WD TV Live Hub
=silent=
2 August 2006
11,534
Homeless
To παρακατω player δεν εχει παρουσιαστει ακομα επίσημα απο την WD παρόλα αυτα κάποιος το εχει στην κατοχη του και το παρουσιαζει εδώ. Φαίνεται πολλά υποσχόμενο.
Load up the high-capacity drive with all your media to create your own personal media jukebox. With just a few clicks, you can play your home movies, share vacation slideshows, and play your music on the big screen and sound system in your living room.
* Access popular Internet content from the comfort of your living room via wired network connection
* Full HD 1080p video playback makes this Hub the perfect partner for your compatible HDTV
* Use the programmable remote control to make your entertainment choices using animated navigation menus
* Play almost any type of media file; the WD TV Live Hub supports a wide variety of the most popular file formats including HD camcorder video formats (no need to spend time transcoding)
* Store all your media on the 1TB hard drive, and the Live Hub finds and categorizes it all and displays it in one easy-to-view menu system
* Copy, move or delete files stored on a USB drive, a network drive, your camcorder, or a camera to the Live Hub built-in drive using the on-screen menus
* Stream any file on the WD TV Live Hub media center to a WD TV Live Plus or WD TV Live media player or any DLNA/UPnP compatible TV, Blu-ray Disc player, or game console
* Powerful enough to handle multiple streams so you can stream a movie in one room, while viewing photos on your TV upstairs
* Cool, quiet and ultra-compact design
* Supports a wireless network connection to your home network with an optional USB wireless adapter (sold separately)
* HDMI 1.4, composite video and component video output
* An optical audio output sends digital signals to your AV receiver for the best surround sound experience.
HDMI 1.4, Gigabit LAN... Χμμμμμμμ.... Τσιπακι?
Μπορει να πεταξει και κανενα καινουριο Live σε λιγο (συνηθως τετοια εποχη μεχρι τελη νοεμβρη - αρχες δεκεμβρη πεταει τα καινουρια μοντελακια για να πουλησει τα χριστουγεννα)
Ωπ... Αθορυβο λεει, αλλα βλεπω - οπως ειναι αναμενομενο (λογω δισκου), ανεμιστηρακι στον πατο...
http://www.avsforum.com/avs-vb/showthread.php?p=19343135#post19343135
Οσο πουλανε οι αλλοι σκετες συσκευες, η WD θα πουλαει δισκο+media player μαζι... Θα τους παρει τα σωβρακα...
Δεν θα εχει την τιμη που εχουν τα αλλα players των 100 ευρω. Σίγουρα η διπλάσια τιμη+ θα παίξει στην Ελλάδα. Πάντως το συγκεκριμένο αγοράστηκε 230$ Καναδά δηλαδή 162 ευρώ.
Το WD Live hub έχει διαρεύσει ότι βγαίνει από τον Σεπτέμβρη. Το θέμα είναι ότι πάλι η WD δεν δείχνει να συμπαθεί το HD passthroug. Καλό το gigabit....δεν λέω...και θα το έπαιρνα ευχαρίστως όταν βγει αλλά θα θα έλεγα "super" άμα τελικά υποστηρίζει DTS HD MA και Dolby TrueHD. Τότε ναι ...μιλαμε για σώβρακα......:D
Δεν εννοω αυτα των 100... Κατι Popcornhour, Dune και Egreat που την ειχαν δει καπως εννοω...
Οσο για το HD audio, οσο βασιλευουν τα σημερινα specs στα mkv ειναι δευτερευον, αν δεν αλλαξει κατι (ισχνη μειοψηφια των κατοχων οσοι εχουν καινουριους ενισχυτες). Μη νομιζετε οτι η WD δεν εχει κανει ερευνα αγορας...
διορθωστε με γιατι ισως κανω λαθος,dts ηχο δεν εχει η πλειοψηφια των mkv?
ολη αυτη η κουβεντα γυρω απο media players σχετικα με DTS HD MA και Dolby TrueHD ,αφορα αποκλειστικα στην ικανοτητα τους να αναπαραγουν τα mkv που κυκλοφορουν στη ¨θαλασσα¨ ή κατι αλλο μελλοντικο?
Εχω ψηθεί άσχημα. Αύριο ήμουν έτοιμος να χτυπήσω το WD TV Live αλλά απ'ότι φαίνεται θα κάνω υπομονή για το Hub.
Μπορείτε να κάνετε μια εκτίμηση για ημερομηνία κυκλοφορίας; (έστω και στα Αγγλικά μαγαζιά).
Εγω παλι δεν ψηθηκα :) Ελπιζα συντομα σε καποιο μοντελο που θα υποστηριζε hd,τουλαχιστον να το νιωθει καποιος ηδη κατοχος wd σαν αναβαθμιση.Δισκους παιρνουμε και μονοι μας , φθηνοι ειναι :P
Περιμένω πως και πώς μηχανάκι που να υποστηρίζει DTS HD σε ματρόσκες , να έχει Sigma chip και καλή υποστήριξη (και τιμή εώς 200)
Θα το χτυπήσω και εγώ αν περνάει τον ήχο στον ενισχυτή...
Kάνει downmix dts... Φαινεται στην παρουσιαση του AVSForum.com. To θέμα είναι αν η WD έχει ενσωματώσει και σε αυτό το μηχάνημα όλα τα καλούδια για ελληνικούς υπότιτλους....
Και εγω για λαιβ πηγαινα αλλα αφου βγαινει αυτο το τερατακι!!θα κανω υπομονη να παω να αγορασω αυτο.:a0210:
Αμα κάποιος ήθελε να πάρει το live καλύτερα αυτό (εξαρτάται και από την τιμή) αλλά αν δεν υποστηρίζει HD Sound διαφορά όντως δεν θα δείς
Απάντηση: Re: WD TV Live Hub
τι θα σας προσφερει παραπανω δεν καταλαβαινω.
Εγώ πάλι μόνο προτερήματα βλέπω
gigabit LAN
ενσωματωμένος δίσκος (το άρθρο αναφέρει ότι ήταν φτηνότερο από ξεχωριστή αγορά 1ΤΒ passport + WD live)
καλύτερο τηλεκοντρόλ! πλήρους μεγέθους και λειτουργιών! ΕΠΙΤΕΛΟΥΣ!!
αυτό είναι και media server (μπορεί αυτό να σερβίρει υλικό από τον εσωτερικό του, και από ότι μπει στις usb του).
1.4 hdmi (3D βλέψεις μήπως? θα δείξει)
Φυσικά καθοριστικό ρόλο θα παίξει και η τιμή του στο Ελλάντα.
unboxing: http://www.youtube.com/watch?v=z1pr8g7rCTo
Review εδω
http://www.anandtech.com/show/3990/western-digital-wdtv-live-hub-review/1
Pros:
  1. 1 TB hard disk bundled, enough for most non-tech savvy users' contents
  2. HDMI 1.4 support plays most existing 3D content on 3D TVs
  3. Expanded online services compared to previous generation product
  4. Improved user interface compared to previous products in this lineup
  5. Supports sync of USB drives and digital camera contents to internal hard disk through USB
  6. Easy control of playback and interaction with the streamer through Web Remote and USB keyboards
  7. TrueHD bitstreaming and WMA(Pro) decode work fully
Cons:
  1. Many bugs existing in previous generation products still left unfixed
  2. GbE port seems more like a marketing gimmick, rather than actually adding to the performance
  3. Content can be transferred to the internal hard disk from a computer using the network only
  4. Can't stream multiple HD streams from the Live Hub, though the specifications seem to indicate that it is possible
  5. For a flagship product, WD should have tried to provide full HD audio bitstreaming / Blu-Ray ISO support / advanced media streamer features
Οι ταχυτητες στο gigabit δικτυο ειναι πολυ καλες, στα ιδια επιπεδα με τα αλλα Sigma μηχανακια με gigabit θυρα που κυκλοφορουν ~10-12 Mb/s. Αυτος που κανει το review συγκρινει με pc...
