LOST - Season 4
Βαθμολογήστε την Σειρά:
  • Εξαιρετική
    Votes: 0 0.0%
  • Πολύ Καλή
    Votes: 0 0.0%
  • Καλή
    Votes: 0 0.0%
  • Μέτρια
    Votes: 1 50.0%
  • Κακή
    Votes: 1 50.0%
takisot
Μέλος Δ.Σ.
27,991
Παλλήνη
Αντε καιρος ηταν, γιατι ειχαμε παθει συνδρομο στερησης!
Καλο το πρωτο επεισόδιο αλλα τωρα απο τα flash backs το γυρισαν στα flash-forwards! :p
Φρα.Πε.
6,443
Ελευσίνα
Το 2ερο επεισοδειο τα'σπασε πάλι, χαμόςςςςςςςςςςςςςςςςςςςς
Πολλοι νεοι χαρακτήρες, νεα τροπή και το κουβάρι ξετυλίγεται αργαααααα
PS Aυτη η ποντικομαμή ο Μπεν ειναι μεγάλη μάρκα...
jimdamian
1,296
Episode 4.03 - The Economist
ΑΝΑΛΥΤΙΚΗ ΠΕΡΙΓΡΑΦΗ
http://link.brightcove.com/services/player/bcpid1412255475?bctid=1413085498
jimdamian
1,296
Lost Boss Outlines Revised Season 4 Plan
Carlton Cuse: It's good to be back. It'll be even better tomorrow when the writers all start rolling in and we start getting to work... pending the vote, of course.
What came out of your meeting with ABC today?
Cuse: Damon [Lindelof] and I are going to try and make five more episodes before the end of May, which is ambitious. But, we've found ourselves in situation where we had eight episodes of story planned, and we're going to try to fit that into five hours of the show. Even though it's going to be very hard to execute, we felt like any less would be doing a disservice to the story we had planned. We really want to give the fans the best possible experience and ending that we can to Season 4.
Any chance that the first of the five episodes will air the week after that last pre-strike episode— thus eliminating any scheduling gap?
Cuse: No, there's probably going to be four weeks between the airing of the first batch of episodes and our new episodes.
What will happen to the three "lost" episodes? Will they roll over into next season's 16, or will they vanish forever?
Cuse: Damon and I remain committed to producing the 40 additional hours of the show that we promised. We haven't figured out exactly when we'll put those other three on, but we're not eliminating them from the show. You will get those three episodes downstream.
I know it's early, but have you decided what will have to get cut from this season's arc in order to accelerate things? Are we going to lose some flashbacks and/or flash-forwards?
Cuse: All those conversations will take place tomorrow when we actually start talking about story.
Is it possible that some guest actors you were planning to use before the strike may no longer be available now? Like, for example, Andrea Roth?
Cuse: Yeah, there are a lot of issues that have to get sorted out. We're also in the middle of pilot season... We're kind of figuring out what has happened to all of our actors who have gone on to do other things. Literally, there are cobwebs on the couches in the writers' room. Call me in a couple of days and I should have more answers for you.
OK, last question: Have you come up with a code word for this season's top-secret cliffhanger?
Cuse: [Laughs] Not yet. That's a very good point. We'll have to get on that. If you have any ideas, Mike, let us know.
jimdamian
1,296
ΑΝΑΚΟΙΝΩΣΗ
LOST: Part two of season 4 to start April 24th
Lost is back! Oh, wait, that happened two weeks ago.
What I mean is, Lost will be back-back, after the strike.
And even better, we've just checked in with inside sources, and we have dates!
Yes, dates!
So, break out your calendars, 'cause we're hearing this is the approved plan:
The last episode of the current pod (episode seven) will air Mar. 13.
Then the show will be off the air for six weeks and return Apr. 24 at 9 p.m.
(That Apr. 24 episode will be the already-completed episode eight, which was filmed prestrike, but which apparently works much better as a minipremiere than it does as a minifinale.)
Καλυτερα ετσι παντως να περιμενουμε 6 βδομαδες αλλα θα δουμε μια full season με συνολικα 16 επεισοδια !!!!
greg
926
Γλυφαδα
Παιδιά το επεισόδιο 5 τα σπάει... Δεν ποσταρω σποιλερ απλά πρέπει να το δείτε οπωσδήποτε..
softice
28 October 2007
2,078
Επιτέλους.
Πολύ τον είχαν παραγκωνίσει τώρα τελευταία τον καλύτερο χαρακτήρα της σειράς imo.
nutsis
25 November 2006
776
Κερκυρα
Βρε παιδια η 4η περιοδος αρχιζει και εχει απαιτησεις απο το κοινο.
Για να μπορουμε να κανουμε μια αξιοπρεπη θεαση πρεπει να κατανοουμε
εξεζητημενες θεωρίες φυσικής και μεταφυσικής.
Εχει ξεφυγει τελειως απο οτι μας εμφανιζε εως και στο τελος του 2ου κυκλου.
Ασε που πρεπει να θυμομαστε λεπτομερειες απο 70+ επεισοδεια.
Επισεις υπαρχουν στοιχεια ορατα - αορατα σκορπισμενα σε καθε επεισοδειο που δεν φαινονται αμεσως.
Αν ειναι να βλεπω καθε ενα 2-3 φορες, να τρεχω στην βικυπαιδεια σε αρθρα για καμπυλοτητες του χωροχρονου, και πως χώρος και ο χρόνος είναι ανεξάρτητα στο χωροχρονικο συνεχες, στο τελος της 4ης παμε για ρεκτιφιε στα εγκεφαλικα κυτταρα .
Και εγω τωρα πρεπει αυτα να τα εχω προχειρα στη RAM μυαλου μου;
