Και φοτος μετα απο πειραγμα στην κουρο απο αλο φορουμ.
http://img860.imageshack.us/img860/8476/dsc0070e.jpg
αριστερα ειναι lcd tv .
Εδω και αλλες οδηγιες.
Step 1 concerns connecting your TV to Hyperterminal. If you are already okay with issuing RS232 commands, proceed to step 2.
Step 1
You will need:
A computer with serial port (you can buy USB to serial adaptors if you don’t have one).
A serial cable (9 pin to 9 pin, female to female, straight not null modem).
Hyperterminal (included with XP).
1. Connect the computer to the TV with the serial cable.
2. Start Hyperterminal (Start > All Programs > Accessories > Communications >HyperTerminal).
3. It will ask you to create a new connection. Name it whatever you want (TV for example) and choose an icon (can be any) and click OK.
4. On the next screen (Connect To), ignore the phone number field and change the ‛Connect using’ drop down box to your serial port (usually COM1) and click OK.
5. Next you will see ‛COM1 Properties’. The default bits per second or Baud rate is 9600 for Pioneer displays.
6. Set BPS: 9600, Data Bits: 8, Parity: None, Stop Bits: 1, Flow Control: None and click OK.
7. Next go to File > Properties and open the Settings tab. Click on ‛ASCII Setup..’ button. Make sure ‛Send line ends with line feeds’ is NOT checked and make sure ‛Echo typed characters locally’ IS checked. Click OK and Click OK on the properties screen.
8. You should now be set to communicate with the TV. To test all is okay, put the TV in standby (red light on front).
9. Now type PON in the Hyperterminal and press Enter. The TV should turn on (blue light). Now type POF and press return and it should go back to stand by. Please note typing in Hyperterminal is odd and everything will appear on one line. This is normal. Don’t try to move the cursor with the mouse or anything like I did. Just type commands (even if they overwrite what you have just typed) and press Enter. That’s it.
10. Hopefully the TV responded to PON and POF. If so then you are ready to do the fix.
Step 2.
1. Make sure your TV is in stand by (red light on front).
2. Type PON and press Enter (TV should turn on).
3. Type FAY and press Enter (Enter Factory Mode).
4. Type CPM and press Enter (Clear pulse meter).
5. Type CHM and press Enter (Clear Hour meter).
6. Type POF and press Enter (turn TV off).
7. Unplug TV for 15 seconds or so.
Note changes are not visible until the TV has been turned off and on again.
That was all I did. The red tints have gone and black luminance is back to normal. If you see sparkles on the screen you may need to adjust VOL SUS and the VOL RST P in the service menu. A guy in the other forum said you raise VOL RST P until the sparkles disappear. The usual setting for VOL SUS is 128.
πριν.
μετα.
μεσα σε δυο μερες μου το εκανε 2 φορες .ποσο διαρκεια ζωης εχω ακομη,(για να ετοιμασω της βασεις για το καινουργιο μου τραπεζι σαλονιου) τη να πω ρε παιδια ακομα δεν εχει κλεισει 3 χρονια . KYRO και μ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,Καλημέρα.
Έχω πολύ πολύ άσχημα νέα για όλους μας από τη χαλασμένη μου KURO 5090Η. Είναι πολύ πιθανό στατιστικά, (ήδη στο FORUM είμαστε τέσσερα άτομα), στο μέλλον να αντιμετωπίσετε πρόβλημα με την mainboard της TV. Η τηλεόρασή σας κάποια στιγμή ενδέχεται να μην ξεκινά και θα αναβοσβήνει το μπλέ φωτάκι 8 φορές. Αν το πάθετε, έστω και μία φορά, αρχίστε να ανησυχείτε. Το πρόβλημα σιγά σιγά θα επιδεινωθεί και θα φτάσει σε σημείο η τηλεόραση να μην είναι ποια λειτουργική (θα καταφέρνει να εκκινήσει 1 στις 3 φορές). Το κόστος επισκευής, αν θα είστε εκτός εγγύησης τη στιγμή της βλάβης, είναι εξωφρενικό!!!!! 650,00 ευρώ!!!!!. Εναλλακτικές λύσεις δυστυχώς δεν υπάρχουν πολλές. Στο εξωτερικό οι τιμές του ανταλλακτικού παίζουν στα ίδια περίπου επίπεδα και το μόνο που μπορεί να γίνει είναι να σταθεί κάποιος τυχερός και να βρει κάποια ανακατασκευασμένη ή μισοχαλασμένη αλλά που θα ψιλοδουλεύει όπως έκανε ο Nektar, με περίπου 90ευρώ.
Εγώ πάντως παιδιά είμαι τρομερά απογοητευμένος και μετανιωμένος με την αγορά μου και καλοπροαίρετα θα σας συμβούλευα να αρχίσετε να ψάχνετε από τώρα για καμιά main καβάτζα (στείλτε pm σε μένα ή τον Nektar για να σας δώσουμε sait) ή να την πουλήσετε πριν να είναι πολύ αργά.
Κριμα ρε παιδια.. Μηπως αντι να δωσουμε 650, να δωσουμε κανα 100αρι εκαστος σε δικηγορο και να ετοιμασουμε μια μαζικη αγωγη για ελλατωματικο προιον? Υπαρχει κανενας νομικος να μας πει αν εχει βαση μια τετοια κινηση?
ειδικα απο την στιγμη που ειναι εκτος εγγυησης η βλαβη,πολυ δυσκολο.
εσυ Γιωργο τελικα τι εκανες?
Αφου εξαντλησα ολες της πιθανες εναλλακτικες λυσεις χωρις αποτελεσμα, την εβαλα σε ενα ραφι στην αποθηκη..
Ενα πανακριβο προιον μεσα σε 3 χρονια λειτουργιας αρχιζει και χαλαει μαζικα. Απο την αλλη μερια, η εταιρεια που το κατασκευαζει πουλαει ενα ανταλλακτικο στο 1/3 σχεδον της αξιας του προιοντος. Μια αγωγη ισως να αναγκαζε την εταιρεια να δεχθει οτι υπηρξε αστοχια υλικου και να δεχτει μειωση της τιμης του ανταλλακτικου.
na σε πιανει τρελα ειναι ........................μαστα..και οι υπολοιποι κανουμε τον σταυρο μας..
Με βάση ποιον νόμο θα γίνει μια τέτοια αγωγή; Και εναντίον ποιου;
Της πιονηρ στην Ιαπωνία;
