Αναβάθμιση (δωρεάν για τους υπάρχοντες χρήστες) σε v.1.8 με τις παρακάτω βασικές βελτιώσεις (copy - paste):
New Features & Improvements:
Template support β save documents as template files to re-use time and time again, share templates across all apps and even access files on multiple devices through cloud storage.
New document dialog β it’s now simpler than ever to find, create and manage document presets with customised, saveable presets and thumbnail previews.
Updated PANTONE© library β work with a seemingly endless range of colours, including updated PANTONE© Color Bridge and PANTONE© Formula Guide solid palettes (coated and uncoated).
Lens correction improvements β benefit from manual lens correction override in the Develop Persona, take advantage of the newly added ‛recently used’ and ‛favourites’ lists, and enjoy improved lens correction of RAW files coming from fixed focal length lenses.
Big plugin support improvements β experience the power of a range of plugins in the app, including Nik collection by DxO.
Better metadata handling β new support for user-editable fields in image metadata, including the IPTC standard for copyright and other information, plus, save and import metadata files (XMP)[enable in preferences], batch whole folders of images and tag with appropriate ownership info, and more.
PSD smart object support β any smart objects included in PSD files can now be imported into Affinity Photo as embedded documents [enable in preferences], letting you easily edit layers within any smart object and maintain a non-destructive workflow into Affinity.
Canon CR3 RAW support β open and edit your highest quality photographs in Affinity Photo.
Η αναβάθμιση ΔΕΝ καταργεί τίποτα από τις ρυθμίσεις της εγκατεστημένης έκδοσης, και το "παλιό" Nik collection λειτουργεί κανονικά - μάλιστα το preview στο color Efex είναι σχεδόν ακαριαίο!
Όλες οι αλλαγές και η σχετική κουβέντα στο φόρουμ χρηστών εδώ:
https://forum.affinity.serif.com/index.php?/topic/107773-affinity-photo-for-windows-180/
