ΠΩΛΗΣΗ Monitor 5.6" TVLogic VFM-056WP High-Resolution Compact LCD πωλείται
Kosh
7 September 2006
91,495
Εκεί ψηλά.....
Πωλείται το field/on camera Monitor 5.6" ΤVLogic VFM-056WP High-Resolution Compact LCD.
Με εξαιρετικό χρωματικό εύρος, εισόδους HDMI και HDSDI αλλα και composite, s-video, component και εξοδο HDSDI και κύκλωμα loop through.
Αψεγάδιαστο χωρίς γρατζουνιά στην οθόνη με plastic shield από την πρώτη ημέρα.
Αποσπώμενο Battery plate για μπαταρίες Sony NP- F ( L series) και έξτρα δύο ακόμα Battery plates για ΑΑ και Panasonic D series.(70 κοστίζει κάθε battery plate αν αγοραστούν ξεχωριστά)
Ενσωματωμένο focus assist, luma zone, waveform, blue only function,dslr scale, timecode, aspect market και άλλα.
Tιμή πακέτο 540
Δώρο ενα sun hood της tvlogic.
https://www.pixelution.co.uk/shop/t...ogic-vfm-056wp-5-6-3ghdsd-viewfinder-monitor/
http://www.fotoklik.gr/index.php/--6/monitors/location-lcd/tvlogic-vfm-056wp-5-6.html
https://www.bandpro.com/tvlogic-vfm-056wp.html
The 5.6" TVLogic VFM-056WP High-Resolution Compact LCD Monitor is ideal for HD-SLR production. A 6” x 4” x 1” lightweight, magnesium-alloy casing houses a 5.6” 1280 x 800 LED-backlit LCD display with a full complement of preferred features, including DSLR Scale, Focus Assist, Various Scan Models, Markers, Audio Level Metering with speaker, Timecode Display, Waveform/Vectorscope, Y Level Check, Range Error Check, and (in the WP model) HDMI loop out via HD-SDI (720p).
Features:
DSLR Scale: Function Scales SD output from a DSLR to 1280x800 Full Screen
Focus Assist (Peaking Filter): Red Color is displayed on sharp edges to enhance focus accuracy
Various Scan Modes: ZERO SCAN, UNDER SCAN, OVER SCAN and 1:1 PIXEL FOR PIXEL
Markers: Choose framing markers for CENTER, SAFETY AREA, FIT and more.
SDI Loop Through: Feature allows your HDMI or SDI input signal to be looped through to a second display via SDI
Waveform/Vector Scope: Displays waveform luminance (Y Level) and Vesctor Scope (B-Y, R-Y on XY axis) in Y/Cb/Cr, Wide and Line modes
Range Error: Selected values (Y MAX, Y MIN, C MAX, C MIN) are indicated in WAVEFORM/VECTOR* or Y/Cb/Cr modes
Y Level Check: Displays Y Level as a solid color on screen to assist in exposure adjustments
