devilman90
- 13 February 2011
- 14
Re: Max T100 - Τον έχει κανείς
Λοιπόν παραθέτω πιο κάτω το μύνημα που εστειλα και τι μου απάντησαν
εστειλα
περιμένω λοιπόν και αλλη απάντηση
Οσον αφορα τωρα το firmware
δικιο εχεις δεν υπάρχει το αρχικό το ελληνικό
εννούσα το firmware το αγγλικό της alcor
για στειλε μου ενα αρχείο με ελληνικούς υπότιτλους να δοκιμάσω
στειλε μου ενα λινκ με pm
εστειλα
Code:
hello, i am from greece and i bought
your lovely receiver but i experience one problem.
well all channels are Ok . but could a greek
menu be added on your next firware- i will
help you with the translation just send me
an english text,
the epg ican't be shown in greek too and my
major problem is the subtitles allthough they
are being showed ok there is a problem with
the greed language
i selected from the menu on language greek
and on subtitles greek again, but the result
is not the appropriate one,
what i mean is that the letters being showed
are not greek (i can't even understand what
they are-maybe there is a
decoding problem use greek-iso-8559-7 or
something that will show the subs right
i will send you a greek .srt file in order to test it
I am waiting for your prompt reply!
Keep up the good work
Yours sincerely
Panos.
μου απαντησαν
Dear Panos,
Thank you for your inquiry.
Selecting 'Greek' as the language and subtitles
are only applicable for DVB-T audio streams and
subtitles, these options do not affect the subtitle
function of the media player feature.
As far as I know Alcor HD-1500 is not intended to be
sold in Greece, therefore it doesn't have greek
localization. Of course we will try to obtain a greek
firmware from our software developer partner.
Therefore please send me some pictures of the
back panel of your device together with the serial number,
and also of the remote controller, so we can make sure
that you are using an Alcor device, otherwise Alcor's firmware
could make your device unusable.
Thanks and have a nice day,
Best regards,
Miklos KERTESZ
Brand Manager, Technical Support
Infopatika Ltd.
τους απάντησα
Thank you for your prompt reply.
Yes i know that the receiver is not sold in greece
, i ordered it from abroad, i have done all your firmware
updates through this site
http://www.alcordigital.hu/letoltes
for the hd1500 receiver and i had no problem
(except the usb(hi power low) which i figured it out
(google transaltor for the read me etc))
(when i press the english flag so as the language
of the site go english it does not show the extra
firmware updates that you have done)
(in newest firmwares stablility improved)
as far as the pictures
http://www.technikashop.hu/Images/Products/alcor_hd1500.jpg
this one shows exactly how it is
i would be gratefull to you if you could do that for me,
i dont care about the menu just the media player part(greek subtitles)
Please inform me for any new on this subject
and on every other subject done to improve the device
Panos
