Philips 200 Hz system is active only on signals in SD (standard definition) and can not be activated when you connect HD sources to HDMI. 200 Hz system helps to smooth out movements, but unfortunately also makes some calculation errors, which appear as mudslinging around moving objects, for example. 200 Hz nor does it contribute to a big improvement over 100 Hz.
It will also ultimately the consequence that the deep reproduction of black is achieved at the expense of shadow detail - ie the degree of detail in the darkest colors, and it is an unfortunate side effect, which unfortunately destroys some of the overall experience with the 9704H TV.
Τα προβληματα που ειχα αναφερει παραπανω με την κινηση και το shadow detail , ευτυχως το flatpanels δεν τα κρυβει...
Παντως το μαυρο και η αντιθεση ειναι οντως σε κορυφαια επιπεδα...
