Nέα προϊόντα Hi End εταιρειών.
f2gnikos
13 May 2012
80
Icon Stereo 845 PP
The Ultimate Pure Triode PP Integrated Amplifier! Probably the worlds first. Following our very successful MB845 100w mono blocks, we realised that there are many people who just love the sublime quality of the 845 valves but do not need high power or have the space needed for two large mono blocks and a pre-amp. Surprisingly 100w to 40w is only 3.9db lower in sound output, so the ST845 is an excellent relatively small one box package.
Specifications and Features
Pure Class A, Triode front end
Pure Triode 845 push pull output Stage
All hand wired point to point
Remote control volume
May also be used as a power amplifier
Comprehensive manual supplied
Built in “Easy Bias” Meter
ALPS Japanese volume pot.
4x 845 precisely matched
2x 6SL7 first stage valves
2x 6SN7 output driver valves
1x GZ34 driver stage rectifier
Max output one channel 41w 8Ω 1% THD*
38+38w 8Ω both ch driven 0.5% THD*
THD 8w 0.3%. 1w 0.09%
Max output into 4Ω 32w (11.3v)
Max output into 16Ω 39w (25v)
Signal to noise level -93db
Channel balance better than 0.1dB
Damping factor of 14
Freq response 10hz-20kHz -0dB (41kHz –0.1db) 8w
Freq response 20Hz-20kHz 0.25dB (40kHz -1dB) 38w
Suitable loudspeakers 4Ω to 16Ω
*Low Distortion Tertiary wound output transformers
Transformers potted to reduce noise
Solen/SCR Hi Fi quality audio capacitors
Jensen copper foil on request
Silver plated pure copper PTFE audio cable
Gold plated Input & speaker terminals
Attractive Plexiglas cover supplied
Four line inputs
Record loop
300mv sensitivity.(high) for full output
950mv sensitivity (low) for full output
220/240/115 volts 220watts typical, 500w max
C E. FCC ROHS
44W, 40D, 24H (28H with cover), 35kg
UK selling price (inc. VAT)
Icon Audio Stereo 845 £ 5999.95
Tzimisce
Administration Team
1 February 2007
33,232
127.0.0.1
Κάποιος κάρφωσε τη συζήτησή μου με τον Μιχαηλό στην Copland! :flipout:
Καλή η κίνηση με τις KT120!
Ακόμη καλύτερη το ότι θα παρέχουν upgrade kit για τους κατόχους των 405.
Αλλά με KT120 να βγάζει τα ίδια watt με τις KT88;
Δώστε ρε παιδιά στον λαό μερικά wattάκια παραπάνω!
27 July 2006
1,926
Παραπανω βγαζει!
Tzimisce
Administration Team
1 February 2007
33,232
127.0.0.1
Διαβάζω από εδώ και από εκεί, αλλαγές στα Watt λέει δεν έχει...
Ελπίζω και η τιμή της αναβάθμισης που αναφέρουν (πάνω από 5.000 δολάρια) να είναι λάθος...
More data please! :p
Tzimisce
Administration Team
1 February 2007
33,232
127.0.0.1
chatάκι, chatάκι?
Μα αν δεν ξέρεις το μηχάνημα καπετάνιο μου, το πιο πιθανό είναι να σβήσεις το post σαν αναφορά σε παλιό μηχάνημα.
Αν δεν έπιανε το αετίσιο μάτι μου το λογότυπο της Tung Sol να το ψάξω λίγο και το φουρφούρι (καλά, δεν θέλει και τόσο αετίσιο μάτι για να το δεις αυτό) θα το κλαίγαμε το post. :p
Ο 405 έχει KT88 της Electroharmonix. :smile:
Magellan
Banned
28 July 2006
19,085
Εν πλώ
Μη νομίζεις ότι δεν το τσεκάρησα Βαγγέλη μου, για αυτό υπάρχει ακόμη το ποστ....
sokmav
5 February 2012
14,227
Το γκρι είναι ποίημα....(βεβαίως και πάλι θα προτιμούσα το μαύρο.)
sokmav
5 February 2012
14,227
Με την αφορμή της συμπλήρωσης είκοσι-πέντε χρόνων από την κυκλοφορία του πρώτου ψηφιακού ηχείου της,η Meridian ανακοίνωσε την κυκλοφορία του νέου flagship ανανεωμένου μοντέλου της,DSP Eight Thousand.
https://www.meridian-audio.com/en/campaigns/anniversary/
Μερικά από τα χαρακτηριστικά του:
New tweeter with beryllium dome for outstanding response and wide bandwidth.
Wide bandwidth analogue electronics, to deliver the best sound from high resolution recordings.
Music is all about timing. Meridian's advanced EBA (Enhanced Bass Alignment) technology ensures that all the frequencies in the music arrive with the correct timing, for a sound that is clearer and more authentic – more 'alive'.
All drive units clamped with machined rings to provide enhanced stability, resulting in less coloration.
Ως ναυαρχίδα της εταιρίας,η τιμή του φυσικά είναι υψηλή και προδιαγράφεται γύρω στις 80.000$
Dr Pan K
18 December 2010
9,067
Νεος Burson Virtuoso
Chord Hugo TT (2500$) + 2Qute
