Harman Kardon AVR - 255
Status
Not open for further replies.
vadergr
17 August 2007
29,246
Μεταμορφωση
Πωλειται ο πασιγνωστος ενισχυτης 7.1 με το εξαιρετικο design της harman kardon.
Eιναι ελαχιστα χρησιμοποιημενος και δεν πρεπει να εναι ουτε ενος ετους.
Πολυ μουσικος, με εξαιρετικο GUI μεσω hdmi,Faroudja DCDi Cinema scaling to 1080p, και φυσικα υποστηριζει και hd format.
Πωλειται στα 450ε και υπαρχουν ολα τα παρελκομενα του , καθως και η συσκευασια του.
Στειλτε πμ... -bye-
A-BUS® Ready No Amplifier Type High-current ±35 amps Analog Audio Inputs 6 Assignable Rear-Channel AmplifiersYes Bandwidth 20Hz – 20kHz Bandwidth @ 1W (+0dB/–3dB) 10Hz – 130kHz Bass Management Quad crossover Component Video Inputs (Assignable) 3 @ 100MHz Description 7.1-Channel AVR Digital Audio Inputs (Coax/Optical/USB) Rear panel 2/2, Front panel 1/1 Digital Audio Outputs (Coax/Optical) Rear panel 1/1 Digital Input Polling All video inputs Dimensions (H x W x D) 151mm x 440mm x 351mm Direct Audio Inputs 7.1 Discrete Remote On/Off CodesYes DMP The Bridge II Input No Dolby Digital Plus Yes Dolby Pro Logic® IIPro Logic II Dolby True HD Yes Dolby Virtual SpeakerYes Dolby VolumeNo Dolby® Digital Dolby Digital EX DSP Processor Cirrus® CS 49700 DTS 96/24™Yes DTS Neo:6®Yes DTS® 5.1Yes DTS-ES® 6.1 Discrete & MatrixYes DTS-HD/DTS-HD Master AudioYes Ethernet Input No EzSet® Capability EzSet/EQ™ HDMI Type 1.3a with audio/video processing HDMI™ Inputs/Output 3/1 Headphone Modes2-Channel, Dolby HP High Resolution GUI Yes IEC Detachable Power CordNo Input Titling All inputs IR Carrier OutputNo IR-In/Out JacksYes Logic 7®Yes Low-Voltage Trigger JacksNo Multichannel Power (FTC) 50 x 7 Multizone CapabilityNo On-Screen Display Yes, on HDMI and component Output DACs 192kHz/24-bit Power Supply Independent front & rear Preamp Outputs 7.1 Channels Signal-to-Noise Ratio (IHF-A) 100dB Speaker TerminalsColor-coded binding posts Stereo Power (FTC) 65 x 2 S-Video/Component Video Inputs 4 System Remote7-Device preprogrammed THD @ Impedance 0.07% @ 8 ohms USB Input No Video Processing / Conversion Faroudja DCDi Cinema™ scaling to 1080p Weight 13.6kg
Kαι μερικες φωτο...
Απο τα καλυτερα design... -bye-
εγω που τον παιζω σαν προ ειμαι πολυ ευχαριστημενος...
αλλα και τα βατ ακομη που λεει ο κατασκευαστης ειναι τιμια..
μηπως να το ξανασκεφτεις?
Ειναι οντως ετσι οπως λες.
Δεν καιγομαι να τον δωσω, απλα σκεφτομαι για καποιον ενισχυτη με 2x hdmi out...
αν ειδα καλα εχει 3 hdmi 1 in kai δυο out? η οχι?και τωρα που ξαναειδα τα specs 3 in και ενα out Λεει???
Επειδη δεν μπορω συνεχως να "κλεινω" τον ενισχυτη σε καποιους που υποσχονται οτι θα τον παρουν και να γειωνω τους υπολοιπους, ο ενισχυτης ειναι διαθεσιμος στα 420ε και μονο για παραλαβη μεχρι αυριο το απογευμα απο το Νεο Ηρακλειο στην Αθήνα.
Μετα απλα παυει να ειναι διαθεσιμος και τον κραταω.
Οσοι ενδιαφερεστε στειλτε πμ ξανα απο την αρχη.
Σε "προσφορες" κατω απο 400ε απλα δεν θα απαντησω...
Status
