Απάντηση: PANASONIC LCD-PLASMA 2009
Ονομαστικες καταναλωσεις και καποια αλλα χαρακτηριστικα για τις σειρες Z και V.
PANASONIC TH-P54Z1
● Screen Size: 54V-● Number of pixels: 1920 × 1080 ● Contrast Ratio: 40000-1 ● Channel Receiver: Digital Terrestrial (CATV support pass-through), BS Digital, 110-degree CS digital and terrestrial analog, CATV ● utility sound Maximum output: total 20W (JEITA) ● Input and Output Terminals: HDMI × 4, D4 input × 1, Video Input × 3, RGB input (Mini D-Sub15Pin) × 1, optical digital audio output, LAN terminal, power consumption ● 550W ● Dimensions: 1428W × 820H × 25Dmm (when mounted speakers) ● Weight: 32kg (when mounted speakers)
PANASONIC TH-P50Z1
● Screen Size: 50V-● Number of pixels: 1920 × 1080 ● Contrast Ratio: 40000-1 ● Channel Receiver: Digital Terrestrial (CATV support pass-through), BS Digital, 110-degree CS digital and terrestrial analog, CATV ● utility sound Maximum output: total 20W (JEITA) ● Input and Output Terminals: HDMI × 4, D4 input × 1, Video Input × 3, RGB input (Mini D-Sub15Pin) × 1, optical digital audio output, LAN terminal, power consumption ● : 550W ● Dimensions: 1336W × 762H × 25Dmm (when mounted speakers) ● Weight: 28.5kg (when mounted speakers)
PANASONIC TH-P46Z1
● Screen Size: 46V-● Number of pixels: 1920 × 1080 ● Contrast Ratio: 40000-1 ● Channel Receiver: Digital Terrestrial (CATV support pass-through), BS Digital, 110-degree CS digital and terrestrial analog, CATV ● utility sound Maximum output: total 20W (JEITA) ● Input and Output Terminals: HDMI × 4, D4 input × 1, Video Input × 3, RGB input (Mini D-Sub15Pin) × 1, optical digital audio output, LAN terminal, power consumption ● : 550W ● Dimensions: 1249W × 719H × 25Dmm (when mounted speakers) ● Weight: 25kg (when mounted speakers)
PANASONIC TH-P50V1
● Screen Size: 50V-● Number of pixels: 1920 × 1080 ● Contrast Ratio: 40000-1 ● Channel Receiver: Digital Terrestrial (CATV support pass-through), BS Digital, 110-degree CS digital and terrestrial analog, CATV ● utility sound Maximum output: total 20W (JEITA) ● Input and Output Terminals: HDMI × 4, D4 input × 1, Video Input × 3, monitor × 1, RGB input (Mini D-Sub15Pin) × 1, optical digital audio output, Ir system LAN terminal, ● Power consumption: 577W ● Dimensions: 1241W × 818H × 401Dmm (with stand) ● Weight: 36kg (with stand)
PANASONIC TH-P46V1
● Screen Size: 46V-● Number of pixels: 1920 × 1080 ● Contrast Ratio: 40000-1 ● Channel Receiver: Digital Terrestrial (CATV support pass-through), BS Digital, 110-degree CS digital and terrestrial analog, CATV ● utility sound Maximum output: total 20W (JEITA) ● Input and Output Terminals: HDMI × 4, D4 input × 1, Video Input × 3, monitor × 1, RGB input (Mini D-Sub15Pin) × 1, optical digital audio output, Ir system LAN terminal, ● Power consumption: 537W ● Dimensions: 1155W × 774H × 401Dmm (with stand) ● Weight: 33kg (with stand)
PANASONIC TH-P42V1
● Screen Size: 42V-● Number of pixels: 1920 × 1080 ● Contrast Ratio: 40000-1 ● Channel Receiver: Digital Terrestrial (CATV support pass-through), BS Digital, 110-degree CS digital and terrestrial analog, CATV ● utility sound Maximum output: total 20W (JEITA) ● Input and Output Terminals: HDMI × 4, D4 input × 1, Video Input × 3, monitor × 1, RGB input (Mini D-Sub15Pin) × 1, optical digital audio output, Ir system LAN terminal, ● Power consumption: 484W ● Dimensions: 1052W × 709H × 332Dmm (with stand) ● Weight: 29kg (with stand)
