Όπως ανάφερα και σε άλλο θέμα υπάρχει και dark chip 4. Αν δεν κάνω λάθος η τεχνολογία dlp όπως και τα dark chip είναι όλα ανακαλύψεις της Texas Instruments.
Ένα αρκετά διαφωτιστικό post που με βρίσκει σύμφωνo είναι το post 3 στο
link που παραθέτω.
''If you are looking for sharpness then a .95" DMD Darkchip4 or Darkchip3 DLP 1080p projector is the best option. Most new DLP projectors use the less sharp .65" DLP chip. Unfortunately they stopped incorporating these into under $10k models a couple of years ago. The cheapest new model that has a Darkchip4 is the DPI Cine 230 for $7000, above budget. There is also the Runco LS-5 that uses Darkchip3, you may be able to find a reduced/ex-demo one for the price you are looking at but they tend to retail around $6000.
As you have light control then I would try to pickup one of these second hand, if you look on ebay or Videogon then they do pop up for time to time:
Marantz 15S1
Sim2 HT380
Sim2 D80E
Samsung A900B
All of the above have Darkchip3 .95" DLP chips. If you are lucky then you may be able to get these Darkchip4 projectors in that price range but I haven't seen any
Sim2 Ht3000e
Marantz 11S2''
