Απάντηση: Crypto Redi 250MP - Δέκτης με DTS
Και άλλα αρχεία που δεν έπαιξε:
1) Κανένα μήνυμα λάθους, αλλά δεν υπήρχε εικόνα.
General
Format : Matroska
Format version : Version 2
File size : 443 MiB
Duration : 51mn 44s
Overall bit rate mode : Variable
Overall bit rate : 1 197 Kbps
Encoded date : UTC 2011-02-22 05:18:54
Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 18 2010 07:35:17
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 51mn 44s
Nominal bit rate : 1 100 Kbps
Width : 656 pixels
Height : 368 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 24.816 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.184
Writing library : x264 core 114
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=1100 / ratetol=1,0 / qcomp=0,60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20,0 / qblur=0,5 / ip_ratio=1,40 / aq=1:1,00
Language : English
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 51mn 44s
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 8ms
2) Κανένα μήνυμα λάθους, αλλά δεν υπήρχε εικόνα.
General
Format : Matroska
File size : 387 MiB
Duration : 45mn 12s
Overall bit rate : 1 198 Kbps
Encoded date : UTC 2011-05-29 19:40:30
Writing application : mkvmerge v4.5.0 ('Speed of Light') built on Feb 23 2011 01:17:16
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format profile :
[email protected]
Muxing mode : Header stripping
Duration : 45mn 12s
Width : 688 pixels
Height : 368 pixels
Display aspect ratio : 1.870
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.174
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1,00:0,00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=1100 / ratetol=1,0 / qcomp=0,60 / qpmin=3 / qpmax=51 / qpstep=4 / cplxblur=20,0 / qblur=0,5 / ip_ratio=1,40 / aq=1:1,00
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 45mn 12s
Channel positions : Front: L R
3) Μήνυμα «Μη υποστηριζόμενο αρχείο»
General
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
Format settings : rec
File size : 774 MiB
Duration : 1h 21mn
Overall bit rate : 1 325 Kbps
Writing application : AVI-Mux GUI 1.17.3, Sep 19 2005 21:09:46
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 21mn
Bit rate : 1 051 Kbps
Width : 640 pixels
Height : 288 pixels
Display aspect ratio : 2.222
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.238
Stream size : 614 MiB (79%)
Writing library : XviD 1.0.0 Beta2.5 (UTC 2003-12-18)
Audio #1
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 21mn
Bit rate : 128 Kbps
Sampling rate : 44.1 KHz
Stream size : 74.0 MiB (10%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.63 video frame)
Interleave, preload duration : 118 ms
Title : Japanese
Audio #2
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 21mn
Bit rate : 134 Kbps
Stream size : 78.1 MiB (10%)
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 109 ms
Title : French
Text #1
Stream size : 53.7 KiB (0%)
Text #2
Stream size : 55.4 KiB (0%)
4) Κανένα μήνυμα λάθους, αλλά δεν υπήρχε εικόνα.
General
Format : AVI
File size : 17.4 MiB
Duration : 8mn 0s
Overall bit rate : 304 Kbps
Writing library : Boilsoft Joiner build 2411/release
Video
Codec ID : XVID
Duration : 43s 560ms
Bit rate : 1 934 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Color space : YUV
Bits/(Pixel*Frame) : 0.252
Stream size : 10.0 MiB (58%)
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 8mn 0s
Bit rate mode : Constant
Bit rate : 128 Kbps
Delay relative to video : 19ms
Stream size : 7.33 MiB (42%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.01 video frame)
Interleave, preload duration : 500 ms
Writing library : LAME3.97
5) Μήνυμα «Μη υποστηριζόμενο αρχείο»
Πληροφορίες από GSpot 2.70a
Το Lavc51.26.0 πρέπει να είναι η libavcodec version.
6) Εμφάνιζε μήνυμα «Μη υποστηριζόμενος» και δεν είχε ήχο
General
Format : AVI
File size : 215 MiB
Duration : 23mn 32s
Overall bit rate : 1 279 Kbps
Video
Codec ID : divx
Codec ID/Info : Mainly used by Google
Codec ID/Hint : DivX
Duration : 23mn 32s
Bit rate : 1 151 Kbps
Width : 640 pixels
Height : 480 pixels
Color space : YUV
Bits/(Pixel*Frame) : 0.156
Stream size : 194 MiB (90%)
Audio
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 23mn 32s
Bit rate : 112 Kbps
Sampling rate : 22.05 KHz
Stream size : 18.9 MiB (9%)
7) Εμφάνιζε μήνυμα «Μη υποστηριζόμενος» και δεν είχε ήχο
General
Format : Matroska
File size : 580 MiB
Duration : 1h 27mn
Overall bit rate : 927 Kbps
Encoded date : UTC 2007-09-16 07:04:56
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : VC-1
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Duration : 1h 27mn
Bit rate : 781 Kbps
Width : 640 pixels
Height : 480 pixels
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.106
Stream size : 489 MiB (84%)
Language : Japanese
Audio
Format : WMA
Codec ID : 161
Codec ID/Info : Windows Media Audio
Duration : 1h 27mn
Bit rate : 128 Kbps
Bit depth : 16 bits
Stream size : 80.1 MiB (14%)
Language : Japanese
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
8) Εμφάνιζε μήνυμα «Μη υποστηριζόμενος» και δεν είχε ήχο
General
Format : AVI
File size : 1.51 GiB
Duration : 1h 23mn
Overall bit rate : 2 610 Kbps
Video
Codec ID : XVID
Duration : 1h 23mn
Bit rate : 2 476 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5:4
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.239
Stream size : 1.44 GiB (95%)
Writing library : ZJMedia MPEG Encoder
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 23mn
Bit rate : 128 Kbps
Stream size : 76.0 MiB (5%)
Interleave, duration : 1000 ms (25.00 video frames)
9) Μήνυμα «Μη υποστηριζόμενο αρχείο»
General
Format : AVI
File size : 185 MiB
Duration : 6mn 31s
Overall bit rate : 3 961 Kbps
Subject : On Your Mark
Writing library : This file was made by AviUtl 0.97d.
Comment : Pioneer DVL-909 / Pinnaclesys DC10+
Video
Codec ID : MP42
Codec ID/Info : Microsoft MPEG-4 v2 (pre-standard)
Codec ID/Hint : Microsoft
Duration : 6mn 31s
Bit rate : 3 700 Kbps
Width : 640 pixels
Height : 360 pixels
Bits/(Pixel*Frame) : 0.670
Stream size : 173 MiB (93%)
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 6mn 31s
Bit rate : 256 Kbps
Stream size : 12.0 MiB (6%)
Interleave, duration : 459 ms (11.00 video frames)
Interleave, preload duration : 458 ms
Writing library : LAME3.91
Encoding settings : -m j -V 4 -q 2 -lowpass 20.6
10) Εμφάνιζε μήνυμα «Μη υποστηριζόμενος» και δεν είχε ήχο
General
Format : AVI
File size : 233 MiB
Duration : 19mn 22s
Overall bit rate : 1 678 Kbps
Video
Codec ID : XVID
Duration : 19mn 22s
Bit rate : 1 542 Kbps
Width : 512 pixels
Height : 384 pixels
Color space : YUV
Bits/(Pixel*Frame) : 0.314
Stream size : 214 MiB (92%)
Audio
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 19mn 22s
Bit rate : 128 Kbps
Stream size : 17.7 MiB (8%)
11) Εμφάνιζε μήνυμα «Μη υποστηριζόμενος» και δεν είχε ήχο
General
Format : AVI
File size : 1.21 GiB
Duration : 1h 5mn
Overall bit rate : 2 631 Kbps
Video
Codec ID : XVID
Duration : 1h 5mn
Bit rate : 2 497 Kbps
Width : 512 pixels
Height : 384 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.508
Stream size : 1.15 GiB (95%)
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 5mn
Bit rate : 128 Kbps
Stream size : 60.3 MiB (5%)
