LG LH9000 : Reviews - Eντυπώσεις - Σχόλια
Yperion
21 June 2006
43,473
BVR (Beyond Visual Range)
LG 47LH9000 Review
SITE ΚΑΤΑΣΚΕΥΑΣΤΗ
http://hellas.lge.com/prodmodeldeta...Id=0102&parentId=01&modelCodeDisplay=47LH9000
ΕΓΧΕΙΡΙΔΙΟ ΣΥΣΚΕΥΗΣ
http://hellas.lge.com/products/mobi...rentId=01&gcscId=null&paramModelCode=47LH9000
REVIEWS
FULLHD................... http://www.fullhd.gr/2008-03-14-21-37-34/lcd-tvs/2475-lg-47lh9000-review.html
HOMETHEATERMAG.... http://www.hometheatermag.com/flat-panels/lg_47lh90_lcd_hdtv/
CNET...................... http://reviews.cnet.com/flat-panel-tvs/lg-47lh90/4505-6482_7-33485570.html?tag=tpr
TELEVISIONINFO....... http://www.televisioninfo.com/content/LG-42LH90-47LH90-55LH90-LCD-HDTV-Review-1354.htm
Re: LG LH9000 : Eντυπώσεις - Σχόλια - Δοκιμες
Aν λαβουμε υποψην τα γραφομενα του FullHd μπορει να κοντραρει στα ισα την Philips 9704 οποτε οσοι θελουν LED local dimming ας ριξουν μια ματια και σε αυτη....
Conclusion
LG got many things right with the 47LH90, including deep blacks, gorgeous color, superb detail, and great frame interpolation. The feature set includes some welcome items, such as the Picture Wizard, Blue-only mode, and 10-point calibration. The remote is easy to use, and the menu is well organized, even if it takes an extra unnecessary step to enter.
On the downside, shadow detail isn’t all that good. Black letterbox bars can appear dark gray and uneven depending on the image brightness in different areas. Also, the THX Cinema mode isn’t as close to correct as it should be, so this set will need a professional calibration to look its best. Finally, it failed some important video processing tests, and SD content didn’t look quite as sharp as I’ve seen on other sets.
At $2,400, the 47LH90 costs far less than last year’s LCDs with LED local dimming, which is certainly a move in the right direction. Can I recommend this TV? Yes, but not without a few reservations. If you think you can live with its shortcomings, its strengths are well worth a closer look.
TEST: LG 47LH90 LCD
The good: Excellent black-level performance and shadow detail; accurate color thanks to extensive picture adjustments; matte screen handles bright lighting well; plenty of connectivity with four HDMI and one PC input.
The bad: Relatively expensive; poor off-angle performance; some blooming; does not separate antiblur and dejudder processing; benefits of 240Hz difficult to discern; no interactive features; no S-Video inputs.
The bottom line: Deep black levels and accurate color help propel the LED-backlit LG LH90 series into the front row of the LCD picture quality class.
CNET: LG 47LH90 Review
Καλημέρα Γιάννη... -bye-
...άλλαξα τον τίτλο του νήματος για να ταιριάζει με τα υπόλοιπα τις κατηγορίας, μιας και θα το χρησιμοποιήσουμε για το συγκεκριμένο μοντέλο..
...επίσης στο 1ο post σου, λέω να μαζεύουμε ότι στοιχεία προκύψουν, ήδη έβαλα τα review που έχεις βρει και το link από το site του κατασκευαστή....
...οπότε, μένει να ξεκινήσουν και οι εντυπώσεις κατόχων!!!
Τελικά με το shadow detail τι γίνεται; Οι μισοί γράφουν ότι υπάρχει πρόβλημα, και οι μισοί ότι δεν υπάρχει... :smash:
Τελικα εμπιστευομαστε τις βαθμολογιες του FullHd η οχι Γιωργο?
1000 ευρω διαφορα για 1% χειροτερη εικονα απο την 9704...πολλα δεν ειναι?
Εγώ εμπιστεύομαι κυρίως το μάτι μου...
Και την 9000 δεν την έχω δει, δυστυχώς.
Γενικά με την LG έχω πρόβλημα με την κίνηση που βλέπω στα καταστήματα, αλλά τα περιεκτικότατα μενού είναι μεγάλο δέλεαρ...
Καλό θα ήταν να μας έλεγε ο Μάνος ποια είναι τα "σημεία" στα οπόια χάνει η 9000. Και για το halo πάλι δεν ξέρουμε τίποτα... :ears:
Από την άλλη έχει μόνο 1300 ευρώ;; (η 9704 έχει 2.300).
To Γερμανικο περιοδικο Video-Home Vision που εχει δοκιμασει και τις δυο βαζει 78% στην LG και 88% στην Philips...
Προφανως και αυτη την φορα καποιος δεν μας τα λεει καλα...αλλο 1% και αλλο 10%...:D
Εγω προσωπικα θα ελεγα οτι η αληθεια ειναι καπου στην μεση...
Μου φαίνεται πολύ καλή πρόταση για όσους δεν διυλίζουν τον κώνωπα....
Τέτοια τβ με 1.300 ευρώ πέρσι ούτε στον ύπνο μας (σε LCD).
την εχει δεικανεις απο κοντα????σε τηλεοπτικο σημα τι λεει???εχει κανενα προβλημα οπως input lag σπασιματα στην κινηση η κατι παρεμφερες????ειχα παραγγειλει την 750,ο φουρλης δεν δινει σημεια ζωης εδω κι 40 μερες και τα πηρα κρανιο...λετε να παρω αυτη???πως σας φαινετε σαν επιλογη???η τιμη της ειναι πολυ καλη αν μη τι αλλο
Αν θυμάμαι καλά κάπου τόσο είχε προσφορά την Α789 της σάμσουνγκ πέρυσι το πράκτικερ για κάποιο διάστημα...
την ειδα απο κοντα και στο plaisio mall και mediamarkt, δεν μπορω να πω οτι ενθουσιαστηκα,αλλα το μαυρο της ειναι οντως καλο.Πιστευω τιμια αγορα στα χρηματα της
Σε ένα τεστ διάβασα ότι έχει Bluetooth ενώ σε άλλο ότι δεν έχει. Γενικά υπάρχει κάποιος είδος ασύρματης σύνδεσης (DLNA, Bluetooth κ.λ.π) για αποστολή εικόνων και βίντεο;
