Re: Yongnuo YN-622C E-TTL
Βασιλη τα συγκεκριμενα ειναι μονο για Cανον
Εχει και για Νικον.
Εχει και για Νικον.
Για Sony δεν έχει τίποτα?
Because of the different ways in which Nikon and Canon flash systems work, it is likely that the YN-622N will have a much more limited set of capabilities compared to the YN-622C. On EOS DSLRs you can adjust your flashgun from menus on the back of the camera, which is essential since the Yongnuo transmitter has no LCD or control panel to speak of. Nikon cameras do nearly all of their adjustments exclusively on the back of the flash itself, so the YN-622N may be not much more than a fancy “wireless TTL cord” à la the Pixel King triggers.
