17 August 2007
27,540
Μεταμορφωση
Για να λες ότι παίζεις mkv, μάλλον δεν είναι σωστό το αρχείο.
Σε 3d να προτιμάς iso image.
Δεν θυμάμαι αν το συγκεκριμένο μηχανάκι υποστηρίζει mvc.
8 June 2007
996
ΜΕΣΟΛΟΓΓΙ
Καλησπερα και σε ευχαριστω...
ετσι ειναι το αρχειο που βλεπω...απλα στο τελος προσθεσα εγω το 3DSBS
Aquaman.2018.1080p.3D.BluRay.Half-SBS.x264.TrueHD.7.1.Atmos-FGT.3DSBS.mkv
Aquaman.2018.1080p.3D.BluRay.Half-SBS.x264.TrueHD.7.1.Atmos-FGT.3DSBS.srt
σε βοηθάει αυτο..?? https://www.cloudmedia.com/?page_id=1756
