Περί photoshop, πλήρες πρόγραμμα επεξεργασίας... όλες οι εκδόσεις
cacau
7 June 2008
20,383
Οι παρακάτω είναι οι ελάχιστες απαιτήσεις, αν δεν βγάλεις άκρη στείλε μου p.m. να σου δώσω mail για να ανεβάσεις στο wetransfer την εικόνα.
Hardware Minimum Requirements
Processor (CPU) Intel i3 or AMD Ryzen 3 equivalent or above (3.0 GHz and above)
AVX Instructions required.
System Memory (RAM) 8GB (16GB and higher is recommended for improved performance)
Graphics Card (GPU) OpenGL 3.3 or higher required.
Nvidia GTX 740 or AMD Radeon 5870 (higher series graphics cards recommended)
Dedicated Graphics Memory (VRAM) 2 GB (6GB or more for optimum performance)
Display (Monitor) At least 1024x768
Special Hardware Considerations For Image Apps
The specifications listed above are minimum requirements to operate the software. More robust hardware will improve overall performance and processing speed. Your computer's ability to process an image may be affected by the size of the file itself, and a large enough file can exceed the resources of a minimally equipped computer and cause errant behavior.
Some computers without a dedicated graphics card may function but errant behavior should be expected. A sufficient dedicated graphics card with OpenGL 3.3 and at least 2 GB of VRAM is our minimum requirement to support the software on your device. We do not support Intel HD Graphics 4600 integrated graphics cards or lower in any configuration.
Graphics Drivers
Outdated graphics drivers may result in faulty performance. Drivers should be kept current through the GPU manufacturer's website or provided software. Windows driver updates are rarely current and newer drivers may be available even when Windows says you are up to date. Our programs use the newest optimizations from both Nvidia and AMD whenever possible.
cacau
7 June 2008
20,383
Όσοι έχετε λογαριασμό Creative Cloud μπείτε στις ρυθμίσεις και απενεργοποιήστε το content analysis. Περισσότερα εδώ.
cacau
7 June 2008
20,383
Πολύς προβληματισμός παντού στο διαδίκτυο για τις AI generated images... ...Άλλο πράγμα να αλλάζεις ουρανό και να αφαιρείς κάποια στοιχεία, και άλλο αυτό.
Για να μην μιλήσουμε για αυτές που είναι εντελώς ανύπαρκτες, και τις φτιάχνεις γράφοντας κείμενο - προς το παρόν, γιατί σε λίγο θα το συζητάς...
Reactions: KostasMo
