[B]Enigma2 Changelog:[/B]
aa6f644 french translation (2015/07/27). Change the "commit" string (suppress sourceforge) and small fixes.
e62f508 Merge pull request #13 from athoik/allow_user_defined_cable_and_terrestrial
ce066cd Merge pull request #6 from Taapat/pull
d800ffe Cosmetic: remove execute bits from non executabe files
02acb3f Allow user defined cable.xml and terrestrial.xml under /etc/enigma2 just like we do for satellites.xml
cc1f41e Merge pull request #9 from christophecvr/master
e367703 Servicemp3 bug in delayed subtitles.
a57202e Restore some translations in lv.po removed on automatic parse
f75bfcd Update Latvian translation
3c74d67 SoftwareUpdate: Now we are on github do not show commits on sourceforge
578e7a1 latest Polish translations update (POT-Creation-Date: 2015-07-13 22:21+0200)
0319f39 Merge pull request #5 from christophecvr/master
8a70f71 Merge pull request #3 from athoik/remove_dead_code
570eba6 Merge pull request #2 from athoik/dont_delete_gstreamer_cache
768dc68 Extrenal srt problem gst-1 solved. To have all the media always in sync. Subtitles must run in sync by gst-1. Since by base enigma2.bb file for gst-1. The patch disable sub is not there anymore. For gst-1 the subtitle sync is enabled by default. The extren subtitles can have from time to time a warning. That's now solved and all subtitles internal/extrenal, Are starting well and synced.
bd5b8e2 About: Remove the old sourceforge latest commit parser
2f4e045 Improvement off code by cuesheet servicemp3
0847201 Extra correction for gst-1 start sequence. After fresh reboot the movie went't sometimes to early to play state. For gst-1 playbin may only go to playing after , all settings are done.
e09852c Merge pull request #4 from athoik/fix_github_commit_log
25603bf About: read commit logs from Github using json api
59d66ec servicemp3: remove dead code from getTrackInfo
44d3629 enigma2.sh: don't delete GStreamer cache on reboot
b348b25 get rid of hardcoded TS packetsize
5cd3124 update skin_display_et8500.xml
acf1245 PliExtraInfo: frontend data unknown return empty string
914b336 Merge pull request #1 from Dima73/master
893fa95 Merge branch 'OpenPLi/master'
4a6b43e Standby: fix stop service in standby if box automatic wake up, e.g. for record timer
9f16d43 PliExtraInfo: Indicate also data in case of streamed services
34ade29 ScanSetup: add missing FEC_Auto option in S2 transponder parameters
952a179 Estonian translation Cosmetic treatments: Thanks to err23
c6061e6 Small correction on cuesheet support servicemp3.
97b9b3b servicemp3: Solution for CD with more than 9 tracks
[B]61a22ab IPTV recording in E2[/B]
864e55b Corrected start sequence off servicemp3 in e2. Only applicable to gst-1 branch. After that the servicemp3 is initiated and playbin started, the playbin is going to paused. Once all media info concerned video,audio and or subititle is obtained and set, playbin state will be changed to playing. Thanks to this there is not and to early out off sequence start from gstdvbvideosink and gstdvbaudiosink anymore.
1ed8d99 Added chapter support for servicesMP3 Movies.
ed18157 Added cue-sheet to servicemp3.
16eadc0 OSD3DSetup: Add sanity check
1d081bd Fix issue when justplay timer is busy and you start instant recording
08915ce Streamline double timer check in TimerSanityCheck
f3a803c Estonian translation 1st July 2015 Harmonization: Thanks to rimas Thanks to Pr2 and his constant renewal enigma2.pot
2e39560 French translation, added new strings and some corrections, thnx Pr2
d2fd924 Updated Slovakian translation, thnx Janda
5871fcf Solve ScanSetup Issues with DVB-T2
080c9b3 Update estonian translations by Zeros and Very small cosmetic in enigma's cs.po by Ims
0eb39a5 new option for "Location"
75296f7 Sanity check when is changed dir - due changes in Filelist.
c328db9 Fix various problems with et7000/et7500/et8500 remote control configuration.
b78a10b Update for French po files, thnx Pr2.
bf59b43 Updated Latvian translation with latest gettext and terrestrial changes from Dima73.
9a20448 add gettext title
3e19d46 added gettext plugin name and description
18037d3 Fix problem with the logic of the top directory
448dd73 Update Estonian translation, Thanks to Henkka, rimas, Scott, rootsikunn, Filmix
7b7a471 MovieList: Solve an issue with a check that always failed
68aa47e Estonian translation 7 June 2015 et.po Thanks to rimas & our users. Once more, The main thanks to Henkka
69be7f5 TimerSanityCheck: Solve check with alternatives
f150e07 skip_t2 move as the last parameter
d8ed137 added new vuplus t2 scan and sundtek hardware blindscan t/t2
c3b3034 Update Estonian translation, thanks to rimas
367f889 French translations for e2 updated, no new strings but some cosmetics changes and some typo errors fixed, Thnx Pr2.
506e730 Revert "Add screensaver to MovieSelection preview mode"
680dab5 Revert "Small finetunning to the ScreenSaver in MovieSelection"
b37ab7f Revert "MovieSelection: Remove identical keypressScreenSaver method"
3857402 UsageConfig: write str(i) instead of "%d"%i
0f4cdcb UsageConfig: Simplify timeout choices for screensaver
6d19d44 MovieSelection: Remove identical keypressScreenSaver method
d39dd98 Update Estonian translation Credits : - The main translation: Henkka - Update, Control & corrections: zeros - Beta testing and screenshots: rootsikunn
869716d bsod: remove unused getConfigBool
46775c7 Only close movieplayer list in standby when parental locked is involved
5107787 eSocket: Inline getDescriptor
b7366e3 network/socket.cpp: Fix high CPU usage while not in standby
689036e Revert "Revert "socket: use getaddrinfo""
500532d Small finetunning to the ScreenSaver in MovieSelection
0627586 Add screensaver to MovieSelection preview mode
1abb908 Update norwegian bokmal language, thnx andy1
28618e4 Revert "socket: use getaddrinfo"
44eaeed enigma2.sh: add export for HOME.
3b2ee8c Omit only short auto tags. Real tags will not be omitted, no matter how short they are
73ee025 epgcache: Allow Python threads to run while searching EPG text
cfab223 eEPGCache: Don't access iterator after erase
d743e97 socket: use getaddrinfo
757930a Revert "eEPGCache: Don't access iterator after erase"
bdbf6ba eDVBCAHandler: Prevent memory access of out of scope local variable
b0838e5 eMainloop: Prevent invalid read in valgrind
626f02e eEPGCache: Don't access iterator after erase
35eaa94 eDVBLocalTimeHandler: Don't access iterator after erase
f864997 gRC: Initialize variables before use
b3ed586 Revert "socket: use getaddrinfo"
60bbfb7 Revert "serversocket-remove-unused-variable-res-in-eServerSo"
c5c9635 serversocket-remove-unused-variable-res-in-eServerSo
d197755 socket: use getaddrinfo
[B]OE-Core Changelog:[/B]
853408f Remove sourceforge SVN packages tuxcom and tuxterm
863c3f9 tuxbox-common: Move to github and sanitize recipe
3e78b5c tuxbox-common: Pin release 373 to prevent build failure on sourceforge being offline
50d859e mut@nt: update bsp
0e6a3f1 New download location for dvbsnoop 1.4.50
fed0c5a Remove ambx plugins
88bd34d Move to github part 2
843b977 enigma2, plugins, pliplugins: Move to github
f0420d9 LCD4Linux: switch to 4.5-r5.
707c42c meta-vuplus: update bsp
6d2de6d mut@nt: update bsp
9261e76 formuler: update bsp
4626541 libdvdnav, libdvdread: to latest upstream versions
9431435 xmltvimport-rytec: Update to 2015-06-29
111c3ed add new remote control for dreambox
ce7e74e Update HansSettings to 03July2015
79c045d Package didn't build correct due the use of spaces in the sources on git. also a lot of changes in the settings.
49f96dd Activate building the icesat-channelsettings.
4bde55e Added icesat/Enigma2-settings-13.0E-19.2E-23.5E-28.2E settings to the build environment
f38d7e1 meta-vuplus: update bsp
fe54920 formuler: update bsp
d28fb82 formuler: update bsp
de9b61a add new image box and remote control
20c552f meta-vuplus: update bsp
5a6a409 mut@nt: update bsp
dbe419b Updated HansSettings to June-02-2015
9119f50 Adjusted the descripion of the Ziggo cable settings, and some services didn't work, so rescanned the cable for new services ...
92138be Removed old settingslists, due the merge of UPC and Ziggo there's only one cable provider left.............
b1ca7bd Clean cable settings lists
8c3c09d Update Henksat Ziggo settings
a24d749 meta-vuplus: update bsp
1a736e3 mut@nt: update bsp
