Νikon Z8
Kosh
7 September 2006
91,472
Εκεί ψηλά.....
Key specifications​
  • 45.7MP Stacked CMOS sensor
  • Up to 20fps with Raw, 30fps full-sized JPEG
  • Pre-burst capture in JPEG modes (up to 120fps for 11MP crops)
  • Subject recognition AF and 3D Tracking
  • Synchro VR combining in-body and in-lens stabilization, rated at up to 6EV
  • 8K/60p video in N-Raw, 4.1K in ProRes Raw
  • 8K/30p or up to 4K/60p from 8K
  • Choice of ProRes 422 HQ, H265, H.264
  • N-Log or HLG capture
  • 3.68M dot EVF with dedicated low-lag sensor feed
  • 2.1M dot screen on two-way hinge
  • One CFexpress Type B, One UHS II SD slot
  • Dual USB-C ports
The Nikon Z8 will be available from late May with a recommended price of $3999.
Reactions: evanfotis
NassosT
4,706
Από τον Thom Hogan (https://www.zsystemuser.com/):
What Does the Nikon Z8 Have the Z9 Doesn’t?​
  • 10-bit HEIF support
  • Portrait impression balance
  • Skin softening
  • AF improvements (dedicated aircraft detection, silhouette focus, smaller face detect)
  • USB LAN capability (two USB-C ports: one for USB Power Delivery, one for USB data)
  • 30% lighter, smaller than Z9
  • With HLG video, Z8 has base ISO of 400, the Z9 at 800 (NLOG both are 800)
What Does the Z9 Have the Z8 Doesn’t?​
  • No built-in vertical grip and controls (instead: optional MB-N12 battery grip)
  • No built-in GPS and logging (instead: use SnapBridge from your phone)
  • No built-in Ethernet
  • No Kensington lock
  • No dual CFe slots (instead: one CFe, one SD)
  • No Fn4 button (Fn3 button moves to the Protect button)
  • No extra button row below the Rear LCD
  • No PC Sync socket
  • No flash button on top button cluster (WB instead)
  • No Voice memo
  • No full magnesium frame (instead: partial carbon fiber coupled with magnesium alloy)
  • Slightly shorter video recording time (90 minutes on Z8 versus 125 minutes on Z9)
evanfotis
26 March 2008
5,485
Όλα πολύ καλά ιδίως στο βίντεο, εκτός από δυο για μένα.
Χαμηλής ανάλυσης Evf & ότι δε βάζει η Νίκον pixel shift high res mode σε φωτό…
Θα ήθελα φυσικά και εγγραφή σε usb c όπως κάνει πλέον η Panasonic.
Ίσως τελικά η S1Hii τα δώσει αυτά αλλά μάλλον δε θα έχει εσωτερικό raw…
Kosh
7 September 2006
91,472
Εκεί ψηλά.....
αυτο με το evf δεν το καταλαβαινω πραγματικα. Σε καμερα τετοιας αξιας να επιμενεις σε medium range evf
spcav
18 August 2006
16,633
σε καμια τριετια που ισως πεσει σε λογικεσ (για μενα) τιμες, μπορτει και να τη χτυπησω.
Εχει ολα οσα θελω...εκτος της τιμης! :p
Μα πλεον (εδω και καποια χρονια) με το iPhone δεν χρειάζεσαι μηχανη....:LOL:
22 June 2006
34,849
NEO HRAKLEIO
Αυτό είναι σίγουρο…. Απλά μας αρέσει να παιδευόμαστε ! :p
Προσωπικά, το μόνο που με χαλάει λίγο (εκτός της τιμης φυσικά) είναι το βάρος /όγκος σε σχέση με τις υπόλοιπες μηχανές της κατηγορίας της .
Φυσικά αυτό βοηθάει στο να μην υπερθερμαίνεται εύκολα….
22 June 2006
34,849
NEO HRAKLEIO
Το pixel shift μάλλον άχρηστο είναι.
Το δοκίμασα στη Sony a7r iii που έχω τώρα και πήρα καλύτερα αποτελέσματα με το LR AI .
Άσε που είναι μόνο για απολύτως στατικά θέματα.
Ελάχιστη διαφορά, που όπως είπα με τις μοντέρνες τεχνικές ΑΙ ειναι αχρείαστο τελικά.
evanfotis
26 March 2008
5,485
H Sony έχει ίσως τη χειρότερη υλοποίηση high res…
Το είχα δει στην a7r3…Δοκίμασε με Panasonic S1R η και στις αλλες και θα δεις. Και ας είναι για στατικά θέματα ως επι το πλείστον τι σημασία έχει, είναι μια δυνατότητα που και αυξάνει κατά πολύ ευκρίνεια και δυναμικό εύρος, ισοφαρίζοντας αισθητήρες μεγαλύτερης ανάλυσης.
22 June 2006
34,849
NEO HRAKLEIO
Τα 42/45 mp μου είναι αρκετά…. Κι αν βάλεις και το ΑΙ πας πολύ παραπάνω άνετα και σε κινουμενα θέματα.
Καλο είναι να το είχε, αλλά δεν μ ενδιαφέρει προσωπικά καθόλου πια.
Ίσως τώρα πάρουν μπρος οι υπόλοιπες εταιρείες και δώσουν raw εσωτερικά…ειδικά η Fuji που δεν έχει να προστατέψει άλλες μηχανές , όπως και η Νίκον.
Ειδικά τώρα που βγήκε κάποια άκρη και με τις πατέντες της red, μπορεί να δούμε κι άλλες μηχανές να το υλοποιούν.
kbouk
8 January 2010
22,425
ΠΕΙΡΑΙΑΣ
Ενταξει εγώ που έχω την S1R είμαι υπερβολικά ευχαριστημένος από τα 47Mpx , εχω τη δυνατότητα Hires αυτόματου , είναι σούπερ λειτουργία σε απόδοση αλλά για πολύ εξειδικευμένη χρήση πιστευω θα χρειαστει πολύ μεγαλύτερη ανάλυση.
Το δυναμικό εύρος είναι συζητήσιμο αν μεγαλώνει σημαντικά , ναι βοηθάει στα σκοτεινά αλλά όχι στα φωτεινά
22 June 2006
34,849
NEO HRAKLEIO
Πολυ αλμυρη τιμη στην ευρωπη 4600 ευρω , φανταζομαι στην ελλαδα ακομα χειροτερα!
karamela
6 November 2013
10,664
Μηχανή για επαγγελματίες καθαρά που θα την πάρουν και με τιμολόγιο κλπ. Εμείς απλά κοιτάμε. Για ερασιτεχνική χρήση είναι overkill και καλύτερα να δώσεις αυτά τα λεφτά να πας κανένα ωραίο ταξίδι στην Ασία και ας τραβάς φωτός με το κινητο σου.
cacau
7 June 2008
20,385
Κάπως έτσι το σκέπτομαι κι εγώ τελευταία - εντάξει όχι κινητό, αλλά με ότι έχεις...
...η μηχανή πάντως πολύ ωραία!
Reactions: karamela
karamela
6 November 2013
10,664
Κάπως έτσι το σκέτομαι κι εγώ τελευταία - εντάξει όχι κινητό, αλλά με ότι έχεις...
Μα έτσι είναι Δημήτρη, προσωπικα έχω δώσει σχεδόν τα πάντα από εξοπλισμό και έχω μόνο την Olympus em5iii με τον Olympus 12-100 και τέλος. Τα λεφτά πάνε σε ταξίδια και δεν αγοράζω αλλο εξοπλισμό. Έχω να αγοράσω οτιδήποτε φωτογραφικό πάνω από 1,5 χρόνο και εκεί θα μείνω. Καλοκαίρι ετοιμάζω μεγάλα πράγματα σε Ασιατικες χώρες και η Olympus θα παρει φωτια!!!!
Στα της μηχανής του νήματος οκ είναι φοβερή μηχανή αλλά η τιμή της είναι απλά για λίγους και εκλεκτούς. Ειλικρινά μπορώ να σκεφτώ αλλά 100 πράγματα πέρα από ταξίδια που θα προτιμούσα να διαθέτω αυτα τα κοντά 5.000 ευρώ…
