Microsoft Surface Book [2015]
jtheogr
13 July 2010
809
Καλαμάτα
Απάντηση: Microsoft Surface Book
Δεν βλεπεις τα σουπερ ντουπερ λαπτοπ διπλα στα σουπερ κινητα γιατι 600-700 ευρω για ενα κινητο δινουν οι 5/10 ενω 1.500+ για λαπτοπ δινει ο 1/10, οχι οτι δεν υπαρχουν.
Η microsoft εβγαλε σουπερ μηχανακια δεν λεω αλλα αυτο ειναι κατι που μπορουσε να το ειχε κανει εδω και πολυ καιρο, οι λογοι που δεν το εκανε και το κανει τωρα ειναι πολλοι.
Εγω προσωπικα πιστευω οτι τα συγκεκριμενα μηχανακια ειναι σουπερ αλλα ειναι ακριβα μενει να δουμε τι μεριδιο θα παρει απο την Apple.
alextrela
28 November 2011
3,129
Re: Microsoft Surface Book
Microsoft Surface Book Comes With A Custom NVIDIA GPU
http://microsoft-news.com/microsoft-surface-book-comes-with-a-custom-nvidia-gpu/
We all know Microsoft Surface Book can be bought with a discrete GPU. Microsoft has only mentioned that it is a NVIDIA GeForce Graphics Processor and they didnΚΌt reveal any technical specifications of it. Microsoft didnΚΌt announce the model name of the GeForce processor as they have built a custom GPU for Surface Book working with NVIDIA. We have confirmed that Surface Book features a Maxwell architecture-powered GeForce GPU with 1GB of video memory. I think this custom GPU will be more or less equal to GeForce GTX 950M in terms of power and performance.
Maxwell is NVIDIAΚΌs next-generation architecture for CUDA compute applications. Maxwell introduces an all-new design for the Streaming Multiprocessor (SM) that dramatically improves energy efficiency. Improvements to control logic partitioning, workload balancing, clock-gating granularity, compiler-based scheduling, number of instructions issued per clock cycle, and many other enhancements allow the Maxwell SM (also called SMM) to far exceed Kepler SMX efficiency.
When Surface team does Reddit AMA next week, I guess we will come to know more about it
Hands on: Microsoft Surface Book review
This is the new standard for Windows laptops
http://www.techradar.com/reviews/pc...etbooks/microsoft-surface-book-1306306/review
ΚΩΣΤΑΣ ΝΑΚΟΣ
29 June 2006
4,393
Είναι κάτι που πραγματικά αξίζει τον κόπο να το πληρώσεις και θα μπορεί να κοιτάζει τον ανταγωνισμό στα μάτια για πολύυυυυυυυυυυ καιρό!!!!!
Μπράβο και πάλι μπράβο μπαίνει στη λίστα με τις μελλοντικές αγορές!!!!!
alextrela
28 November 2011
3,129
Και με ρίγος συγκίνησης :flipout:
Διαφωνώ στο οτι μπορούσε πιο παλιά, διοτι τεχνολογικά μόλις στο 2013 απο την μια με τους Bay Trail Atom CPU για την low mid κατηγορία και Haswell Intel Core για την high end κατηγορία πέτυχαν να φέρουν μια ισορροπία απο άποψη επιδόσεων,θερμοκρασιών,αυτονομίας και φορητότητας.
Ειναι γνωστό οτι η πρώτη γενιά Clovair Trail Atom και Ivy Bridge Intel Core CPU tablet υλοποιήσεις υπέφεραν απο την σωστή και αποδοτική ισορροπία στους 4 εξαιρετικα σημαντικούς παταγοντες που ανέφερα που προσδιορίζουν σε μέγιστο βαθμο την εμπειρία χρήσης ενός μηχανήματος.
Εφόσον η Intel δεν είχε εξελίξει το παγκόσμιο χάρτη των CPU-GPU η MS δεν θα μπορούσε να κανει τίποτα παρα μονο να περιμένει ποτε θα ωριμάσουν οι εξελίξεις.
alextrela
28 November 2011
3,129
Exclusive Review of Microsoft Surface Book - 256GB/i5/8GB/dGPU (NVIDIA GeForce Details Included)
https://surfacebookinfo.blogspot.my/2015/10/exclusive-review-of-microsoft-surface.html?m=1
Και πλήρη επιβεβαίωση οτι χρησιμοποιείται η νέα γενιά SSD NVMe της Samsung με σχεδόν τριπλάσιες επιδόσεις ανάγνωσης/εγγραφής :Banane0::twoguns::ernaehrung004::award:
http://www.samsung.com/semiconductor/insights/news/14101
The new NVMe-based SM951 SSD achieves sequential data read and write performance up to 2,260 megabytes per second (MB/s) and 1,600MB/s, respectively, while using Samsung’s leading-edge controller technology. These performance figures are the industry’s most advanced, with speeds four and three times faster than those of a typical SATA-based M.2 SSD which usually moves data at up to 540MB/s and 500MB/s, respectively.
I finally had an opportunity to spend about 30 minutes with Microsoft Surface Book - 256GB/i5/8GB/dGPU version. Yes, the one with NVIDIA GeForce GPU (see images below for details)!
Initially, I am going to try to focus on what the other reviewers have not covered well. I will update this review with more details as time permits.
Weight
It feels light and comfortable to hold when folded like a book. The grip is nice and not slippery at all. It will not readily slip out of your hands when folded and held from the hinge side.
Weight Distribution
It feels steady in laptop mode. You won't flip it over by just writing with a pen. You have to push harder on the screen to lift the keyboard base.
The detached clipboard (screen) is thin, very light and almost feels like holding a clipboard. With an i5/i7 CPU, that's an amazing feat.
Keyboard
Keyboard is great but not as awesome as my ThinkPad X1 Carbon keyboard. It gets close though.
Display
Display is bright, sharp and well lit. With Windows 10 scaling, it is very readable at 13.5" size. The touchscreen is great. No issue there.
Hinge
The hinge is firm and built solid. But keep in mind that you can't open the display all the way flat because of the hinge design. It will stop about halfway past upright (my guess is about 45 degrees or 135 degrees from closed position when facing from front). You can however detach and flip it and then close it with screen facing up.
Also, if you want to write on the screen in laptop mode, you will need to hold the screen with one hand for stability and comfort. You could do simple diagrams without holding the screen though.
Pen
I have never had Surface Pro line before so I don't have any benchmark to compare to. I compared the OneNote pen experience with Surface Pro 4 and Surface Book and felt that Surface Book was slightly better (but this could be just an illusion in my mind). I feel that the Samsung Galaxy Note 4 phone pen is more accurate/precise when taking notes vs. the Surface Pen. Surface Book pen was very usable but not perfect in my mind. When I wrote "Hello World" multiple times in cursive at the normal writing speed, the letter "l" was about half the height of what I had expected. I had to slow down or put more pressure to get full height. Maybe there is a setting to adjust pen sensitivity that I didn't try.
Pen Eraser
Pen Eraser is fantastic. Feels just like a real pencil eraser.
TouchPad
TouchPad is great. Feels smooth like my MacBook, my ASUS ROG and my Lenovo X1 Carbon. No issue with the TouchPad .
Camera
The front facing camera quality was very good and it adjusted for low light. The back camera was good but showed some fuzzy artifacts (around the objects) if I pointed towards fast moving objects.
22 June 2006
34,866
NEO HRAKLEIO
Μετά από αυτό , λέω να μείνω με το MacBook Pro μου, για πολύ καιρό!
Ίδια σχεδόν specs, πιο ακριβό το surface , 2 φορές πιο αργό όμως. Ούτε κάν ένα layer 4K video δε μπόρεσε να παίξει στο premiere!
2 φορές πιο γρήγορο το Mac σε Lightroom Kai photoshop επίσης.
http://youtu.be/82xP8_xs-Zw
alextrela
28 November 2011
3,129
Συγγνώμη αλλα τι περίμενες.
Δεν ήξερες τα specs οταν ανακοινώθηκαν.
Το Book εχει ultra low dual core στα 15W TDP και το Mac εχει quad core στα 28 η 35W TDP.
Λογικό ειναι το ενα σε επιδόσεις να υπερέχει ολοκληρωτικά.
Ειναι σαν να μου συγκρίνεις μήλα με πορτοκάλια η i3 με i7.
Άκυρο το βίντεο του τύπου διοτι συγκρίνει ανόμοια πράγματα.
Να μου τα συγκρίνει με το αντίστοιχο dual core Mac στα 15W TDP ειναι το σωστο.
Με αυτο αποκλειστικά πρεπει να συγκριθεί.
http://www.skroutz.gr/s/7699298/Del...-16GB-1TB-256GB-GeForce-GTX-980M-FHD-W10.html
22 June 2006
34,866
NEO HRAKLEIO
Δε πάει έτσι.... Τοsurface book το συνέκριναν και στη παρουσίαση με το MacBook Pro
Η τιμή έχει σημασία επίσης.... Γιατί να πάρεις ένα υποδεέστερο μηχάνημα που ειναι πιο ακριβό;
Καθόλου άκυρη σύγκριση, αφού έναν επαγγελματία τον ενδιαφέρει η απόδοση .... Κι εκεί χάνει κατα κράτος! Ας μη συγκρίνουνε λοιπόν πορτοκάλια με μήλα!
Καλό το μηχανάκι, αλλά όχι τόσο όσο λένε.
alextrela
28 November 2011
3,129
Δεν πάνε έτσι όπως τα λες.
Πολύ μπακαλίστικα αυτά που παραθέτεις που υποδηλώνουν ότι παραγνωρίζεις βασικούς παραμέτρους πληροφορικής και συγκρίσεις 2 προϊόντων.
Το σύγκριναν με παρόμοιο hardware configuration,διοτι δεν υπάρχει ένα Mac αλλά 3-4 με διαφορετικό εξοπλισμό.
Το Macbook που αναφέρεται πάνω είναι εντελώς άλλη κλάση επεξεργαστή(ντεσκτοπ)και όχι mobile του Book.
Είναι λάθος τέτοια σύγκριση.
Η σύγκριση πρέπει να γίνει με αυτό.
http://www.skroutz.gr/s/6441744/App...-512GB-Flash-Storage-Retina-Display-2015.html
Η με αυτό στις 15
http://www.skroutz.gr/s/6907408/App...-256GB-Flash-Storage-Retina-Display-2015.html
Από εκεί βγάζεις τα συμπέρασμα.
Ο i7 του mac είναι άλλη κλάση/κατηγορια επεξεργαστης και εντελώς άλλη του Book.
Δεν είναι όλα τα i7 τα ίδια ούτε τα i5 ούτε τα i3 αλλά χωριζονται σε υποκατηγορίες ανάλογα την χρήση η το μηχάνημα που προορίζονται.
Και μεταξύ τους υπάρχουν απο μικρές έως τεραστιες διαφορες.
Η για να στο πω και αλλιώς σαν να μου συγκρινεις ενα αμαξι με 300 ίππους με ένα άλλο με 150 ίππους.
Είναι σαν να μου συγκρίνεις ένα iPhone 5 προ 3ετιας με το iPhone 6s.
Η το A6 επεξεργαστή με A9 το φετινο.
Η όπως είπα ένα i3 laptop με ένα αντίστοιχο i7.
Συγκρίνεις ακριβώς τα ίδια specs ίδιες προδιαγραφές μεταξύ 2 προϊόντων και όχι αντί άλλων και να βαφτίσεις το κρέας ψάρι.
Και από την άλλη το ένα έχει αφη το άλλο όχι, το πρώτο μπορεί να παίξει ρολο tablet το άλλο όχι, το πρώτο πιο ελαφρύ και φορητο με καλύτερη μπαταρία, το ένα υποστηρίζει γραφίδα το άλλο όχι.
Όσο για τον επαγγελματια που λες υπαρχουν χιλιάδες ειδών επαγγελματιες και δεν χρειάζονται όλοι τεράστια ισχυ εξ ου υπάρχει και Macbook 12 με Core M όπως το entry level SP4 έχει παρόμοιο.
Τώρα αν εσύ θες τέτοια ισχυς εννοείται δεν κανει για την δικια σου χρήση αλλά θα κάνει άψογα για κάποιον τρίτο αντίστοιχα.
Μην κρίνουμε αυστηρά από την δικιά μας ανάγκη αυστηρά κάθε φορα,διοτι εκατομμύρια διαφορετικές ανάγκες υπάρχουν για εκατομμύρια ανθρώπους ξεχωριστά.
tiniakos
7 August 2007
16,172
Τήνος / Ελλάς
Χωρίς να είναι υποστηρικτής της apple θέλω να θυμισω ότι η microsoft στην παρουσίαση τόνιζε ότι είναι 2 φορές πιο γρήγορο από τον ανταγωνισμό.
alextrela
28 November 2011
3,129
Ναι αλλά θα πρέπει να το συγκρίνουμε με ίδιο
Hardware configuration option.
Στο παραπάνω βίντεο του τύπου συγκρινει ανόμοια πράγματα.
22 June 2006
34,866
NEO HRAKLEIO
Αν υπήρχε θα το κάναμε, αλλά δεν υπάρχει. Από όσο ξέρω μόνο διπύρηνο i7 βγάζει η Microsoft, και μάλιστα σε τιμή πιο ακριβή από του mbpro
Κι εφόσον η τιμή του ξεπερνάει ακόμα και αυτή του mbpro , τότε έχει νόημα η συγκριση
alextrela
28 November 2011
3,129
Αυτος το συγκρινε με ένα από τα 2 στα δεξιά δεξια,ενω έπρεπε με οτιδήποτε στα αριστερά που είναι στα ίδια κυβικά με του Book.
http://www.amazon.com/gp/product/B0...o retina 15&qid=1445453027&ref_=sr_1_1&sr=8-1
Πολλές συσκευές είναι με διπύρηνος i7 στην αγορά και όχι μόνο η MS.
http://www.skroutz.gr/s/7319897/Del...ce-GTX960M-Quad-HD-Touchscreen-Windows-8.html
http://www.skroutz.gr/s/5756829/Toshiba-Portege-Z30-A-1E1-i7-4510U-16GB-512GB-SSD.html
Ο ένας είναι 15W TDP ultra low voltage που προορίζεται για συσκευές έως 1.5 κιλό και του Macbook είναι άλλη κλάση με 28 η 35W TDP που αυτόματος και χωρίς συγκριτικά να υπάρχουν το ένα είναι πολύ υποδεέστερο του δευτερου.
Εδώ ο επεξεργαστής του Macbook που λέει ο τύπος.
http://www.everymac.com/systems/app...l-graphics-mid-2015-retina-display-specs.html
http://ark.intel.com/products/83503/Intel-Core-i7-4980HQ-Processor-6M-Cache-up-to-4_00-GHz
Και εδώ του Book
http://ark.intel.com/products/88192/Intel-Core-i7-6600U-Processor-4M-Cache-up-to-3_40-GHz
Και εδώ τα benchmark test.
http://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-4980HQ+@+2.80GHz
http://www.cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-6600U+@+2.60GHz
Μιλάνε από μονα τους ποσό άκυρη η σύγκριση για να φανεί το Macbook ελέφαντας και μυρμήγκι το Book.
Αν βάλουμε αυτόν τον επεξεργαστή σε tablet form factor θα ψήσει αρνί πριν προλάβεις να πεις γειά.
Η ας το συγκρινει με το Vaio Canvas που είναι πιο στα κυβικά του και που πάλι θα υστερεί.
Ακόμα και σε σχέση με το Dell υπερτερεί ένα 40% το Macbook που είναι πιο κοντά στα κυβικά του.
https://cpubenchmark.net/cpu.php?cpu=Intel+Core+i7-6700HQ+@+2.60GHz&id=2586
http://ark.intel.com/products/88967/Intel-Core-i7-6700HQ-Processor-6M-Cache-up-to-3_50-GHz
Δεν μπορούμε να συγκρίνουμε έναν desktop top class CPU με έναν mobile που φοράει το Book.
Άλλη η χρήση τα πλεονεκτήματα του ενός και αλλά του αλλου σαν συσκευές και είναι προφανες ότι η σύγκριση στην παρουσίαση της ms έγινε με έναν παρόμοιο σε hardware configuration Macbook.
alextrela
28 November 2011
3,129
Το λάθος δε το έκανε ο τύπος, αλλά η Microsoft που επέμενε να το συγκρίνει με το MacBook Pro, στη παρουσίαση και όχι μόνο.
Κανένα λάθος δεν εκανε και πολύ σωστά το συγκρινε με το Macbook διότι Macbook δεν είναι μόνο το συγκεκριμένο quad core i7 που αναφέρει ο τύπος και εσυ αλλά η πλειοψηφία που έχει dual core CPU.
Το μόνο λάθος που εκανε είναι η αναφορά σε x2 επιδόσεις έτσι αόριστα.
Σου εξήγησα κάποια πράγματα πάνω,αμα θες να καταλάβεις έχει καλώς,αμα δεν θες μεινε στην λαθεμένη θεωρία σου και σε κυνήγι μαγισσών.
Όποιος ξερει στοιχειωδώς κάποιες βασικές γνώσεις πληροφορικής δεν θα έμπαινε καν στον κόπο να μπει σε τέτοια σύγκριση καν και μάλιστα εκ των υστέρων να καταλαβει την γκάφα ολκής που εκανε ο τύπος που πάνω στον ενθουσιασμό του σαν Apple fan του ξεφυγε και προσπάθησε να δικαιολογηθεί στον συμπληρωματικό πρόλογο που εκανε εκ των υστέρων.
Εκεί το έχασε το παιχνίδι όπως και εσύ που επιμένεις να συγκρίνεις μήλα με πορτοκάλια για να υποστήριξης μιας εντελώς εσφαλμένη συλλογιστική.
Και αναφερόμενος στην τιμή όπως μπορείς να δεις ο i7 του Macbook έχει διπλασιο κόστος από τον i7 του Book όπως σου έδειξα στα λινκ.
Αυτήν την στοιχειώδη διαφορά να έβλεπες και εσύ και ο τύπος δεν θα μπαίνετε στην λογική μήλα με πορτοκάλια.
Μάλλον και εσύ και ο τύπος ταυτίζεται όλα τα i7 είναι τα ίδια όπως αντίστοιχα τα i5 η 300 άλογα με 150 άλογα Mercedes είναι το ίδιο πράγμα στο ίδιο σασί.:flipout:
Ένταξη αφού το διαβάσαμε και αυτό τα λέει όλα.
alextrela
28 November 2011
3,129
Και τα πρώτα reviews έσκασαν ενόψει κυκλοφορίας από την Παρασκευή.
Surface Book review: the ultimate laptop, even if it isn't perfect
http://www.engadget.com/2015/10/21/surface-book-review/
Pros
•Distinctive, well-constructed design
•Impressively light as a tablet
•Gorgeous screen
•Pen input works well
•Comfortable keyboard
•Fast performance
•Best-in-class battery life in laptop mode
•Lots of configurations to choose from
Cons
•Short battery life for just the tablet
•High cost of entry
•"Fulcrum" hinge makes the laptop appear fatter when shut
•Feels heavy compared to some other flagship laptops
•Screen wobbles a bit it in laptop mode
Summary
Microsoft's first laptop raises the bar for other notebooks, with fast performance, best-in-class battery life and a design that manages to be both premium and unforgettable. The detachable screen is also comfortable to use as a tablet, thanks to both its light 1.6-pound design, accurate pen input and some well-thought-out dimensions. Overall, we recommend it, especially to people who value performance, design and battery life above all else, and are willing to pay dearly for it. We just hope that next year's model is a little lighter and that it offers longer battery life in tablet mode.
alextrela
28 November 2011
3,129
Surface Book review: Microsoft's first laptop shoots for the moon
Microsoft Surface Book review:
Microsoft's bold first laptop doubles as a part-time tablet
http://www.cnet.com/products/microsoft-surface-book/
The Good/ The Microsoft Surface Book packs high-end components, including new Intel processors and optional Nvidia graphics, into a smart, slim body. Some components and most of the battery are hidden in the base, so the tablet half is lighter. The high-res screen looks great, and the included stylus pen is excellent.
The Bad/ Configurations with the optional Nvidia GPU and more storage get very expensive. There are some first-generation quirks, including an awkward gap between the screen and base when closed.
The Bottom Line/ While it's not nearly as refined as the new fourth-gen Surface Pro, Microsoft's Surface Book is a powerful, feature-filled premium hybrid that doesn't forget it's a laptop first
alextrela
28 November 2011
3,129
Ενα εξαιρετικό άρθρο που αποτυπώνει και ξεδιαλύνει το τοπίο σε σχέση με την περίφημη φράση της MS οτι το Book υπερέχει x2 του MacBook.
Ετσι για να αφήσουμε στην άκρη θεωρίες συνομωσίας και κυνήγι μαγισσών fanboyικου επιπέδου.
Surface Book vs. MacBook Pro: It isn't twice as fast. It's three times as fast
Microsoft figured out how to put a discrete GPU into the Surface Book, and it paid off.
http://www.pcworld.com/article/2995...nt-twice-as-fast-its-three-times-as-fast.html
Microsoft claims its new Surface Book is twice as fast as its equivalent MacBook Pro. Well, we ran some benchmarks, and hate to say it, but Microsoft lied. The Surface Book isn’t twice as fast.
It’s three times as fast.
Read on for the details.
What Microsoft meant
First, let’s clarify what Microsoft meant when it said the Surface Book would smoke the MacBook Pro. The company specifically means the MacBook Pro 13 inch model. That’s a very important distinction, because the MacBook Pro 15 is a different class of laptop. It’s larger, heavier, and packs a quad-core CPU and fairly beefy AMD discrete graphics. For Microsoft to say the Surface Book out performed the MacBook Pro 15 would be absurd. It would be like Apple saying the MacBook Pro 15 outperforms, oh, an MSI GT 80 Titan SLI laptop in gaming. So the target for the Surface Book is the MacBook Pro 13. Microsoft even compares the two directly in its reviewers guide.
How I tested
For my tests, I had access to a 2015 MacBook Pro 13. But the only Surface Book I had with the discrete graphics chip had an Intel Core i7-6600U.
That's not a fair comparison, but I had a workaround. Microsoft had also provided a Core i5 Surface Book without discrete graphics. Microsoft is still pretty secretive about the GPU in the Surface Books, but I don’t believe it’s putting a different GPU in the higher-end models. I just plugged the Clipboard section with the Core i5 into the base with the graphics chip in it. Neat.
So for the record, I tested a Retina MacBook Pro 13 with an Intel Broadwell Core i5-5752U, Iris 6100 graphics, 8GB of RAM and PCIe SSD, and the latest El Capitan build. Its rival was a Surface Book with an Intel Skylake Core i5-6300U, GeForce graphics, 8GB of RAM and PCIe SSD with Windows 10.
First up were some CPU tests. Cinebench R15 is a cross-platform test that uses a real-world 3D rendering engine from Maxon. The test is pure CPU, so let’s see how Microsoft’s β€œtwice as fast” statement holds up here.
The higher clocked chip of the MacBook Pro 13 again edges past the Surface Book’s CPU
Not what you expected, PC fans? Consider the CPUs. The MacBook Pro 13 uses a pretty high-wattage, dual-core 28-watt chip with a base clock speed of 2.7GHz. That means it sticks to 2.7GHz even when under a load, and it’ll Turbo Boost to 3.1GHz. The Skylake dual-core in the Surface Book is a 15-watt chip; its minimum clock speed is 2.4GHz with a Turbo Boost of 3GHz.
Even though the Skylake CPU is faster than the Broadwell CPU in the MacBook if all things are equal, the chip in the MacBook most likely runs at higher clock speeds all the time. If you want to peep the specs of the chips in use here, I’ve lined them up at Intel’s ARK for you to compare.
In pure CPU tests, it’s often a wash and the MacBook Pro’s higher clocked CPU has a speed advantage here
Was Microsoft fibbing!?
If you’re thinking Microsoft’s mouth was writing checks its hardware couldn’t cash, take a step back. Microsoft has never told me exactly what tests it used to determine the β€œtwice” boost (believe me, I asked), but I always suspected it was mainly built around the GeForce chip.
Of the many ground-breaking features Microsoft pulled off with the Surface Book, one of the crowning achievements is that GPU under the keyboard. You can see what a difference it makes in GPU-intensive benchmarks.
First up is LuxMark 3. It’s a test designed to measure the OpenCL performance of a chip. OpenCL stands for Open Compute Language, and it’s an attempt to move general purpose CPU chores onto the GPU.
For my test I ran the LuxBall load because other workloads crashed on the MacBook Pro 13. I wasn’t sure how this one would break, as Intel’s OpenCL performance has come a long way, but the result is certainly something that’ll make PC fans happier.
LuxMark 3 is a cross-platform OpenCL benchmark. I ran it on both of the graphics chips which is where OpenCL should run.
Heaven 4.0 performance
Next I ran Unigine’s Heaven 4.0 graphics test. The test was run at 1366x768 resolution with 2x AA, no tessellation and medium quality. I did this because the MacBook Pro 13 defaulted to many of those settings when started. On the Mac, the only graphics API is OpenGL, while the PC has DirectX and OpenGL. I opted for DirectX, as I don’t think it would have been fair to use OpenGL on the PCβ€”Windows is all about DirectX, and it’s a big advantage for the platform.
Full disclosure: I ran the same test with different settings to see how the graphics in both stacked up. Most of the tests showed the Surface Book with the same big performance margin, though I could also find settings that would drag down both laptop’s performance so they were the same. Still, I think is a fair representation.
Surface Book also gets to wave good bye to the the MacBook Pro 13 in Unigine’s Heaven 4.0
Let’s try a real game
Tomb Raider really puts the MacBook Pro 13 at a huge disadvantage. If I were Microsoft PR, I’d pick this benchmark and start screaming.
The GPU in the Surface Book isn’t just about gaming. Sure, that’s a nice bonus over integrated graphics, but the GPU really plays to other applications that need more graphics performance. CAD/CAM users, for example, can use it, and other professional-level applications should see a nice bonus with the discrete graphics chip in the Surface Book. That’s why my last performance benchmark will be Adobe Premiere Pro Creative Cloud.
Premiere Pro has used GPU acceleration for years. It originally supported only Nvidia’s CUDA but has since added OpenCL. Luckily it runs on both platforms, too.
For my test I installed a Premiere Pro CC on both laptops, imported a 6.5GB 4K resolution .MOV video file, and then exported the movie to H.264 using the Vimeo preset at 1080p resolution with the maximum render quality setting enabled. On the Mac, OpenCL was used. On the Surface Book, CUDA was my choice because it’s an Nvidia chip.
The result? Another crushing blow in favor of the Surface Book. For a professional, less time spent rendering means more productivity. On the Surface Book, it was done literally minutes ahead of the MacBook Pro 13.
I leaned on Premiere Pro CC 2015 to encode a 4K H.264 file on both platforms and Surface Book pile drives the Macintosh.
Battery life
Despite having a smaller battery and a touch screen, the Surface Book edges past the MacBook Pro 13 in battery life while playing 4K video.
Απο όλα τα παραπάνω βγαίνει το συμπέρασμα οτι η αναφορά της MS πρώτα αφορούσε η σύγκριση με 13αρι MacBook όπως ειναι το σωστο βάση βάρους,φορητότητας,specs,αναλογίες διαστάσεων και κατηγορίας προϊόντων δηλαδη των ultrabook και οτι η υπέροχη βασιζόταν στην Nvidia κάρτα γραφικών οπου υπερέχει όχι μονο 2 αλλα 3 φορες στα συγκριτικά μεταξύ τους και σε αποδοση γραφικών πχ παιχνίδια αλλα και απαιτητικών εφαρμογών που αξιοποιούν την GPU.
Ακόμα και επίπεδο battery efficient και εκεί υπερέχει το Book.
Η μόνη ελαφριά υπέροχη του MacBook ειναι σε επίπεδο CPU πράγμα απόλυτα λογικό λογο υψηλότερο minimum χρονισμού και 28W TDP έναντι του αντίστοιχου Book στα 14W.
alextrela
28 November 2011
3,129
Το αποκορύφωμα ειναι το παρακάτω συμπέρασμα που βάζει τα πράγματα στην θέση τους απο όλες τις απόψεις.:twoguns:
But, but, but...
There's one last issue to address: Price. Some may argue it should be the $1,500 Surface Book against the $1,500 MacBook Pro 13.
This cuts to exactly what Microsoft is likely arguing: We figured out a way to put a GPU in a 13-inch laptop, while Apple and all other PC makers couldn’t or wouldn’t do it.
The Surface Book's premium price is what a premium is about. You can’t get discrete graphics in any MacBook Pro, but you can on the Surface Book. And the payoff is clear.
