sherbourn 7020A processor
Νεος προ απο την sherbourn .Aν και το ξερω απο τον Μαη τωρα παρουσιαστηκε στο σαιτ τηε εταιριας.Τιμη Ιταλιας 3,5 χιλιαδες ευρω.Εδω θα δουμε>
FeaturesSpecificationsImagesPDF/BrochureProduct Manual
Features
Features
•Twin Cirrus® 32 bit dual core DSP’s. Cirrus 497004 & 495315 for true 192K performance
•Decoding support for Dolby Digital, Dolby Digital EX, Dolby Digital Plus, Dolby Digital True HD, Dolby PLIIx, DTS, DTSES, DTS HD, DTS Master Audio, DTS Neo 6, SPDIF, PCM 8 channel (note: some audio formats are only supported via HDMI)
•Genesis® Torino high performance video scaling engine for true 10-bit processing
•Integrated 3D video decoder
•Faroudja DCDi Cinema® Format Conversion and Truelife™ video enhancer
•Automatic Cirrus/Sherbourn multi-channel room correction and automatic loudspeaker setup. Calibrated measurement microphone included.
•Quadruple bass manager with independently selectable high and low pass frequencies from 40hz – 160hz
•Balanced subwoofer output
•All legacy video inputs can be scaled and output over HDMI at up to 1080p
•HDMI sources can be format converted to component video up to 1080i
•Intuitive, full color graphical OSD with adjustable transparency presented over live video, including HDMI
•HDMI 1.3a Deep Color compliant
•All inputs are assignable and feature input labeling, selectable decode modes, selectable triggers, etc.
•Independent graphic EQ with global bass and treble controls by channel groupings
•0.5dB level trims
•High voltage, low impedance main analog outputs (7 VRMS)
•RS-232 controllable
