Arri Alexa
Portioli
3 June 2007
3,928
Dystopia
Μετά το drive, και το anonymos
(που μόλις ήρθε στους κινηματογράφους),
είπα να ανοίξω ένα νήμα,
για άλλη μια εκπληκτική κάμερα
http://www.arri.com/camera/digital_cameras/cameras.html
wiki:
The Arri Alexa is a film-style digital motion picture camera made by Arri first introduced in April 2010. The camera marks Arri's first major transition into digital cinematography after smaller previous efforts such as the Arriflex D-20 and D-21. The Arri Alexa features an advanced electronic viewfinder, modularity, PL mount lenses, and a 35mm-width CMOS sensor shooting up to 2.88k resolution.[1] New features also include recording to the digital intermediate codec ProRes 4444 and ProRes 422 in camera, simplifying the post production workflow.[2]
The camera is designed for use in high budget feature films, television shows, and commercials, and is widely seen as Arri's answer to the growing acceptance of using the Red One, along with lower resolution cameras like the Sony CineAlta (35 mm, 1080p), Panavision Genesis (35 mm, 1080p), Thomson Viper FilmStream (2/3", 1080p) to shoot feature films.
Sensor Information
The Alexa's ALEV III sensor has 3392x2200 pixels that can be used for generating an image. There are more pixels than this, but those extra pixels are used for calibration and other purposes and not for generating an image
ALEXA
Output Options:
technical data
Camera Type35 format film-style digital camera with integrated shoulder arch and receptacles for 15 mm lightweight rods.
Sensor35 format ALEV III CMOS with Dual Gain Architecture (DGA) and Bayer pattern color filter array. 1.5x oversampling for 1920 x 1080 output. 1.78:1 (16:9) sensor area used for image out.
Frame Rates"ProRes 422 (Proxy), 422 (LT), 422 and 422 (HQ): 0.75 - 60 fps
ShutterElectronic rolling shutter, adjustable from 5.0° to 358.0° with 1/10 degree precision.
Exposure Latitude14 stops for all sensitivity settings from EI 160 to EI 3200, as measured with the ARRI Dynamic Range Test Chart (DRTC)
Exposure IndexEI 160 (+5.0 / -9.0), EI 200 (+5.3 / -8.7), EI 400 (+6.3 / -7.7), EI 800 (+7.4 / -6.6), EI 1600 (+8.4 / -5.6), EI3200 (+9.4 / -4.6)
Values behind the exposure index are the number of stops above and below 18% grey. These values are for Log C. Rec 709 and DCI P3 have 0.5 stops fewer in the low end at EI 160, 0.4 stops fewer in the low end at EI 200 and 0.2 stops fewer in the low end at EI 400. Otherwise they are the same.
White BalanceSeparate red/blue and green/magenta balance available through Auto White Balance or manual setting. Red/blue: 2000 to 11000 Kelvin, adjustable in 100 K steps, with 1 CC = 035 Kodak CC values or 1/8 Rosco values. presets of 3200 (tungsten), 4300 (fluorescent), 5600 (daylight), 7000 (daylight cool). Green/magenta: -8 to +8 color correction (CC),
ALEXA PLUS
Output Options
technical data
ALEXA M
ALEXA Studio
Photis
4 July 2006
4,796
behind the camera
Πάντως θεωρώ πως στην βαριά κινηματογραφική βιομηχανία, είναι οι κάμερες σαν την Alexa και τις αντίστοιχες της Panavision και της Grasssvalley/Thomson που θα θέσουν και πάλι τα standards. Οι υπόλοιπες που συζητάμε εδώ (red, canon, panasonic, sony) είναι περισσότερο για πιο low budget παραγωγές. Ή για παραγωγές που απαιτούνται πολλές κάμερες στο σετ.
JL_?
19 September 2008
15,415
Terra
Και φυσικά επειδή έχει όσο έχει, είναι η κάμερα που δοκιμάζουν εδώ στην ΕΡΤ για την κινηματογραφία...
:eating:
Τείνω να συμφωνήσω, αν και τη RED δεν θα την ξέγραφα τόσο εύκολα, ενώ και η Cinealta φαίνεται να έχει πάρει μια μικρή παράταση κινηματογραφικής ζωής, λόγω του ότι αποτέλεσε την πιο "φορητή" αξιοπρεπή λύση στο 3D (Fusion), πριν γίνει διαθέσιμο το αντίστοιχο πακετάκι της RED...
Πάντως, πέρα από τα εργαλεία, τη μεγαλύτερη σημασία έχουν και τα μυαλά και τα χέρια αυτών που τα χειρίζονται: για παράδειγμα, τα συνεργεία του BBC έχουν καταφέρει να βγάλουν περισσότερο "κινηματογραφικό" αποτέλεσμα από μια ταπεινή Sony F750, απ' ό,τι τα συνεργεία του Starz από την Alexa...
Kosh
7 September 2006
91,773
Εκεί ψηλά.....
Εμ βεβαια απο μερσεντες και πανω......
Αναθεμα και αν μπηκαν στον κοπο να καλεσουν καποιους επαγγελματιες του χωρου να τους κανουν μια σοβαρη παρουσιαση , να τους εκθεσουν τις αναγκες τους και να συγκρινουν τα διαφορετικα καμερακια για να καταληξουν τι θα παραγγειλουν.
Εκτος .....αν παιζει το γνωστο παλι....αν και για την Arri παρολο που ειναι γερμανικη δεν θα πιστευα κατι τετοιο. (ποτε μην λες ποτε βεβαια....Απο τον Καλαβιτη δοκιμαζουν καμερες ή κατευθειαν απο την Γερμανια ?)
Kosh
7 September 2006
91,773
Εκεί ψηλά.....
:eating:
Τη RED δεν θα την ξέγραφα τόσο εύκολα, ενώ και η Cinealta φαίνεται να έχει πάρει μια μικρή παράταση κινηματογραφικής ζωής, λόγω του ότι αποτέλεσε την πιο "φορητή" αξιοπρεπή λύση στο 3D (Fusion), πριν γίνει διαθέσιμο το αντίστοιχο πακετάκι της RED...
+1 :antlers:
Εγω δεν ξεχνω τι εικονα εβγαζαν τα τζιμανια του Doctor Who παντως απο μια ταπεινη ψηφιακη SDbeta.....
Θυμιζω οτι αναμενουμε την νεα Sony F65 πλεον.......που θα παιξει δυνατα ελπιζω. Και θα στειλει τις cinealta 900, 950 στο χρονοντουλαπο της ιστοριας . Καλες καμερες παντως το ομολογω.
Ομως η RED ηταν καλυτερη.
Kosh
7 September 2006
91,773
Εκεί ψηλά.....
Μην ξεγραφεις ουτε την Sony ουτε την Red. Ακομα δεν την ειδαμε την Epic ουσιαστικα.
Και μην ξεχνας οτι τελειομανεις οπως ο Καμερον και ο Τζακσον δεν θα κολωναν να νοικιασουν καμερες αντι να τις αγορασουν αν ηταν καλυτερες της Epic.....
50 καμερες ο ενας και 30 ο αλλος αγορασαν τα θηρια.
Η Alexa και η λογικη της υψηλης τιμολογησης οταν στην αγορα προσφερονται καλυτερα και φθηνοτερα προιοντα θα πεθανει συντομα. Οι εποχες που μια καμερα εκανε 100.000 γιουρος και τα πεταγαμε για μια καμερα παρηλθαν ανεπιστρεπτι.
Photis
4 July 2006
4,796
behind the camera
Και ο Κάμερον και ο Τζάκσον πήγαν σε φτηνές λύσεις επειδή τους ενδιέφερε να αγοράσουν ποσότητα, υποψιάζομαι λόγω 3D. Αυτό που εγώ είπα πιο πριν είναι ότι τα μεγάλα studio στο hollywood, στα οποία γυρίζονται ταινίες με badget πολλών εκατομμυρίων ευρώ, δεν θα πάνε να δοκιμάσουν φτηνότερες λύσεις αλλά θα πάνε στην πεπατημένη. Και αυτή είναι η Panavision (νο1) η Arri (λόγω παράδοσης και ονόματος) και η GrassValley/Thomson λόγω μεγέθους εταιρίας, πρωτοπορίας στο digital cinema και Technicolor.
Δεν θεωρώ τις υπολοιπες υποδεέστερες. Άλλωστε θα βρουν το δρόμο τους στην αγορά. Θεωρώ όμως ότι ένα μεγάλο στούντιο δύσκολα θα ξεκολλήσει από τα μεγάλα ονόματα όσον αφορά τον εξοπλισμό του, για να πάει σε κάτι πιο νέο. Ακόμα και αν αυτό το νέο είναι αισθητά φτηνότερο. Άλλωστε αν για μια ταινία η αμοιβή του πρωταγωνιστή αγγίζει τα 10 εκατομμύρια δολάρια, τα 100.000 δολάρια που κοστίζει η αγορά μιας κάμερας δεν αποτελούν σοβαρό κόστος.
Stergios Giotas
4 November 2006
833
Ο Roger Deakins, πάντως, ο διευθυντής φωτογραφίας των αδελφών Κοέν και σύγχρονος θρύλος της κινηματογραφικής βιομηχανίας που μέχρι τώρα απέρριπτε συλλήβδην την εικόνα των ψηφιακών καμερών ως "σκουπίδια" και σχεδόν κοιμόταν αγκαλιά με μια Arriflex 435, δήλωσε πρόσφατα ευθαρσώς ότι θεωρεί την Alexa την πρώτη και μοναδική αυτή τη στιγμή ψηφιακή κάμερα που μπορεί να συναγωνιστεί σε ποιότητα το 35άρι φιλμ, έχοντας εφάμιλλη δυναμική περιοχή (αν και με ελαφρώς πιο μαλακή εικόνα) με αυτό, ενώ στον τομέα του χρωματικού κορεσμού τη θεωρεί ανώτερη. Μάλιστα, πιστεύει τόσο πολύ σε αυτή που θα τη χρησιμοποιήσει στο γύρισμα της επόμενης ταινίας James Bond, αλώνοντας έτσι ένα από τα παραδοσιακά κάστρα του φιλμ που αποτελούσε μέχρι τώρα η συγκεκριμένη σειρά ταινιών.
Stergios Giotas
4 November 2006
833
'Εχω την εντύπωση ότι τα τελευταία χρόνια στο Χόλιγουντ, η συνήθης πρακτική είναι η ενοικίαση και όχι η αγορά εξοπλισμού.
Kosh
7 September 2006
91,773
Εκεί ψηλά.....
Οταν προκειται για μεγαλο προτζεκτ και τα γυρισματα ειναι πολυμηνα αρκετες φορες αγοραζουν τον εξοπλισμο τους και τον επαναπωλουν στην ληξη.
Συμφερει καλυτερα.
Photis
4 July 2006
4,796
behind the camera
Πάντοτε έχουν και inhouse μηχανήματα για τα γυρίσματα εντός στούντιο. Αυτά δουλεύουν full time και έχουν μέχρι και τη συντήρηση εντός του στούντιο. Εδώ ακόμα και στην Ελλάδα, διαφημιστικές είχαν δικές τους κινηματογραφικές κάμερες (Arriflex), για να γυρίζουν τα σποτάκια τους.
Kosh
7 September 2006
91,773
Εκεί ψηλά.....
Απο τοτε που πεθανε το φιλμ το πολυ πολυ να τα κανουν πλεον με καμια 5dII.
Tελος οι χλιδες .
Photis
4 July 2006
4,796
behind the camera
Αυτό που λες Ναθαν ισχύει. Με έναν φίλο μου παραγωγό που μιλάω συχνά, οι 99 στους 100 που έρχονται για διαφημιστικά ζητάνε χαμηλό κόστος παραγωγής. Υπάρχει όμως και ο ένας στους 100 που απαιτεί φιλμ. Εκει ξεσκονίζουν την Arriflex και γυρνάνε...
Kosh
7 September 2006
91,773
Εκεί ψηλά.....
Nαι οκ.....
Εχεις υποψιν σου οτι ολες οι μεγαλες εταιρειες κατασκευης κινηματογραφικων μηχανων ληψης εχουν σταματησει σχεδον δυο χρονια την παραγωγη τους και μονο κατα παραγγελια πλεον ξαναζεσταινουν τα καλουπια τους ?
Ετσι για να ξερουμε τι συζηταμε.
Ειναι θεμα χρονου πλεον. Οταν ακολουθησουν και οι αιθουσες την ψηφιακη επελαση το φιλμ θα χρησιμοποιειται πλεον μονο για το ιδιαιτερο look του.
Οποιος εχει αμφιβολια ας δει τι εγινε στην αγορα του επαγγελματικου και ερασιτεχνικου φωτογραφικου φιλμ και μετα θα βγαλει συμπερασμα.
Απλα παιρνει χρονο στην τεραστια κινηματογραφικη βιομηχανια να προσαρμοστει υλικοτεχνικα.
