Απομακρυσμένη διαχείριση μέσω ....
22 June 2006
34,866
NEO HRAKLEIO
Teamviewer...
To γνωστο σε ολους μας Teamviewer τωρα και στο ipad δωρεαν!
Δουλευει απροβληματιστα, με Pc και Mac , γρηγορο και αξιοπιστο.
Xρειαζεται τον teamviewer server εγκατεστημενο...
http://teamviewer.com/en/download/index.aspx
attachment.php
attachment.php
attachment.php
attachment.php
22 June 2006
34,866
NEO HRAKLEIO
Re: Aπομακρεισμενη διαχειριση μεσω ....
Connect My Mac
Ενα ακομη δωρεαν προγραμμα , μονο για Mac...
Connect my mac
Εχει το καλο, οτι δε χρειαζεται καποιο ειδικο προγραμμα εγκατεστημενο, απλα ενεργοποιουμε την ενσωματωμενη δυνατοτητα του Mac για vnc connection.
attachment.php
attachment.php
attachment.php
attachment.php
Description
Connect to your Mac computers from iPad/iPhone/iPod Touch at anytime! Great functionalities and It's FREE!
Compared with this free version, the Pro version has more features:
- Multiple connections
- Trackpad to move mouse cursor (also support click) and do mouse wheel scroll
- Mouse right click, hover and mouse drag
- Modifier keypad including Shift, Ctrl and Alt which enables you to press almost any key combinations.
- A cool functional keyboard: Cut, copy & paste and other shortcuts keypad, including HOME, END, PAGE UP, PAGE DOWN, Arrow keys, etc.
- Virtual left button and right mouse button
- Support video output (need iPad or iOS4 and output connector)
Features:
- Specifically designed for both iPad and iPhone
- Take advantage of iPhone4's HD screen and iPad's big screen
- Portrait and landscape mode
- Support various resolutions and colors
- Tap to do click, double tap to double click, and all easy to use features
- Pinch to zoom in and out. Choose the zoom scale you like
- International keyboard support for many languages, including French, German, Italian, Korean, Russian, Swedish, Spanish, Portuguese etc.
- Easy to use design
Supported Platform:
- Mac OS X Tiger
- Mac OS X Leopard
- Mac OS X Snow Leopard
- Windows with VNC server installed
Note: This is also a full VNC client. Thus you can also use it to connect to Windows with VNC server installed.
Brief install instructions (Use it if you do not need step-by-step instructions):
How to configure my Mac?
- Mac OS Tiger: http://www.macminicolo.net/Mac_VNC_tutor.html
- Leopard or Snow Leopard: http://reviews.cnet.com/8301-13727_7-10329122-263.html
For detailed setup instructions and more information, see
http://www.hanajobs.com/mobile/forums/show/13.page
Send your comments/suggestions to [email protected] or visit our website.
22 June 2006
34,866
NEO HRAKLEIO
Splashtop Remote Desktop for iPad
http://www.splashtop.com/remote
Aυτο το προγραμμα χρησιμοποιω εγω κυριως, γιατι εχει καλυτερη αισθηση, μπαινει σε Mac kai Pc και το βασικο του πλεονεκτημα ειναι οτι αλλαζει την αναλυση οθονης του server ετσι ωστε να εχουμε 1:1 mapping για καλυτερη αναγνωση και χειρισμο!
Οταν τελειωνεις , επαναφερει την αναλυση εκι που ηταν .
attachment.php
attachment.php
attachment.php
attachment.php
Description
*** The #1 iPad app in the US, UK, Canada, Australia, New Zealand, Germany, Austria, China, Taiwan, Hong Kong, Japan, Korea, and many other countries in business category! (Oct 2010)
The highest performance remote access app bringing your entire computer to your iPad, featuring full video and audio support! See your desktop, use your regular web browser with Flash and all of your bookmarks, watch movies, and access any application or file on your computer.
A dedicated iPhone and iPod touch version is also available.
★★★★★ "Both a breakthrough and a bargain." -- The New York Times
★★★★★ "Splashtop Remote WINS hands down!" -- Apps for iPads
* See and control your computer as if you are in front of it
* Access all of your computer files and programs
* Watch videos in any format (including Flash!), and listen to your entire music library
* Play advanced PC games via patent-pending Splashtop streaming technology
* Connect to multiple computers with the same app
* Interact with computer applications using intuitive touch controls and familiar iPad gestures
Fast and easy setup:
* One-click access to your computer desktop with minimal setup
* Application finds your local computers automatically
* Supports all versions of Windows 7, Vista, and XP, including Home Premium
* Supports Mac OS X 10.6 (Snow Leopard)
* Dual-core CPU strongly recommended for best performance
★★★★★ "Splashtop Remote is... extremely easy to setup" -- Pixelatedgeek.com
*** New features coming soon as an update:
* Seamlessly connect across a firewall, when the iPad and the PC are not on the same network
Splashtop Inc. Web SiteSplashtop Remote Desktop for iPad Support
What's New in Version 1.3.0.0
3-finger tap to show in-app controls menu with the following controls:
* Video mode (smooth / sharp) is back!
* Multi-monitor display switching control
* Arrow pad control for ease of scrolling
* Orientation lock
In addition, we fixed several interface and computer discovery bugs.
To enjoy these new great features, make sure to use the latest version of the PC or Mac OSX 10.6 (Snow Leopard) desktop application (free download from www.splashtop.com/remote)
22 June 2006
34,866
NEO HRAKLEIO
VNC
http://itunes.apple.com/us/app/vnc-viewer/id352019548?mt=8;uo=6
Eνα επισης γνωστο και καλο προγραμμα, αν και λιγο ακριβο.
attachment.php
attachment.php
attachment.php
attachment.php
http://www.youtube.com/watch?v=TrFSpceWIUQ&feature=player_embedded
Description
Control a computer from your iPhone, iPad or iPod touch! VNC® Viewer connects your device to a computer anywhere in the world, displays its desktop, and lets you take control. You can run applications, change settings, and access data exactly as you would be permitted to do were you sitting in front of it, and using the keyboard and mouse.
VNC Viewer is from RealVNC, the inventors of VNC. It can connect to any Mac OS X computer, and to any Windows, Linux, or UNIX computer running VNC-compatible Server technology. RealVNC recommends VNC Enterprise Edition for robust, secure, and high-performance connections, and for its unrivalled flexibility. For more information, see www.realvnc.com.
===Summary===
1. Download VNC Viewer from the App Store.
2. If the computer you want to control is running Mac OS X 10.4 or later, enable Apple Remote Desktop/Remote Management (see below for more information). If not, install and start a VNC-compatible Server.
3. If you are connecting over the Internet (for example, via 3G), configure firewalls and routers protecting the computer to allow and forward network communications to it. Start with www.realvnc.com/products/iphone/1.3 for more information. If you are connecting over a Wi-Fi-enabled private network such as a LAN or VPN, you should be able to connect without further configuration.
4. Find out the network address of the computer. If you are connecting over the Internet, this will probably be that of a router. You will also need a port number if the VNC-compatible Server is listening on a port other than the default for VNC, 5900 (note this is not necessary for Apple Remote Desktop/Remote Management).
5. Start VNC Viewer, identify the computer you want to control, and connect!
===Features===
* New in version 1.3: Support for Bonjour, making it simple to locate and connect to compatible computers.
* Interact with your computer as though sitting in front of it.
* Give connections user-friendly names, and see desktop previews.
* Pinch to zoom in to a specific area, or out to see the whole picture.
* Easy navigation, scrolling, dragging, and selection using standard touch, tap, and drag gestures.
* Mouse button mode for precise control over mouse button and scrolling operations.
* Easy text entry using on-screen keyboard with preview.
* Important non-character keyboard keys (function, modifier, and so on) available on a scrolling key bar.
* Automatic performance optimization.
* Support for screen resolutions up to 5120 by 2400 pixels (though the actual resolution is limited only by the memory of your device).
Users connecting to VNC Enterprise Edition also enjoy the following significant benefits:
* Connections encrypted using up to 256-bit AES technology.
* Authentication credentials protected by 2048-bit RSA public keys.
* System authentication to connect using computer log on credentials.
* Enhanced performance.
* Support for non-US keyboards.
* Transfer text between applications on your computer and device.
VNC Enterprise Edition is available for a wide range of Mac OS X, Windows, Linux, and UNIX computer operating systems. For more information, visit www.realvnc.com/products/enterprise.
===Connectivity===
VNC Viewer can establish connections to:
* VNC Free Edition (version 4.1).
* Mac OS X 10.4 or later with built-in Apple Remote Desktop/Remote Management enabled. To do this, turn on the 'VNC viewers may control screen with password' option, and set a password. Note this does not apply to PowerPC Macs running 10.4 (Tiger); install VNC-compatible Server technology instead.
* AMX touch panels.
* Third-party VNC-compatible Servers.
VNC Viewer can establish secure (authenticated and encrypted) connections to:
* VNC Enterprise Edition (version 4.x).
* VNC Personal Edition (version 4.x).
Please note 30 day trial licenses are available for these products.
===Trademarks===
VNC is a registered trademark of RealVNC Ltd. in the U.S. and in other countries.
RealVNC Web SiteVNC Viewer SupportApplication License Agreement
What's New in Version 1.4.0
VNC Viewer now supports up to 256-bit AES encryption, and significant improvements have been made to performance over low bandwidth connections and when working with Bonjour.
22 June 2006
34,866
NEO HRAKLEIO
Και τελος .... Desktop connect
Eνα απο τα πιο ολοληρωμενα προγραμματα , και το πιο ακριβο!
Δεν χρειαζεται κανενα εξτρα προγραμμα εγκατεστημενο σε Mac ή PC!
Δουλευει με VNC kai RDP ....
Yποστηριζει (οπως και καποια απο τα προηγουμενα) Wake on Lan).
attachment.php
attachment.php
attachment.php
attachment.php
Description
*A MUST HAVE FOR THE IPAD and IPHONE!* Instantly connect to any computer from anywhere in the world!
"Behold! OSX on iPad! With Flash!" - boingboing.net
"good freedom to use a remote system at an excellent price" - Tweaktown.com
"Windows 7 on the iPad" - Gizmodo
"Five iPad apps to consider on your first day of ownership" - LA TIMES
"and just like that, flash on the ipad!" - technabob.com
Desktop Connect is a fast, full-featured desktop viewer. View and control Windows, Mac OSX and Linux computers as if you were sitting in front of them, or observe others as if you were watching over their shoulder.
Desktop Connect is the only universal app that will automatically discover all of your computers on your local network. We uniquely offer support for both VNC and Microsoft Remote Desktop (RDP).
Desktop Connect enables you to:
• View websites with Adobe Flash
• Launch and view any application on your desktop.
• Remotely control Media Players and PowerPoint Presentations.
• Access an important business document while you travel.
• Guide your office administrator as you watch the desktop remotely.
• Help your grandmother on her computer as she downloads your childhood photos.
Easy Connect (optional software for your computer)
• It can find and connect your computer anywhere in the world by simply signing into your Google Gmail Account.
• Easy Connect allows a SINGLE CLICK CONNECT to your Windows or Mac computer without any complex configuration.
• Encrypt all data using industry standard SSL.
• Stream sound from any flavor of Windows Vista, Windows 7 and MAC OSX.
• Easy Connect uses VNC and is OPTIONAL to install on your Windows or Mac.
•• Please visit our Easy Connect product page where it can be downloaded for free from your Windows or Mac computer.••
• Optimized Performance for fast and responsive control of your computer.
• Browse easily through all computers on your network.
* Introducing "Easy Connect Gateway". This enables you to view your Easy Connect computers from any Java enabled Web browser or a VNC viewer from another computer.
Privacy and Encryption:
• NLA Authentication and SSL for RDP
• MAC OSX Authentication
• 128-bit encryption for all passwords.
• Restrict access to Desktop Connect with a passcode. Protect your private information from others.
• Data encryption available through SSH tunneling (VNC only) and VPN access.
Advanced Capabilities:
• Shared Clipboard for your iPad and desktop allows you to copy and paste between them. (RDP only)
• Best-in-Class automatic discovery through both Apple Bonjour and Microsoft NETBIOS.
• Wake-on-LAN (WOL)
• Support for Arrow keys, Cut, Copy, Paste, Select All on external keyboard
Supported Operating Systems:
The following operating systems are supported out-of-box:
• Windows XP Professional
• Windows Server 2003 and 2008 Windows Vista Business, Enterprise, and Ultimate
• Windows 7 Professional, Enterprise, and Ultimate
• Mac OS X (VNC, Leopard, Snow Leopard)
You can still connect to these computers with Easy Connect (or any free VNC server)
• Windows XP Home Edition
• Windows Vista Home Premium
• Windows 7 Home Premium
For more information, visit www.antecea.com.
Antecea Inc. Web SiteDesktop Connect Support
What's New in Version 4.1
* Support for Arrow keys, Cut, Copy, Paste, Select All on external keyboard
* RDP Console Mode
* Fix problem with double click for left handed mouses.
* New toolbar and updated help doc.
