[ Επίσημο ] AirTag @ 2021
songless_bird
8 May 2013
11,133
Νότια Μακεδονία
Τι να το κανεις, αν δεν έχεις εκτενές δίκτυο;
Σοβαρά τώρα; οι συσκευές samsung είναι περισσότερες από τις ios . Απόδειξη ότι το airtag της samsung έχει μεγαλύτερη ακρίβεια ακομη στην απλή έκδοση ΒΤ χωρίς uwb σε όλα τα review.
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Από ότι διαβάζω, το σύστημα offline location της Apple θα λειτουργεί μόνο για όσες συσκευές της έχουν το U1 chip (Ultra Wideband) και θα μπορεί να εντοπίσει τις συσκευές ακόμα και αν τους έχει γίνει full restore η είναι power reserve mode (ένα κλικ πριν μείνουν από μπαταρία).
One of the most exciting features of iOS 15, which was announced at WWDC 2021 in June, is definitely the Find My tracking when the device is completely turned off. However, not every device is compatible with this feature. Read on as we detail which Apple devices support Find My when turned off with iOS 15.
With iOS 13, Apple has implemented a new version of its Find My network that works offline. It uses Bluetooth technology to send the location of a lost device to other Apple devices nearby. This way, users can see the location of an iPhone, iPad, Mac, or Apple Watch even when it’s not connected to the internet.
Now with iOS 15, Apple has gone one step further and finally allowed powered-off devices to be tracked through the Find My network. Not only that, but the company says that devices running iOS 15 can be located even after a full restore. The only way to disable Find My now is by removing the iCloud account of the device’s original owner.
Unfortunately, due to technology limitations, only some iPhone models can be located when turned off. You can check the full list below:
iPhone 11
iPhone 11 Pro
iPhone 11 Pro Max
iPhone 12 mini
iPhone 12
iPhone 12 Pro
iPhone 12 Pro Max
This new feature is based on Ultra Wideband (UWB) technology, which is part of Apple’s U1 chip. Only iPhone 11 and newer models (except for the second-generation iPhone SE) have the U1 chip, so that is why only these devices will work with Find My even when turned off. Apple Watch Series 6 also has the U1 chip, but the feature is exclusive to iPhones so far.
If you have an older iPhone or even any iPad model, you will still be able to use Find My when your device is offline but not completely turned off. Here’s how the new feature is presented in the Settings for an iPhone with a U1 chip compared to other devices, both running iOS 15:
According to Apple, supported devices can also be located through Find My when in Power Reserve Mode. In other words, tracking works even if your iPhone runs out of battery, just like Express Transit with Apple Pay. It’s almost as if this feature turns your iPhone into an AirTag
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Σοβαρά τώρα; οι συσκευές samsung είναι περισσότερες από τις ios . Απόδειξη ότι το airtag της samaung έχει μεγαλύτερη ακρίβεια ακομη στην απλή έκδοση ΒΤ χωρίς uwb .
Σοβαρότατα. Προφανώς δεν είναι περισσότερες οι συσκευές που μπορούν να υποστηρίξουν το find my network (το οποίο υπάρχει εδώ και δεκαετία στα iPhones και μόλις εσχάτως στον ανταγωνισμό), ενώ είναι ελάχιστα τα μοντέλα της με ultra wideband chip.
Για το δεύτερο, τα έχεις μπερδέψει. Δεν μπορεί να έχει μεγαλύτερη ακρίβεια το απλό BT σε σχέση με το uwb. Απλά ίσως έχει μεγαλύτερη τοπική εμβέλεια το ΒΤ (ισχυρότερο σήμα).
songless_bird
8 May 2013
11,133
Νότια Μακεδονία
Ακομη χειρότερα δηλαδη . Τα samsung δεν χρειάζονται uwb για να το υποστηρίξουν και το κάνουν ακόμη και αν έχεις κλειστά bt και wifi και κλειστή την συσκευή. Επίσης πριν τελειώσει η μπαταρία και κλείσουν στέλνουν αυτόματα την τελευταία πραγματική τοποθεσία. Συσκευές των 150€ και όλες με το UI 3.1... Δες πως λειτουργεί της apple οοοοοοταν το έχεις και άσε τις υποθέσεις για τον ανταγωνισμό που το έχουν εδώ και 1 χρόνο... Τα reviews των airtags σε διαψεύδουν πάντως . Η συσκευή μου δεν έχει uwb και μια χαρά την βρίσκω offline.Screenshot_20210816-164122_Find%20My%20Mobile.jpg
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Ακομη χειρότερα δηλαδη . Τα samsung δεν χρειάζονται uwb για να το υποστηρίξουν και το κάνουν ακόμη και αν έχεις κλειστά bt και wifi και κλειστή την συσκευή. Επίσης πριν τελειώσει η μπαταρία και κλείσουν στέλνουν αυτόματα την τελευταία πραγματική τοποθεσία. Συσκευές των 150€ και όλες με το UI 3.1... Δες πως λειτουργεί της apple οοοοοοταν το έχεις και άσε τις υποθέσεις για τον ανταγωνισμό που το έχουν εδώ και 1 χρόνο....View attachment 184135
Εχμ, μα τι λες. Πως θα τα βρεις χωρίς uwb?
Με σήματα καπνού;
Όσο για το τελευταίο location, το έβρισκες πάντα στο find my εδώ και δέκα χρόνια…
songless_bird
8 May 2013
11,133
Νότια Μακεδονία
Με σήματα καπνού;
Χρησιμοποιεί το bt και το wifi ακομη και το nfc. Αφού τα airtags είναι συμβατά και με παλαιότερα iPhone χωρίς U1.. Η έκδοση με uwb απλά προσφέρει ακρίβεια εκατοστων με AR και λίγο καλύτερη ακρίβεια στα Samsung ενώ στην γενική χρήση δεν έχει καμία διαφορά από το απλό ούτε στην απομακρυσμενη εύρεση μέσω Samsung network..Κοίτα τα review με το απλό Samsung smarttag χωρίς uwb...
Άκου δεν έχει δίκτυο η samsung...
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Μήπως έχεις μπερδέψει το offline mode που μπορεί να κάνει (και) το Samsung με το τελείως σβηστό location που κάνουν τα iPhones με U1 chip?
Γιατί αυτό διαβάζω στο site της Samsung:
Offline devices
can still be found
Once Offline Finding is enabled, your Galaxy is detectable as long as it's turned on - even
when mobile data is disconnected. Other Galaxy devices will participate in the search for your Galaxy as 'helpers',
sending signals into the server that share your lost phone's location. So enable offline finding and become a helper now and you'll be in good hands in the case of a missing device later on
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Ναι, αυτό λοιπόν υπάρχει χρόνια στα iPhones (Find My).
Το νέο, στο οποίο αναφέρομαι και ΔΕΝ υπάρχει στον ανταγωνισμό είναι η δυνατότητα εντοπισμού με ΣΒΗΣΜΕΝΗ (η ακόμα και fully restored η σε battery reserve mode) συσκευή μέσω του U1 chip.
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Και από εκεί και περα, αναφορικά με το θέμα της έκτασης του δικτύου Find My, δεν υπάρχει τίποτα στον ανταγωνισμό που να πλησιάζει το ένα δισεκατομμύριο ΕΝΕΡΓΑ iPhones, κάτι που προφανώς επιτρέπει το γρήγορο location tracking όπως στα παραδείγματα που αναφέρθηκαν.
songless_bird
8 May 2013
11,133
Νότια Μακεδονία
Μιλαω ότι λειτουργεί ΤΩΡΑ η εύρεση σβησμένης συσκευής Samsung χωρίς uwb chip . Ακομη και σβηστή η συσκευή χρησιμοποιεί το bt και το wifi για εύρεση κοντινης συσκευής Samsung. Δεν έχει σχέση με αυτό που έχουν τώρα τα iPhone αλλά με αυτό που ΘΑ έχουν.. Ακομη και να τα κλείσω χειροκίνητα bt και wifi από την στιγμή που έχω πει οκ στην εύρεση συσκευής τα χρησιμοποιεί για αυτό τον λόγο. Την επέκταση του δικτύου της samsung σε όλες τις συσκευές της . Οχι μόνο αυτές με U1 .... Μην υποθέτεις για κάτι που έχουμε εδώ και 1 χρόνο και εσύ ΘΑ πάρεις....Αν η apple δεν μπορει ή δεν θέλει να ανοίξει την υλοποίηση και σε μη U1 συσκευές δυστυχώς αφορά 1 δις χρήστες της
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Έχεις κάποιο πειραματικό μοντέλο;
«Once Offline Finding is enabled, your Galaxy is detectable as long as it's turned on - even
when mobile data is disconnected»
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Δυστυχώς δεν προσεχεις τι γράφω. Η επέκταση του δικτύου FindMy ισχύει για όλες τις συσκευές apple ακόμα και αρχαία iPhone 4.
Τα μοντέλα με U1 chip μπορούν να εντοπιστούν ακόμα και αν είναι σβηστά, restored η σε με σχεδόν άδεια μπαταρία.
leonkoum
20 December 2008
4,894
Παιδια μια απορια...
Διαβαζω οτι η apple κυκλοφορισε νεο fw το 2.0.36 ΟΜΩΣ πολυς κοσμος εξω αναφερει οτι εχοει ακομα το παλιο 2.0.24 ή ακομα το παλαιοτερο 1.0.301
Και τα δικα μου εχουν 'κολλησει' στο 1.0.301 εδω και καιρο.
Τι παιζει με αυτα?
takisot
Μέλος Δ.Σ.
27,928
Παλλήνη
Τι παιζει με αυτα?
Κάποια στιγμή κάνουν μόνα τους update. Δεν μπορείς να το εκβιάσεις.
Μιχάλης Κορ.
21,492
Πειραιάς
Πρέπει να είναι στον ίδιο χώρο το airtag με το κινητό σου, συνδεδεμένο στο διαδίκτυο βέβαια και κάποια στιγμή κάνει μόνο του update, όπως κάνουν πχ και τα airpods.
