ARTA Audio Measurement and Analysis Software
Morfeas
3,508
Voula, Athens
The ARTA software consists of following programs:
ARTA - program for the impulse response measurement and for real-time spectrum analysis and frequency response measurements.
STEPS - program for frequency response measurements with stepped-sine excitation.
LIMP - program for the loudspeaker impedance measurement and loudspeaker parameters estimation.
The ARTA program has functions of following measurement systems:
Impulse response measurement system with signal generators: periodic white noise, periodic pink noise, MLS, linear and logarithmic swept-sine.
Dual channel Fourier analyzer with signal generators: white noise, pink noise, periodic white noise and periodic pink noise.
Single channel Fourier analyzer with signal generators: periodic white noise and periodic pink noise.
Spectrum, octave band and THD analyzer with signal generators: sine, two sine, multitone, white noise, pink noise, periodic white noise and periodic pink noise.
The ARTA program is also a powerful analyzer of:
Gated frequency response,
Smoothed frequency response (in 1/n-octave bands),
Step response,
Impulse response envelope (ETC – curve),
Cumulative spectral decay curve and sonogram,
Energy decay in reverberant environments,
Room acoustical parameters,
Directivity patterns,
Speech intelligibility measures: MTF, STI, RASTI, %AL.
The STEPS program enables the measurement of the frequency response with a high dynamic range and a high noise immunity. Simultaneously with a frequency response measurement the STEPS estimates levels of 2nd, 3rd, 4th, 5th and higher order harmonic distortions.
The LIMP program is specialized for the loudspeaker impedance measurement and for the estimation of physical and Thiele-Small loudspeaker parameters.
http://www.fesb.hr/~mateljan/arta/index.htm
Αξίζει και μια ματιά στο http://www.fesb.hr/~mateljan/arta/support.htm
Enjoy
Πολύ καλό μοιάζει να είναι! Και μάλιστα sharewhare που λειτουργεί σε όλα μια χαρά, εκτός από load και save.
Ελπίζω να βρω χρόνο να το δοκιμάσω!
Πρόεδρε καλημέρα..
Εξαιρετικό το post μήπως να το 'καρφίτσωνες' στα σημαντικά της κατηγορίας ?
Οι άνθρωποι έχουν κάνει πολύ καλή δουλειά και τα χρήματα που ζητούν είναι λίγα για το αποτέλεσμα..
Επίσης πολύ καλή είναι η λογική τους να δοκιμάσουν τις κάρτες που προτείνουν..
Αν μάλιστα διασταυρώσουμε και τους 'άλλους' της Liberty Instruments που φτειάχνουν το PRAXIS, τότε μάλλον οι κάρτες της M-audio είναι οι πιο σίγουρες για χρήση σε τέτοια μετρητικά και τέτοιες κατηγορίες χρημάτων..
Φυσικά οι κάρτες D/A & A/D των μεγάλων του είδους (Roland, Tascam κλπ) θα είναι καλύτερες από πλευράς θορύβου (απαραίτητο σε ευαίσθητες μετρήσεις κρουστικής απόκρισης ηχείων) αλλά με σημαντικά υψηλότερη τιμή..
Καλημέρα Dr,
μια στιγμή να βρω το κουτί με τις καρφίτσες.
Ακόμα και με τους περιορσμούς της demo έκδοσης νομίζω ότι για ερασιτεχνκή χρήση είναι μια χαρά.
Πρόεδρε καλημέρα..
Όσον αφορά μόνο στις μετρήσεις αρμονικής παραμόρφωσης, ακόμα και η αρχαία (2002) soundblaster Audigy 2ZS συμφωνούσε μέχρι τους 5 χιλιόκυκλους με ένα ΗΡ334 που είχε πέσει στα χέρια μου τότε. Βέβαια στα
-50db το "συμφωνούσε" ήταν κάπως χονδρικό (0,1% με 0.2% το θεωρούσα εντάξει), σε ψηλότερες στάθμες όμως απόλυτο.
Έδώ και 3 χρόνια έχω την Μ-audio 192, παίρνω ίδιες μετρήσεις με τις παλιές, μόνο που αυτή πάει μέχρι τους 96 χιλιόκυκλους.
Σίγουρα ένας πιο γραμμικός A/D μετατροπέας θα βελτίωνε και την ακρίβεια χαμηλά.
Αν το κόστος δεν είναι θέμα, η analog devices έχει ένα evaluation board με 12μπιτο 1 mHz Α/D, έκανε 550 ευρώ πριν 3 χρόνια που είχα ρωτήσει (τιμή Έλληνα αντιπροσώπου). Συνδεόταν στην παράλληλη θύρα και είχε και ένα στοιχειώδες λογοσμικό που έκανε Fourier.
Χαιρετισμούς
Κωνσταντίνος
