ODROID-GO Super 128GB
22 June 2006
34,878
NEO HRAKLEIO
  • Me 128gb micro sd, γεματη παιχνιδια.
  • Μαζι θα δωθει και ο ασυρματος δεκτης WIFI DONGLE, για αμμεσα updates/downloads
Ειμαι αθηνα
60 ευρω
SPECIFICATIONS
ProcessorCPU : RockChip RK3326(Quad-Core ARM 64bit Cortex-A35 1.3GHz)
GPU : Mali-G31 MP2
OSUbuntu 18.04. 19.10 and 20.04 on Kernel 4.4 Aarch64
Modified EmulationStation front-end with Libretro. GPU accelerated OpenGL-ES on DRM-FB
Memory1GB (DDR3L 786Mhz, 32 Bits bus width)
StorageSPI Flash(16Mbytes Boot), Micro SD Card slot(UHS-1 Capable interface)
Display5inch 854×480 TFT LCD (Wide viewing angle display, MIPI-DSI interface)
AudioEarphone stereo jack, 0.5Watt 8Ω Mono speaker
BatteryLi-Polymer 3.7V/4000mAh(76.5×54.5×7.5mm(L*W*T)), Up to 10 hours of continuous game playing time
DC Jack5V input, USB-C power connector : A USB -C charging cable is included in the package.
Maximum drawing current: 1.5Amp
External I/OUSB 2.0 Host x 1, 10Pin port(I2C, GPIO, IRQ at 3.3Volt)
Input ButtonsF1, F2, F3, F4, F5, F6, A, B, X, Y, Direction Pad, Left Shoulder, Right Shoulder, Left Shoulder2, Right Shoulder2, Analog joystick, Analog joystick2
WirelessOptional USB WiFi adapter
Power consumptionGame emulation: 350 ~ 600mA (depends on backlit brightness and type of game emulations and the wireless usage), Power off mode: <1mA
Charging time3.4 ~ 4 hours when the device turns off. When you play game, it takes 4.5 ~ 5.5 hours.
Dimensions204x86x25 mm, Weight: 280 g (10 oz)
