-Philips TV Line-up 2019-
xavito
29 October 2008
9,009
Philips OLED804 & OLED854 to feature HDR10+, Dolby Vision & Atmos...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1548225788
Philips 'The One' & more 2019 LCD TVs with Dolby Vision unveiled...https://www.flatpanelshd.com/news.php?subaction=showfull&id=1548226019
source:]flatpanelshd.com]
TP Vision, the company responsible for the development & marketing of Philips TV in the UK and Europe, has launched its new 2019 range of OLED TVs, namely the Philips 804 & 854 series.
Coming in 55-inch and 65-inch sizes, the Philips 804 and 854 will feature Dolby Vision & Dolby Atmos support, a 2019 WRGB OLED panel from LG Display, third-generation P5 video processing engine, and Android 9 (Pie) at launch.
Things we forgot to mention in the video:
1) The underlying chipset on the Philips OLED804 & OLED854 is HDMI 2.0b and not full-spec HDMI 2.1... we are awaiting clarification on whether any HDMI features such as ALLM, VRR or eARC can be implemented.
2) We forgot that the Loewe bild 7 OLED can also be specced with a swivel stand.
3) The TVs will ship with Android 9 (Pie) at launch.
4) White balance calibration controls have been expanded from 2-point to 20-point.
https://www.youtube.com/watch?v=IZxjsbNzR4g
source video:[youtube.com - hdtvtest.co.uk]
-We interviewed TP Vision's picture quality guru, Danny Tack, to discuss Dolby Vision support and 2019 OLED panel on the new Philips 804 & 854 OLEDs. He also explained why Philips TV is not launching an 8K display at the time of this interview.
https://www.youtube.com/watch?v=2a266DHBeyA
We attended the launch event for the full range of Philips TVs for 2019. In Europe, Philips is a brand of TPVision and they are introducing two new OLED TVs, the 804 and 854 with both Dolby Vision and HDR10+ dynamic metadata HDR systems. They also announced a full line-up of LED LCD TVs with more soundbars from Bowers and Wilkins.
We interview Danny Tack, Andy Kerr, Piotr Herod and Paul Gray.
https://www.youtube.com/watch?v=JB-inRpBQpI
source video:[youtube.com - avforums.com]
hristoslav2
8 January 2016
360
Varna, Bulgaria
https://www.cnetfrance.fr/news/tv-p...atmos-sur-presque-toute-la-gamme-39879723.htm
enigmatiko40
23 May 2010
443
Αθηνα
Re: Philips PUS73x3 : Reviews - Εντυπώσεις - Σχόλια
Αυτη η φωτογραφια ειναι η ιδια σε μαυρο φοντο να φανταστω ετσι? Σε VA αριστερα και σε IPS δεξια. Παρολα ταυτα δεν απογοητευομαι γιατι εχω δει το Ambilight σε σπιτι γνωστου μου που την αποκτησε. Σε παλαιοτερο μοντελο βεβαια του 2017 αλλα το σαγονι μου ειχε πιασει πατωμα!!! Εχω ακουσει για την λεγομενη λοταρια στο τι θα τυχει ως τηλεοραση, VA η IPS. Περιμενω να ερθει η 7304 να δουμε αν θα υπαρχουν κι εκει θεματα. Εχεις καποια γνωση για την 7304? Τι πανελ θα φοραει και ποτε την περιμενουμε?
papasouzakias
13 May 2009
4,523
Το μόνο που αναφέρουν είναι ότι οι νέες Philips θα έχουν Direct LED πανελ χωρίς να αναφέρουν τον τύπο του πάνελ.
Αναλυτικά review θα διαβάσεις στο www.trustedreviews.com/reviews/philips-pus7304 και www.flatpanelshd.com/news.php?subaction=showfull&id=1548832697
Πάντως στο πρώτο review αναφέρεται:
One other aspect of the PUS7304’s picture performance that I need to reserve judgment on is black level. The sets use direct LED lighting, which is a great start. But I haven’t been able to confirm if the PUS7304 range uses IPS or VA panels – or, potentially, a mixture of IPS and VA panels across different screen sizes. Sets that use IPS panels tend to struggle for contrast versus VA models (although they offer a wider viewing angle in return).
There was certainly a little greyness in the occasional dark clip or fade to black we were shown during the Philips event. But not enough to make any sort of definitive judgement one way or the other
Άρα μάλλον και φέτος τα μοντέλα θα έχουν IPS και VA πάνελ.
enigmatiko40
23 May 2010
443
Αθηνα
Μαλιστα. Στο εκαστοτε μαγαζι που θα αγορασω την 7304 δεν θα μπορω να ελεγξω με καποιο κωδικο απο το κουτι πριν καν την ανοιξω αν το πανελ θα ειναι VA? Δεν μπορει καπως θα φαινεται απο καποια λεπτομερεια. Χωρα παραγωγης η Barcode η serial number. Δεν ξερω μια γνωμη εξεταζω.
Κατι αλλο που θελω να ρωτησω. Το Direct led ειναι το το ημισυ του Full Aray κατα καποιον τροπο ετσι? Λιγοτερες ζωνες οπισθιου φωτισμου. Σωστα?Αυτο σιγουρα ειναι πολυ καλυτερο σε φωτεινοτητα απο την edge διαταξη φωτισμου. Αρα περισσοτερα nits, καλυτερος φωτισμος. Δεν ζηταω εξειδικευση. Απλα ρωταω λεπτομερειες ως απλος ερασιτεχνης σε αυτη την κατηγορια. Ειναι καλυτερη η διαταξη Direct led απο τις edge led?
papasouzakias
13 May 2009
4,523
Δεν έχουν αναφέρει κάτι για barcode που μπορείς να δεις τι πάνελ φοράει. Και στη Philips να στείλεις email δε νομίζω να σου απαντήσουν. Μόνο απο το εργοστάσιο παραγωγής θα ξέρουν.
Τώρα για Direct LED vs Edge LED εξαρτάται από την υλοποίηση της κάθε τηλεόρασης. Μπορεί μια Edge LED να έχει καλύτερη ομοιομορφία από μια με Direct LED. Αλλα γενικά ισχύει ότι καλύτερες οι Direct LED.
enigmatiko40
23 May 2010
443
Αθηνα
Σε ευχαριστω για την αναλυση σου φιλε papasouzakias. Φυσικα παιζει ρολο και ο επεξεργαστης της εκαστοτε τηλεορασης. Και λενε οτι ο P5 ειναι κορυφαιος στην διαχειριση και την επεξεργασια. Συν τη εκδοζη του Direct Led, το παντρεμα θα ειναι τιμητικο στο αποτελεσμα.
xavito
29 October 2008
9,009
H διάταξη Direct LED έχει λιγότερα LED από τη διάταξη F.A.L.D.
Η διάταξη Direct LED δεν έχει ζώνες ελέγχου όπως στην F.A.L.D.
Το πόσο φωτεινό μπορεί να γίνει το πάνελ, δεν έχει σχέση με τη διάταξη D-LED σε σχέση με Edge LED,μπορεί μια Edge LED να είναι φωτεινότερη από μια D-LED.
Περισσότερα nits = φωτεινότερο πάνελ αλλά δεν σημαίνει και καλύτερη εικόνα,όλα είναι θέμα διαχείρισης ,ρύθμισης.
enigmatiko40
23 May 2010
443
Αθηνα
Xavito οπως παντα κατατοπιστικοτατος. Σε ευχαριστω πολυ. Η τεχνολογια παντως πηγαινει ολο και πιοτερο προς τις ζωνες οπισθιου φωτισμου. Στις πιο Premium τηλεορασεις το Full Aray ειναι μονοδρομος, οσον αφορα τις LED οθονες. Οι OLed ειναι ξεχωριστη κατηγορια με οργανικα αυτοφωτιζομενα πιξελ. Με τα μειονεκτηματα της κι αυτη η κατηγορια. Εξελιξις. Τα επομενα χρονια θα δουμε μεγαλες αλλαγες. Αν μεχρι τωρα εχουμε φτασει σε αυτη την τεχνολογια,μεσα σε λιγα χρονια, και με τεραστιες αλλαγες ανα 3- 4 χρονια, το 2025-2030 πως θα ειναι? Ταβανι στην τεχνολογια δεν υπαρχει. Παντα θα υπαρχουν αβαν-γκαρντ επιλογες για να προχωραμε πιοτερο ψηλα.Η και οχι παντα ψηλα. Ειδωμεν.
enigmatiko40
23 May 2010
443
Αθηνα
Καλησπερα παιδια. Γνωριζουμε ποτε θα ερθουν οι Philips στην αγορα? Ολες οι αλλες εταιριες εχουν προωθησει τα μοντελα τους. Υπαρχει ημερομηνια? Στον Κωτσοβολο αναφερει προσεχως. Ευχαριστω.
Stergios Giotas
4 November 2006
833
Κωδικοί και ενδεικτικές τιμές λιανικής για τα νέα μοντέλα από το toengel.net:
1.6.2019
55PUS9104/12: 1.299,00 EUR (U2)
55PUS8804/12: 1.299,00 EUR (U1)
50PUS8804/12: 1.099,00 EUR (U1)
55PUS7504/12: 1.199,00 EUR (U1)
50PUS7504/12: 999,00 EUR (U1)
55PUS7394/12: 1.099,00 EUR (U1)
50PUS7394/12: 949,00 EUR (U1)
43PUS7394/12: 799,00 EUR (U1)
75PUS7354/12: 2.399,00 EUR (U1)
65PUS7354/12: 1.349,00 EUR (U1)
55PUS7354/12: 1.099,00 EUR (U1)
50PUS7354/12: 949,00 EUR (U1)
43PUS7354/12: 799,00 EUR (U1)
55PUS7334/12: 1.099,00 EUR (U1)
50PUS7334/12: 949,00 EUR (U1)
43PUS7334/12: 799,00 EUR (U1)
65PUS7304/12: 1.249,00 EUR (U1)
75PUS6754/12: 2.099,00 EUR (U1)
65PUS6754/12: 1.149,00 EUR (U1)
55PUS6754/12: 849,00 EUR (U1)
50PUS6754/12: 699,00 EUR (U1)
43PUS6754/12: 629,00 EUR (U1)
70PUS6704/12: 1.499,00 EUR (U2)
65PUS6704/12: 999,00 EUR (U2)
55PUS6704/12: 699,00 EUR (U2)
50PUS6704/12: 659,00 EUR (U2)
43PUS6704/12: 549,00 EUR (U2)
24PHS4354/12: 219,00 EUR (U0)
24PHS4304/12: 199,00 EUR (U0)
