macOS Sonoma 14
evanfotis
26 March 2008
5,484
… άρχισαν τα παρατράγουδα… ούτε WiFi ούτε Ethernet συνδέεται ενώ δείχνει κανονικά συνδεμένο …
ilias
9,147
Bratislava
Εβαλα το widget με τις μπαταριες και δειχνει μονο το μακ και τα ακουστικα. Το ρολοι η το τηλεφωνο δεν μπορουν να φαινονται κι αυτα ?
Μιχάλης Κορ.
21,476
Πειραιάς
Sonoma 14.1
This update provides enhancements, bug fixes, and security updates for your Mac including:
  • Favorites expanded in Music to include songs, albums, and playlists, and you can filter to display your favorites in the library
  • Apple warranty status for Mac, AirPods, and Beats headphones and earbuds are available in System Settings
  • Fixes an issue where the System Services settings within Location Services may reset
  • Fixes an issue that may prevent encrypted external drives from mounting
Some features may not be available for all regions, or on all Apple devices.
Μιχάλης Κορ.
21,476
Πειραιάς
macOS 14.2 release notes​
This update introduces enhanced Autofill for PDFs and improvements to Messages and Weather. This release also includes other features, bug fixes, and security updates for your Mac.
PDFs
Enhanced AutoFill identifies fields in PDFs and other forms enabling you to populate them with information such as names and addresses from your contacts
Messages
  • Catch-up arrow lets you easily jump to your first unread message in a conversation by clicking the arrow visible in the top-right corner.
  • Sticker option in the context menu lets you add a sticker directly to a bubble
  • Contact Key Verification provides automatic alerts and Contact Verification Codes to help verify people facing extraordinary digital threats are messaging only with the people they intend.
Weather
  • Precipitation amounts help you stay on top of rain and snow conditions for a given day over the next 10 days.
  • New widgets let you choose from next-hour precipitation, daily forecast, sunrise and sunset times, and current conditions such as Air Quality, Feels Like, and wind speed.
  • Wind map snapshot helps you quickly assess wind patterns and access the animated wind map overlay to prepare for forecasted wind conditions for the next 24 hours.
Clock
  • Multiple timers let you run several timers simultaneously and create a name for each timer.
  • Timer presets help you quickly start a timer with a range of preset options.
  • Recents makes it easy to restart your recently used timers.
This update also includes the following new features:
  • Favorite Songs Playlist in Apple Music lets you quickly get back to the songs you mark as favorites.
  • Use Listening History in Apple Music can be disabled in a Focus so music you listen to does not appear in Recently Played or influence your recommendations.
  • Shazam Music Recognition allows you to quickly identify songs playing online or around you, even when wearing AirPods.
  • New keyboard layouts provide support for seven additional languages.
koupa
25 January 2014
1,115
Ερώτηση για τις cloud υπηρεσίες. Στα Windows το OneDrive και το GDrive κάνουν ακριβώς την ίδια δουλειά συγχρονιζοντας τον προσωπικό μας φάκελο. Είναι κάτι που δημιουργεί προβλήματα και γι'αυτό το λόγο χρησιμοποιώ μόνο το OneDrive. Το GDrive μόνο μέσω web browser.
Στο macos υπάρχει πλέον το icloud. Εδώ τι παίζει; Πάλι προσπαθούν να πάρουν τον έλεγχο η έχουν την παλιά λειτουργία με ένα μοναδικό φάκελο προς συγχρονισμό;
