HDAD ripping
ln()
1 February 2007
5,780
Βόλος
Δεν ξέρω πώς γίνεται, αλλά το HDAD 24/96 είναι απλό DVD-Video με PCM ήχο. Οπότε αν έχεις πρόγραμμα για να "τραβήξεις" τον PCM ήχο από οποιοδήποτε DVD-Video μπορείς να μεταφέρεις και στον σκληρό το 24/96 του HDAD.
Γιώργος ΚΟΨ
20 June 2006
2,899
GLYFADA
Βαγγέλη πιθανά να σου κάνει και το dvd-audio extractor
DVD Audio Extractor is a powerful software DVD audio extracting / ripping tool. It can help you to extract audio streams from your favorite DVDs and save them as OGG, MP3, Wave or FLAC files. DVD Audio Extractor can also demux audio streams directly to pcm, mpa, ac3 or dts files. The newly added CD Image creating feature allows you to convert DVD to Audio CD in one step.
DVD Audio Extractor features on its easy-to-use interface, ultra-fast extracting speed, rich audio formats support, multi-channel capability, resample to arbitrary sample rate, audio preview and much more. It's all what you needed to get audios out of DVD-Video discs, so that you can listen on MP3 Player, play on PC, record to CD or do anything else.
http://www.castudio.org/dvdaudioextractor/
