Dell Venue 8" & 11"
alextrela
28 November 2011
3,129
Ο διάδοχος με Intel Core M είναι προ το πυλών προς κυκλοφορίας για το Venue 11 Pro.
Dell is giving the Venue 11 Pro tablet an Intel Core M makeover
http://liliputing.com/2014/10/dell-giving-venue-11-pro-tablet-intel-core-m-makeover.html
alextrela
28 November 2011
3,129
Φως στον ορίζοντα με επικείμενο διάδοχο επιτέλους μετά ξηρασία 2 ετών από Dell
Next-gen Dell Venue 8 Pro to feature Cherry Trail CPU, full HD display?
http://liliputing.com/2015/09/next-gen-dell-venue-8-pro-to-feature-cher
ry-trail-cpu-full-hd-display.html
Dell may be planning to update its line of 8 inch Windows tablets with a new mode featuring a faster processor and an optional higher-resolution display. According to leaked documents obtained by Giga, there’s one thing that the new Dell Venue 8 Pro will have in common with older models: support for a Dell Active Stylus.
If the slides published by Giga are accurate, here’s what we can expect from the new Dell Venue 8 Pro 5000 series (5855) tablet:
’8 inch screen with 1280 x 800 and 1920 x 1200 display options
’Intel Atom x5 Cherry trail processor
Windows 10
802.11ac WiFi, Miracast and WiDi wireless display, and NFC
USB Type-C port
Support for a Dell Active Stylus for pressure-sensitive writing or drawing
There’s also an optional 3D depth-sensing camera, optional support for 4G LTE and/or HSPA+ and optional docking stations that add HDMI, VGA, Ethernet, and USB ports
alextrela
28 November 2011
3,129
Με καθε επισημότητα το ανανεωμένο μικρό Venue 8 Pro ένας πραγματικός άξιος διάδοχος με Wacom και Cherry Trail under the hood.
Dell’s new Venue 8 Pro tablet has faster CPU, WiFi, and more
http://liliputing.com/2015/09/dells-new-venue-8-pro-tablet-has-faster-cpu-wifi-and-more.html
Dell is updating its Venue 8 Pro line of Windows tablets with a new model that means business.
The new Dell Venue 8 Pro 5000 Series tablet features a sturdy MIL-STD tested case, support for a Wacom digital pen, and optional 4G LTE and NFC. It also has a USB Type-C port which will let you connect a desktop docking station (due out in 2016).
Dell says the new Venue 8 Pro 5000 Series tablet will be available in North America soon for $299 and up.
The tablet will be available with either a 1280 x 800 pixel or a 1920 x 1200 pixel touchscreen display. Both models support 802.11ac WiFi, Windows 10 software, and feature Intel Atom processors.
Dell isn’t saying exactly which Atom processor powers the tablet, but if the leak we saw earlier this month is correct, the tablet will likely have an Intel Atom x5-8500 Cherry Trail processor.
22 June 2006
34,878
NEO HRAKLEIO
μολιις απεκτησα ενα μεταχ/νο dell venue 11 pro , me ι5 , 4GB RAM kai 128GB SSD.
Σε τετοια τιμη (400 ευρω) δε νομιζω να βρισκει κανεις τετοιο μηχανημα....
Τρομερη ταχυτητα , πολλη καλη και φωτεινη οθονη, usb 3 , ωραιο πληκτρολογιο (και με μπαταρια) , micro sd kai usb , οτι πρεπει για τη δουλεια που το θελω.
Εψανα και το surface pro 3-4 , αλλα οι τιμες ξεφευγανε αρκετα.
Περιμενω και το πενακι αυριο, και θα πω περισσοτερα , αν ενδιαφερεται καποιος.
Το μονο μειονεκτημα, οτι δεν εχει backlit Το πληκτρολγιο και η αναλογια 16/9 για tablet mode (για laptop μια χαρα ειναι παντως).
Θετικο επισης οτι ανοιγει ευκολα και αλλαζεις μπαταρια και ssd (m.2) για πλακα.
22 June 2006
34,878
NEO HRAKLEIO
πολυ!!! :p
Το ηθελα κυριως σα φορητο-ταμπλετ .... το macbook pro ειναι αρκετα μεγαλο (και ακριβο) να το κουβαλαω παντα μαζι μου, ειδικα για απλες δουλειες.
Εινα ταχυτατο το dell, του εβαλα και photoshop cc kai after effects και δε καταλαβαινει τιποτα!
alextrela
28 November 2011
3,129
Μέρα με την νύχτα σε σχέση με το Τ100.
Οπουδήποτε
Οθονη
Ποιότητα κατασκευης
Θύρες
Επιδόσεις-specs.
Δυνατότητα να αλλάξεις μπαταρια και SSD.
Ιδιαίτερο το τελευταίο μονο η Dell το παρέχει σε tablet form factor.
Αλλα τα μείον το 16:9 aspect,το βασικότερο μείον πιστεύω και η γραφιδα δεν εχει την ίδια ποιότητα με Wacom η surface pen.
Στα νέα Dell 2015 edition το γύρισε η Dell σε Wacom.
Εννοείται στα 400 ευρω ειναι τρελό value for money και κανεις πολυ πιο εύκολα οποιοδήποτε συμβιβασμό στην άκρη.
Ετσι κι αλλιως τα Surface δύσκολα και σπάνια πέφτουν οι τιμές τόσο πολυ αν δεν περάσει μια 2ετια τουλάχιστον.
speedman_27
17 August 2010
5,073
Mitilini
πολυ!!!
Πώς και δεν πήρες iPad Air 2
22 June 2006
34,878
NEO HRAKLEIO
απο αγγελια .... 4 μηνων μονο μαζι με το πληκτρολογιο!
το 16/9 για τη δουλεια μου δε με πειραζει , το αντιθετο με βολευει (ολα τα βιντεο και φωτο που επεξεργαζομαι ειναι 16/9)
Σε ταμπλετ mode θα το ηθελα φυσικα 3/2
καποια στιγμη μου εβγαλε wifi limited connection στο wifi της δουλειας... ξερει καποιος κατι γι αυτο ?
Ειναι θεμα των windows 10 ?
Με ολες τις υπολοιπες συσκευες συνδεομαι κανονικα....
alextrela
28 November 2011
3,129
Ειναι πολυ παράγοντες που μπορεί να παίζουν ρόλο.
Το σωστότερο θα ήταν μετα την αναβάθμιση απο 8.1 να του τραβήξεις ενα reinstall Windows μέσα απο update and recovery απο τα PC settings για να δέσει καλυτερα τα νέα Windows σαν καθαρη εγκατάσταση.
Και βέβαια κοιτάς το Dell support site για το μοντελο για τα τελευταία drivers απο την Dell.
Όπως επίσης να εχεις αναβαθμίσει στην τελευταία έκδοση του bios εφόσον εχει βγει απο Dell.
Αν και φαντάζομαι μεταχειρισμένο που το πήρες λογικα ο προηγούμενος κάτοχος θα έπρεπε λογικα να στο είχε δωσει με καθαρη εγκατάσταση,αρα κοιτάς drivers και ενδεχόμενος bios update εφόσον πάρεχει η Dell.
22 June 2006
34,878
NEO HRAKLEIO
ξερει κανεις πως μπορω να παιξω blue ray disk στο tablet ?
Eχω κατεβασει το powerdvd αλλα δεν παιζει , λογω καρτας γραφικων. Υπαρχει καποιος άλλος πλαυερ ... δε μπορει να μη παιζει ένα τετοιο μηχανημα blueray δισκακια .
22 June 2006
34,878
NEO HRAKLEIO
χωρις μενου εχω και το kodi.... τεσπα, θα δω.
Το μηχανακι είναι πολύ δυνατο, εβγαλε με ανεση τη δουλεια για την οποια προοριζεται , sd editing kai compositing .
Σα tablet βεβαια δεν είναι ιδανικο, λιγο βαρυ και 16/9 , alla και σχετικα θορυβωδες , όπως όλα τα υβριδικα με i5 - i7.
H οθονη εντυπωσιαζει , ειδικα με τη φωτεινοτητα της και το καλο επιπεδο μαυρου.
YG... τα windows 10 εχουν κανει βηματα προοδου, αλλα δυστυχως δεν εχουν φτιαχτει για touch και φαινεται.
Επισης το win app store είναι ακομα πολύ πισω. Ακομα δε βρηκα τις εφαρμογες για gopro kai sony cameras που υπαρχουν σε ios kai android.
Επισης ακομα και σε τοσο δυνατο μηχανημα , καποιες εφαρμογες που υπαρχουν σε ολες τις πλατφόρμες , όπως το flipboard, δεν τρεχουν το ιδιο καλα.
Και δεν είναι θεμα μηχανήματος, όπως νομιζα με το asus transformer...
22 June 2006
34,878
NEO HRAKLEIO
ποιος ειναι ο πιο ευκολος τροπος ν αλλαξω δισκω (μ εναν μεγαλυτερο) αλλα να μη χρειαστει να ξαναστησω τα προγραμματα ?
Υπαρχει κατι σαν clone disk ? Θα εχω προβλημα με τα win 10 και το activation ?
spcav
18 August 2006
16,691
Κατάλαβα....ορεκτικό για το iPad pro ειναι....😛
ΥΓ Το pdvd περίεργο να μη παίζει...Για κοιτά έκδοση κλπ Δοκίμασε και το παλιότερο ΤΜΤ 6
