Blackmagic PocketCinema Camera 6K G2
Kosh
7 September 2006
91,788
Εκεί ψηλά.....
Blackmagic PocketCinema Camera 6K G2​
Today we introduced a new model to the Blackmagic Pocket Cinema Camera family, Blackmagic Pocket Cinema Camera 6K G2. This new model includes an adjustable touchscreen screen for easier framing of shots, a larger battery for longer shooting without needing to charge or change batteries, as well as support for an optional electronic viewfinder. This new 6K model also has the latest generation 5 color science which has previously been available only in the 6K Pro model, as well as retaining the same features as the previous model including Super 35 HDR image sensor with 13 stops of dynamic range, dual native ISO of 25,600 and EF lens mount.
We also released Blackmagic Camera 7.9 Update which adds support for a new user interface which includes sliders for adjusting focus assist intensity as well as improved lens and autofocus performance for Blackmagic Pocket Cinema Camera 4K, 6K and 6K Pro models.
This update also adds support for Blackmagic Design Zoom and Focus demands to Blackmagic Pocket Cinema Camera 6K, 6K G2 and 6K Pro models.
Blackmagic Pocket Cinema Camera 6K G2 is available immediately from Blackmagic Design resellers worldwide for US$1,995.
Kosh
7 September 2006
91,788
Εκεί ψηλά.....
Προκειται επι της ουσιας για αντικατασταση της bmpcc6k υιοθετωντας το σασι τηε 6k pro αφαιρωντας ομως τα builded Nds
Να ακολουθησει και bmpcc4k G2 ?
evanfotis
26 March 2008
5,493
Αυτά που εξαρχής ηθελε...
Ελπίζω μη σπρώξει τη τιμή της προ πάνω...
evanfotis
26 March 2008
5,493
Πλέον με τέτοιο σώμα, πρέπει να αλλάξει όνομα πια...
Kosh
7 September 2006
91,788
Εκεί ψηλά.....
US$1,995.
Ελαφρως
Εχει ενα κακο βεβαια αυτη η ανακοινωση . Οτι συνηθως η ΒΜ βγαζει μια καμερα την φορα και αυτο ισως σηματοδοτει οτι για το καλοκαιρακι παπαλα.....οτι βγαλαμε βγαλαμε για τις μικρης αξιας καμερες
Βεβαια με ενα 500αρικο διαφορα που εχει με την pro (και αν αναλογιστεις οτι εδιναν στα λεφτα αυτα τσαμπα το evf λιγο καιρο πριν.....) δεν ξερω τι νοημα εχει αυτη η κυκλοφορια προφανως για εσωτερικα γυρισματα ειναι καλυτερη.
evanfotis
26 March 2008
5,493
Η παρουσίαση. Οι αλλαγές στο UI ισχύει για όλα τα μοντέλα pocket.
Kosh
7 September 2006
91,788
Εκεί ψηλά.....
Aν διαβαζες το πρωτο ποστ του νηματος ή εβλεπες κανα απο τα βιντεο θα ηξερες ηδη οτι ειναι για φακους Canon EF.
