Exact Audio Copy V1.1 from 23. June 2015
EAC extraction logfile from 5. June 2016, 21:36
Παντελής Παντελίδης / ΟΥΡΑΝΙΟ ΤΟΞΟ ΠΟΥ ΤΟΥ ΛΕΙΠΑΝΕ 2 ΧΡΩΜΑΤΑ
Used drive : hp CDDVDW TS-L633J Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 0
Overread into Lead-In and Lead-Out : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 768 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -8 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "TOTALTRACKS=%numtracks%" -T "GENRE=%genre%" -T "ALBUMARTIST=%albumartist%" -T "ALBUM ARTIST=%albumartist%" -T "COMMENT=EAC Secure Mode, Test & Copy, AccurateRip, FLAC -8" %source%
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 3:51.08 | 0 | 17332
2 | 3:51.08 | 3:29.52 | 17333 | 33059
3 | 7:20.60 | 3:12.30 | 33060 | 47489
4 | 10:33.15 | 4:10.00 | 47490 | 66239
5 | 14:43.15 | 3:53.29 | 66240 | 83743
6 | 18:36.44 | 4:36.17 | 83744 | 104460
7 | 23:12.61 | 3:39.29 | 104461 | 120914
8 | 26:52.15 | 3:36.17 | 120915 | 137131
9 | 30:28.32 | 4:04.54 | 137132 | 155485
10 | 34:33.11 | 4:06.19 | 155486 | 173954
11 | 38:39.30 | 3:35.57 | 173955 | 190136
12 | 42:15.12 | 4:13.55 | 190137 | 209166
13 | 46:28.67 | 3:03.51 | 209167 | 222942
14 | 49:32.43 | 3:50.53 | 222943 | 240245
Track 1
Filename C:\Users\Νick\παν\01 Οίκος Ανοχής.wav
Pre-gap length 0:00:02.00
Peak level 100.0 %
Extraction speed 0.9 X
Track quality 99.9 %
Test CRC 4D8001EC
Copy CRC 4D8001EC
Copy OK
Track 2
Filename C:\Users\Νick\παν\02 Τέτοια αγάπη δεν αξίζω.wav
Peak level 100.0 %
Extraction speed 1.1 X
Track quality 100.0 %
Test CRC B7F2BEF4
Copy CRC B7F2BEF4
Copy OK
Track 3
Filename C:\Users\Νick\παν\03 Κλάματα.wav
Peak level 100.0 %
Extraction speed 1.2 X
Test CRC F6235DD6
Copy CRC F6235DD6
Copy OK
Track 4
Filename C:\Users\Νick\παν\04 Φύγε απο το μυαλό μου.wav
Peak level 100.0 %
Test CRC 3E07E3D6
Copy CRC 3E07E3D6
Copy OK
Track 5
Filename C:\Users\Νick\παν\05 Κλάματα.wav
Peak level 100.0 %
Test CRC 88E53F3C
Copy CRC 88E53F3C
Copy OK
Track 6
Filename C:\Users\Νick\παν\06 Τα παπλώματα.wav
Peak level 100.0 %
Test CRC 28C92788
Copy CRC 28C92788
Copy OK
Track 7
Filename C:\Users\Νick\παν\07 Κόψε με στα δυο.wav
Pre-gap length 0:00:01.02
Suspicious position 0:02:19
Suspicious position 0:03:07
Peak level 100.0 %
Extraction speed 0.2 X
Track quality 98.6 %
Test CRC B03B32C2
Copy CRC 866E51C9
Copy finished
