- 29 October 2008
- 8,991
-LG HU85LS-
Νέος LG HU85LS...https://perfectimage.gr/2019/07/22/νέος-lg-hu85ls/
source:[perfectimage.gr]
DLP: 0.66" DMD chipset from Texas Instruments
native resolution: 2716 x 1528 pixel
pixel shifting projector:not native 4K,τεχνολογίας XPR που μετατοπίζει pixels σε δύο άξονες
three-channel laser light:dual laser engine design for LG,τρία laser: δύο μπλε και ένα κόκκινο. Ένα φίλτρο πράσινου χρώματος είναι τοποθετημένο μπροστά από ένα από τα μπλε λέιζερ.
built-in sound system :10W,two speakers,
supports Dolby Surround, DTS-HD and Dolby Atmos
built-in webOS 4.5 platform
controller :standard LG Magic remote
HDMI 2.0b x2, 4K/60p, HDR10, HDCP 2.2, ARC and HDMI simplink (CEC)
can accept up to a 4K (4096 x 2160) at 24/50/60Hz over the HDMI inputs and USB Type C port.
three USB 2.0 ports (two Type A and one Type C)
S/PDIF optical digital output x1
RJ45 Ethernet port x1
Bluetooth
26dB in the Economic mode,
28dB in the Normal mode,
and 30dB in the High Brightness mode
primarily designed for stand placement, LG does offer the option of ceiling mounting the projector using a bracket (not included)
Power Consumption (Max.):350W
680 x 128 x 347mm (WxHxD)
weight :12.2kg
We review the LG HU85LS (also marketed as the HU85LA in the USA, with the key difference being the inbuilt tuner) CineBeam 4K ultra short-throw (UST) laser projector, which uses a 0.66" DMD chipset from Texas Instruments.
Topics covered in this LG HU85 review include :
black level,
colour accuracy,
motion performance,
video processing including upscaling, HDR, and input lag for gaming.
Even though the LG HU85LS/ HU85LA DLP projector apparently doesn't use a colour wheel, we still saw some rainbow effect (RBE) very rarely.
https://www.youtube.com/watch?v=PsDUawZx1ic
source:[hdtvtest.co.uk]
LG HU85LS review...https://www.avforums.com/reviews/lg-hu85ls-cinebeam-laser-4k-projector-review.17748
source:[avforums.com]
LG HU85LA test...https://www.passionhomecinema.fr/blog/index.php/28/08/2019/test-lg-hu85la-lavis-de-gregory/
source:[passionhomecinema.fr]
