Απάντηση: Re: LG7000 ... η Scarlet ωρίμασε ...
ε..ειπαμε οτι πρεπει να εισαι και ευαισθητος τυπος:grinning-smiley-043
New LCD TVs come with improved response time
However, LCD manufacturers in the recent past found two ways to minimize the ghosting. One such way is to decrease the screen size as ghosting is not much visible smaller panels. Another way is to use a technique called overdriving which uses black-to-gray and gray-to-gray transitions.
Newer LCD TVs adopt two methods to reduce the response time to eliminate the ghosting.
According to first method, the backlight device is fired at a rapid rate which will be usually less than the screen refresh rate. However, this method is likely to result in flickering which can be perceptible by eyes.
The second method is to use ‛motion compensation’ which actually doubles the screen refresh rate and produces transitional frames. Most high end LCD TVs combine these two techniques in their LCD
βαλτε στο γκουγλη LCD TV + flickering και θα βρειτε πολλα αποτελεσματα.
εχω δει σε samsung αλλα δεν θυμαμαι μοντελο
Δηλαδή βλέπεις flicker σε LCD των 50 Hz ?
Απορώ πως επέζησες με τις CRT τόσα χρόνια
