Crystal Audio THX-12SUB
Status
Not open for further replies.
8 June 2007
1,021
ΜΕΣΟΛΟΓΓΙ
Πωλείτε το παραπάνω 12' SUB με πιστοποίηση THX σε αριστη κατάσταση ασιμή χρωμα και στην τιμη 250 ευρω.
The THX Select Certified 12'' THX-12SUB sets a powerful and dynamic foundation for immersive, exciting, you-are-there surround sound. The bass gives the soundfield of your home theatre system a true sense of space.
- THX 12-SUB Select Certified Subwooferfeature flat anechoic response from 35Hz to 200Hz and accurate in-room response from 19Hz to 350Hz
- Sturdy cabinet construction with internal bracing
- High quality, powerful built-in 200 Watt amplifier
- High Sensitivity93dB/W/m
- Long throw woofers with serious magnets for a deep and powerful bottom-end
- Accurate bass performance to THX standards requires one THX-12SUB or two THX-10SUB subwoofers
- Automatic power offto stand-by after 10 minutes without signal
- Automatic power on when signal appears at the input
Crossover DesignTHXLong Term Power Handling (Watt)200Sensitivity (dB/2.83V/m)93Impedance (Ω)4Frequency Response (Hz)20 - 350Woofer12'' Long ThrowDimensions - DxHxW (mm)470x470x350Dimensions - DxHxW (in)18.5x18.5x13.8Maximum Woofer Power (Watt)400
Status
